Question about Daewoo P480 DVD Player
DVD is stuck
The DVD open / close function has stopped working. What should I do to fix it so my precious DVD can come out... Thxs. Fix me
I figured it out....Butter Knife did the trick. Thanks anyway!
Posted on Apr 18, 2007
The button to open/close my Philips DVD player Model DVP5140/37 is not functioning, and the remote does not have an open/close button. How do I fix this??
Here are some troubleshooting steps to get you started to resolve the issue.
First, Try to unplug the unit for 10 seconds from the power source. Wait 10 seconds after unplugging and reconnect. Try to open/close and see if the tray opens. This may resolve the issue as this is what Philips Technical Support says to do in this situation on their website.
Also, you should be able to eject with the remote. To eject or open the disc tray with the remote, you need to hold the STOP button on the remote for 5 seconds.
Hope this helps! If not, I was told to give a direct phone call to Philips Customer Care Center from 12pm-8pm EST Monday-Saturday. Their phone number is 1-866-323-9916. Have the device/unit ready when you call with the Serial Number handy.
Warm regards,
Craig
Mar 20, 2011 | Philips DVP5140/37 DVD Player
Tip
Orion DVD-2000 Region Free Fix
Orion DVD-2000 DVD Player Region Free Fix
Would you like to unlock your Orion DVD-2000 DVD Player to Region Free?
Follow these steps to unlock your Orion DVD-2000 DVD Player :
  1. Power on your machine.
  2. Hold the Stop, Open/Close, Skip Forward and Skip Backward buttons simultaneously for 3 seconds.
  3. A 'hidden' menu will appear.
  4. Release the Stop, Open/Close, Skip Forward and Skip Backward buttons on your player.
  5. Select Region Number from the hidden menu and choose the Free option.
  6. Exit the menu.
Your Orion DVD-2000 DVD Player is now Region Free.
I hope that helps.
on Apr 25, 2010 | Televison & Video
My DVD tray on my Yamaha DV C6480 (it holds 5 DVDs) got stuck in the half open half closed position. It may have come off the track. I opened the case and reinstalled the DVD Tray. Now the tray...
This happens to us all the time. Here is the note I keep on how to fix it quickly:
When tray gets messed up, the drive wheel (with pegs that interlock with pegs on the tray) needs to be such that the tray slides in and out freely. Push tray all the way in. Turn on.
Hope that gives a hint.
Nov 04, 2010 | Yamaha DV-C6480 Multi-disc DVD Player
My coby-514 dvd won't open up when the open/close
disc is stuck, remove cover screws and carefully remove the disc, do not force the unit, once the disc is out use the remote to close the unit, then use remote to open and use a different disc press play and hopefully it will work, try to avoid not using the remote for all functions,including open-close. do not push tray in manually.
Dec 10, 2009 | Coby DVD-514 DVD Player
Model R-1460, when I shut the door it runs but doesn't heat up. What needs to be done to fix it?
Do you mean that when you close the door, the fan comes on? If so, it sounds like a bad door switch. Probably the secondary interlock switch.
This failure is caused by opening the door when the unit is in cook mode. On ALL microwaves, not just one or two brands.......
Be sure to push the stop button before opening the door to add or stir... Or wait for the cook cycle to end. (This is why microwaves have a two step function on the stop/clear button. Hit stop once to stop cook mode and twice to reset timer).
You should use an ohm meter to check all 3 switches. The switch can be either stuck 'closed' or physically closed but not 'making' electrically.
Sep 13, 2009 | Sharp Microwave Ovens
Cannot open dvd.
hey i have the same problem! did you manage to fix it? if can u contact me at mesheluvz@yahoo.com. thanks
Apr 17, 2009 | Televison & Video
DAV-HDX265 dvd tray doesnt open
well, if you hearing clicks is possible that you will only be able to fix by opening and looking if the door has been misplaced..... is possible that a cd is stuck and you need to open to fix.....
another way to fix is to press and hold Eject and Stop ON THE UNIT! while turning the nub to the right (volume up)
that will open the the service unlocking the system!!!!! THAT WILL ONLY WORK if the door or a cd is NOT stuck on it
Aug 28, 2008 | Audio Players & Recorders
Samsung dvd-r135
The Disc Tray Will Not Open And/Or There Is A Disc Stuck In The Player. spacer.gif Some DVD Players manufactured prior to 2003 have a Dealer Lock or Child Lock function. This will prevent the panel buttons from operating.
This function is activated by pressing the STOP button on the front panel
and the POWER button on the remote control simultaneously for four seconds in the power on state. Repeating this sequence releases the dealer lock. When the dealer lock in activated, DEALER LOCK ON or DEALER LOCK OFF scrolls on the display.
If this does not resolve your problem there may be an error with in the player. To resolve this try the following these steps:
  1. Unplug the DVD player from the electrical outlet and leave it unplugged for thirty seconds.
  2. Plug the DVD player back in to the electrical outlet, but do not turn the DVD player on.
  3. With the DVD player off, press the [Open/Close] button on the front of the DVD player. The home theater should power on when you press the [Open/Close] button and eject the tray.
The second option worked for me...
Apr 12, 2008 | Samsung DVD-R135
DVD will not close its door
Open it up (take the screws out) and see if one of the door tracks came out. Just snap it back in place.
Jun 26, 2007 | Zenith DVB317 DVD Player
I am having the same problem as Peg!!!
The belt that changes the disc is broken. can fix with a goody hair tie w/o a metal clasp.
Feb 15, 2007 | kawasaki SVP500 Multi-disc DVD Player
Daewoo P480 DVD Player Logo
172 people viewed this question
Top Daewoo Televison & Video Experts
 Grubhead
Grubhead
Are you a Daewoo Televison and Video Expert? Answer questions, earn points and help others
