Question about Makita AN901 Coil Nailers
Makita AN 901 framing nailer blows nose end apart
I am a small contractor in Nova Scotia. Canada and we have 3 AN 901 framing nailers in circulation. We used these nailers for the last 7 years and my guys as well as myself love them. They are very light and well balanced and have some great features that are hard to find on other nailers. The problem is for the last couple of years we can not stop the nailers from blowing apart the metal nose piece or discharge end. We have had the nailers replaced under warranty twice and ended up taking one out of service to rob the part to make another work. Makita has said that there is no problem but have no solution or answer to how this happening. We have tried 3 different brands of nails but it makes no difference as all have had the same result at some point. It breaks where the piston drives the nail down through the chamber and exits the gun. It shatters this metal peice into sharp fragments which causes cause for safety concerns. This seems to happen as result of two nails trying to be fired at the same time thus causing enough pressure to rupture the cahmber. I am game to try a different nail or method or any suggestions anyone may have. They have since told me that I am not the only case of this problem as someone from Montreal has had the same problem. We have tried Prime Nails ( offshore nails ), Duchene nails and Senco nails in both 2.5 and 3.25" with problems. If anyone else has problems please email me at nwinds@xplornet.com
  • David Ford
    David Ford May 11, 2010
    I would take a look at the air pressure 65-120 max. Then I would look at the piston/driver to make sure that is flat and condition of the bumper. While your at it check over the feed mechanism. Usually when they try and fire 2 at a time the piston might not be retracting fully or the pawls are damaged or worn. I worked for Makita and never saw the problem that you are describing. You might also want to check the collation of the nails that they drop into the pawl dogs properly. They do make a rebuild kit for this tool if any parts are worn. Good luck. Dave
    Champion:
  • 205 Answers
Not too familiar with makita brand nailers but jams are usually caused by cheap nails but I see you have tried senco brand which is a good brand sounds like a mfg defect try using hitachi brand nailers they are good
Posted on May 29, 2009
Why does my Senco SN 901 XP frame nailers driver stay forward?
not sure what powers the senco if it works on combustion or air could be damage O rings. Another possibility is a trapped nail under the blade. Have seen where a nail has not been driven out of the magazine but has bent and points down the magazine close to end of gun. What happens is the blade drives over the nail but becomes trapped between nail and roof of the nose assy. Probably need to strip the gun a little.
Mar 24, 2014 | Tools & Hardware - Others
Ridgid r350rhd-round head framing nailer the nail is jammed in backwards behind the push rod. don't ask me how it is backwards
FYI The fact that you've managed to flip a nail in the nose can suggest a nail that's too short. Rule of thumb is that framing tools use from 50mm (2") up.
Sep 20, 2013 | Ridgid Full Round Head Framing Nailer...
My Duo-Fast Strip nailer has the driver blade jammed in the nose of the tool, cannot budge it?
Possibly a piece of nail,,use a small flat tip punch and small hammer and see if you can dislodge drive,,E Z does it
Feb 05, 2013 | Air Tools & Compressors
Having nails jam on regular basis,could the driver be worn and if so can i replace just this part?
yes you can buy a replacement piston assembly, BUT first I would check the end of the driver and also the nose assembly for wear. If the nose gets worn excessively it will allow the driver to "move" . Also check the nails for a problem. You can go to "hitachipowertools.com" for parts listings. If the driver end is not worn that bad you can CAREFULLY smooth it off some with a bench grinder being careful not to remove too much material. Check the orings also when you have it apart.
May 08, 2011 | Hitachi 3 - 1/4" Framing Strip Nailer
My DC616 a straight 16 gauge DeWalt finish nailer tries to drive 2 nails when it fires 1 out of about every 5 to 10 shots. I am a finish contractor and have used this nailer for about 6 years. I was...
Argh...
Had the same problem, but only after about 4-5 nails. Once it jammed 4 times in a row - very frustrating.
I read the manual, took the unit apart, checked the driver - it was straight. I took a file and filed the back end of the driver down a bit so it would miss the second nail and so far it seems to be working famously.
Great unit...
Sep 07, 2010 | Dewalt DC616 16g Cordless 18v Straight...
I am having problem with my Dewalt D51823 Framing Nailer- air started leaking out of the nose always when is plug to the compressor. the gun is immaculate inside. quite annoying the compressor keep...
Either the plunger has not completely returned to the "pre-firing" position, or there is a defect in one of the o-ring seals. Make sure that the gun is sufficiently lubricated and if so, then next check the condition of the o-rings. An improper seal will cause this. It is also possible that the trigger assembly has a small crack/leak.
Dan
Jun 11, 2010 | Dewalt Heavy - Duty 31° Clipped Head...
Paslode framing nailer/15 years old approx. air blowing by on top of end cap exhaust does not fire
Needs a new set of O rings in the head. Probable needs the trigger set also, and a good cleaning while you have it apart
Jul 21, 2009 | Tools & Hardware - Others
Need tofind a used nose peice
This solution may sound way out there, but generally nose pieces are expensive, so you may want to go hunting through the pawn shops for the same model, in crappy condition, in order to get one
Jul 12, 2009 | Makita AN901 Coil Nailers
Makita AF503 Brad Nailer won't fire nail
Take head off of tool. Clean and lube orings on the head valve . Do not use wd40 use air nailer oil.
Apr 11, 2009 | Makita AF503 2'' 18 - Gauge Brad Nailer
Makita AN901 Coil Nailers Logo
504 people viewed this question
Top Makita Tools & Hardware - Others Experts
Jim Thurston
Mike Squire
John Trevino
Are you a Makita Tool and Hardware - Other Expert? Answer questions, earn points and help others
