Question about Creative Labs Zen MicroPhoto MP3 Player
Freezes at rebuilding library
I am trying to download firmware onto my microphoto I have done everything tech support told me. On how to reboot and erase the memory then to download the firmware off of the creative labs site. But when it gets to rebuilding library it freezes. The mp3 player just sits there with that message on it. Is this something that can be fixed or is this a fatal problem? It started having problems after it was removed from the docking station without being shut off first. thank you for your time, Dawn
    President:
  • 4,402 Answers
Go into recovery mode and do a clean up if that doesnt work you will have to do a format.
also make sure you have the current firmware version.
good luck
please mark the post with a fixya
Posted on Feb 25, 2008
SOURCE:
Creative zen microphoto v0.0.65
If a problem is occuring with the firmware, then just go onto the CREATIVE ZEN website /www.creative.com and select the model of your creative mp3 player.. once you have selected the modell it will then scan your mp3 player to check what it is required and then reccommends the downloads listed. However it is vital that your mp3 player is connected to your pc via usb lead.
Dec 11, 2008 | Creative Labs ZEN Vision:M Digital Media...
Creative Microphoto MP3
Sounds like a hardware issue, do you have warranty on the player?
Jun 02, 2008 | Creative Labs Zen MicroPhoto MP3 Player
My Zen Freaking Froze Up!!!
Reset button to left - use a paperclip. If its a 4gB it might be faulty.
Apr 27, 2008 | Creative Labs ZEN V Plus MP3 Player
Turning on
try downloading the MP3 player recovery tool from Creative's website (the tool contains the latest firmware update available -- 1.15.03). Plug your ZV+ into your PC, run the program and let it update the firmware. Then format, reload your music and try it.
By the way, before updating the firmware, let the battery have a full charge, ok?
I hope it won't keep freezing on you after the update
Jan 24, 2008 | Creative Labs Zen MicroPhoto MP3 Player
Freezes at "rebuilding library"
I just found this on another website and it seems to be working so give it a shot
Listen!!!!! Anyone having problems try this before you blame the product. Turn off player........remove battery.......hold on button ON and put battery back in while still holding the power button on. When power comes on release the power button. You should now see a clean format and re-boot screen. Use the clean function two times. After the second time go down to reboot and should be fine. Worked for me. The Zen Micro Photo is a sweet mp3 player. Dont blame the product for something YOU most likely did. This will fix 99% of your players problems
Nov 12, 2007 | Creative Labs Zen MicroPhoto MP3 Player
Zen Microphoto frozen..
Solution ID # 4794 from creative site ZEN Micro and ZEN MicroPhoto 1. Make sure that the battery is charged. 2. Detach the ZEN Micro or MicroPhoto from the PC, and ensure that it is turned off. 3. Remove the battery. 4. Move and hold the Power button to the Power On position and re-insert the battery to the ZEN Micro or MicroPhoto. Hold the Power button until the Recovery Mode appears. The following options will be displayed: -Clean Up : Scans the player and removes invalid links from its music library.Does not affect music files themselves. -Format (All):Caution! Erases all content!Save a copy of your player's content before formatting. -Reload OS/ Firmware : Caution! Erases your player's firmware. DO NOT select the Reload Firmware option unless you have access to a PC and you have downloaded the necessary firmware to install. Reboot Reboots the device.
Jul 29, 2007 | Creative Labs Zen MicroPhoto MP3 Player
Wont work,won't acsept updates,no files only 4 options done all
try another computer and download the latest firmware from creative
or use the recovery tool then update the firmware.
Jun 11, 2007 | Creative Labs Zen MicroPhoto MP3 Player
Zen Microphoto
get it to see the unit again and download the latest firmware.
if after that it still wont load your hard drive is toast. (did you drop it)?
Jun 02, 2007 | Creative Labs Zen MicroPhoto MP3 Player
Zen Micro
Sounds like it may be the index in your Music Library. Try going into Recovery Mode; remove battery, hold power switch to ON, replace battery, release power switch when the Recovery Mode screen appears on the screen. Run Option 1 CleanUP, after it completes run Option 4 Restart. You will get a Rebuilding Library screen when it reboots, that's normal, then it should go back to your startup screen. Good luck and let us know what happened
May 01, 2006 | Creative Labs Zen Micro MP3 Player
Creative Labs Zen MicroPhoto MP3 Player Logo
106 people viewed this question
Top Creative Labs Audio Players & Recorders Experts
Marvin
Marvin
Peter Dragonetti
Are you a Creative Labs Audio Player and Recorder Expert? Answer questions, earn points and help others
