Question about Dell Inspiron 600m 1.6GHz Pentium M Notebook (162891033) PC Notebook
UNMOUNTABLE_BOOST_VOLUME HI SIR: MY LAP TOP READS ,DISABLE OR REMOVE ANY NEWLY INSTALLED HARDWARE OR SOFTWARE. DISABLE BIOS MEMORY OPTIONS SUCH AS CACHING OR SHADOWING. JOSE
Dell Inspiron 1525 Error Code 0333 Blue Screen of Death:)
Hello
If this is the first time you've seen this stop error screen, restart your computer. If this screen appears again, follow these steps:
Check to make sure any new hardware and software is properly installed. If this is a new installation, ask your hardware or software manufacturer for any windows updates you might need.
If problems continue, disable or remove any newly installed hardware/software, disable BIOS memory options such as caching or shadowing your computer, press F8 to slct Advanced Startup options, and then select safe mode
it could be a memory (RAM) problem. Many Dell's have a Diagnostic partition on the Hard Drive, accessed by F12 at initial boot up. If yours has this, run a complete diagnostic and see if there are any errors.
Try to reboot in safe mode using "last working configuration" and do an evaluation and see what comes up
Apr 15, 2011 | Dell Inspiron 1525 Notebook
It stated on my lappy " UNMOUNTABLE_BOOT_VOLUME" "check to make sure any hardware or software is properly installed" and ask my hardware or software manufacturer for any windows...
UNMOUNTABLE_BOOT_VOLUME - Windows is completely corrupted and the BIOS can't load it.
Just load the default settings in the BIOS and then reinstall Windows using the recovery cd that came with it when you bought it.
Jan 14, 2011 | Dell Inspiron 9100 Notebook
Unmountable boot volume
Unmountable boot volume means your hard drive has gone out...You will need to replace it.There is no way to fix this this.
Apr 24, 2010 | IBM ThinkPad T22 2647 Notebook
When i turn on the laptop there are a blue screen and that is the text - there are a problem has been detected and windows has been shut down to prevent damage to your computer. UNMOUNTABLE_BOOT...
did you install any new hardware like a card, usb product, please have them removed, also if you enabled any stuff on the BIOS setup please go back and disable now, let me know what the situation is,
regards
Apr 21, 2010 | Computers & Internet
Computer: dell dimensio c521 problem: when i turn computer it goes to a black screen stating: "diskette drive 0 seek failure" and below it says: "Press F1 to continue, F2 to enter SETUP. i pressed...
Please follow the below stesp:
Enter the setup, and there will be a setting in there somewhere called "Halt On" and if you set that to "No Errors" the computer should boot fine.
This works with Dell computers.
Diskette drive 0 seek failure — See "Drive Problems" in your Owner's Manual.
Apr 01, 2010 | Computers & Internet
Blue screen on my P.C.,windows shut down
If you are using an AGP or PCI graphic card try disabling the on board video adapter from BIOS.
Ensure that you have the latest drivers for this video card installed.
If the video adapter is using shared memory, then you may have a faulty RAM module.
Reinstall Direct X and any graphic acceleration software.
Go to BIOS and disable memory caching and shadowing options, this usually does not solve the problem, but you never know.
Contact video card or Motherboard manufacturer, there may be an issue between video adapter and your motherboard, or the specific software that you are using. In that case manufacturer may require to download a patch.
May 16, 2009 | Palit Microsystems GeForce 8400GS,, PCI...
Blue scree, or system crash
This link should help you a lot. The problem is an unmountable boot volume.
http://www.techtips4u.com/kb/sw/SW00014.htm
Please let me know if this helps you out.
Mar 12, 2009 | Dell Latitude D600 Notebook
Compac Presario C700-Audio Drivers Not Installed properly
in winxp some sound driver probelm
please install windows vista
Jul 12, 2008 | Compaq Presario 700 470024-192 Notebook
Computer on the blink
this is the'blue screen of death..the Dell model is usually on a tag somewhere on back. supply that, and perhaps you can gain assistance here(I'm Dell Certified going back in time, by the way)
May 08, 2008 | Dell Dimension 3000 PC Desktop
Just use ORIGINAL OS CD and repair OS everything will work fine!
Dec 27, 2007 | Computers & Internet
Computers & Internet Logo
186 people viewed this question
Alun Cox
