Question about Jenn-Air JJW8630C Expressions Collection Electric Double Oven
JJW8630CAB A week ago, I replaced the control panel when the display went out. The new control panel is working good. Now bottom oven will not work. The bottom burner and the broiler will not heat at all. The light and fan, on bottom oven, works as should. I turned on the broiler and the fan came on but burner would not heat. Husband cleaned both ovens a week ago. The top oven works. Last year we had a pyrex dish explode in the bottom oven. It was cleaned thoroughly and has worked until now. Any ideas? Signed, Wife who takes care of all.
  • sdelancey Jan 02, 2009
    Thanks for the manual. Solutions listed in it did not help.
    Brigadier General:
  • 6,966 Answers
Hi and welcome to FixYa,
Offhand in most ovens, there is a thermal probe that look like an elongated thermometer with electrodes/2 wires. This is the temp probe inside the oven. If it is faulty, the controller will not switch on either or both the upper & lower heating elements.
Or it might just be an open heating element.
Good luck and Thank you for using FixYa. Happy New Year.
Posted on Jan 02, 2009
    Sergeant:
    Novelist:
  • 326 Answers
    Genius:
  • 1,011 Answers
Dear Sir/Madam,
Click this link for more information....
Most likely the problem with your oven is a bad igniter. The first thing you do is a visual test. Turn the oven on, wait at least 30 seconds and take a look at the igniter. It should glow very bright red, almost close to white. Normal time for the igniter to open the gas burner valve and to light up the burner is between 40 second to 1 minute. If it glows red but not bright, the igniter is bad and has to be replaced. If it does not glow at all, remove the power from the range, remove the igniter wires and check for continuity between these wires. If there is no continuity, replace the igniter.
thanks
good luck
  • Jenn-Air Master
  • 19,396 Answers
The glass dish exploding may have amaged the thermocouple that controls the lower burner, or may have damaged the valve or cut a wiring leading to control assembly.
All this parts must be inspected.
Enter model number here to find assembly diagrams and parts.
  • 15,935 Answers
Frigidaire oven wont heat up but stovetop and digital all works
Hello angeleyez82 - The EOC (electronic oven control/control board) basically sends power to both the broil and bake elements. As long as the power supply to the range (240VAC) and wiring between the elements is correct, then typically only the element(s) or EOC could prevent the unit from heating. I hope this information helps to some degree.
Jun 25, 2013 | Frigidaire 30" Self-Cleaning Freestanding...
Frigidaire oven
Yes, that sounds like a relay on the oven control board. Here is the part to order that has a 365 day, any part, any reason return policy so you may want to order from them.
Jun 25, 2013 | Ovens
I have a new control panel that was just put in 2 weeks ago. I pressed the button start to long & the "Loc" came up on the display & it won't go off no matter what button I push. I've...
Did you replace the panel yourself? If it was a repairman it should be under warranty. Anyway I would think that after the supply has been turned off overnight the timer would reset itself. If that doesn't work and you don't want to keep mucking around with control panels and you can do without the electronic clock the control panel can be easily bypassed by a repairman. This will then enable manual oven operation.
Feb 16, 2011 | Ovens
My GE double oven JKP26GP broiler burned out (burned a hole right thru). The keypad immediately went blank and the keypad controlled top unit isn't working now (top unit only - bottom is fine). Will...
I'm afraid I don't know how to help you get a new control panel (part #WB36K5065 is no longer available). But we have the same oven and a similar problem. Our control panel works just fine, but the face is melted from a recent mishap (small fire in the upper oven while broiling), so the plastic face of the control panel looks awful and needs replacing. If you decide to replace your oven and would like to sell the front face to your control panel we'd love to purchase from you.
Nov 21, 2009 | GE Ovens
Thermador SC302 double oven the top oven is not getting hot
We've had the same problem. I contacted a local sales room and they contacted their rep who promptly mailed the replacement parts I requested (I'd looked up the part numbers already). Now I'm waiting to find someone who will reasonably do the work.
Aug 10, 2009 | Thermador SMW272 Electric Double Oven
E2 F6 ??? What the? Oven came with house, no manual.
Your oven temperature sensor has failed(e-2) as well as your electronic control board(f-6). The oven temp sensor, electronic control board and the touchpad must be replaced . Approximate cost of parts is $500.00. Before you decide what to do, check the thermal fuse at the control panel first. If blown, replace it and the temp sensor. If you are lucky the control board may still be good.
Jun 12, 2009 | Whirlpool RBD305PD Electric Double Oven
Display on my Jenn-Air electric wall oven is very dim
douglas9101,
I had the same problem and found the solution on-line.
Replace the C3 capacitor on the dispaly module. (100 UF, 35 volt, high temperature)
The local Jenn Air dealer wanted $211 for a new display module.
I purchased a Cap from a local electronics supply store for 79cents.
The only problem is that you need to have a soldering pencil/iron, a solder ******/wick and a small amount of solder.
Steps I had to take on my oven:
- Flip the AC breaker supplying the oven to off to be save
- remove 3 screws on top and 4 on the bottom of the display panel
- gently pull out the display panel and unplug the 2 cables to the display
- unclip the ribbon cable to the display module
- unclip the module itself by pushing on the 2 black tabs
- locate C3
- unsolder C3 and replace with new Cap- keeping the polarity strip the same as theh old Cap
- reasemble in reverse order.
It took me all of 20 minutes. It may sound difficult but is very easy if you have the tools
Good Luck
K
May 11, 2009 | Jenn-Air 27 in. Electric Single Wall Oven...
Neff Oven
It appears that the timer has gone faulty, possibly because of a short in the bulb holder, which probably explains why there is no display and the main oven not working. the top will still work as it is not controlled by the timer.
the solution hear would to be fit a new timer.
Sep 30, 2008 | Neff U1661 Double circotherm super...
Whirlpool Double oven - control panel stopped working
Atlanta...sounds like you may have a power supply problem or the panel is bad. Cut the power, open the unit up and see if there is a fuse in there or a reset. No good? Then replace the circuit board. They just, well, die sometime. Happened to my microwave. Some units may be available remanufactured. Look around on the web.
Dec 06, 2007 | Whirlpool RBD245PRS Stainless Steel Oven
Jenn-Air JJW8630C Expressions Collection Electric Double Oven Logo
161 people viewed this question
Top Jenn-Air Ovens Experts
Oloyede Monsuru
Craig Butler
Craig Butler
Are you a Jenn-Air Oven Expert? Answer questions, earn points and help others
