Question about Konica Minolta bizhub 350 All-In-One Laser Printer
Konica Minolta C450 Scan function loses registered address book
I can access the printer/copier/scanner on the network via the web interface and see that there is an address registered in the Address Book, but from the scanner it no longer sees the address book. This has happened before but mysteriously reappeared. I can ping printer, access via web gui - so I know it's on the network.
Any help would be appreciated.
    Problem Solver:
This has happend before when creating a group in account track... check to see if you have a limited group on.... if so delete the group or change the limitations to (0)
Posted on Jan 02, 2009
Minolta C450 C-D212
Will require a re-flash of the board firmware, MFP. Multi-Function Board. Or Replacement $$$$$$$$$$$$$$$$$$$$$. Firmware via a Secure Konica Minolta Web site they like their firmware secure that is why you will need a tech.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
Apr 28, 2014 | Konica Minolta bizhub C450P Laser Printer
Konica Minolta c450 Network Print- Data comes at the machine end but no print
does this happen with word , pdf, web pages, email? what other indication display on screen
Jan 02, 2014 | Konica Minolta bizhub C450P Laser Printer
How to setup scanner konika c450 in win7
you need to type in the IP address of the machine into the search bar and log onto the user interface, then you need to log on as the administrator and add the settings under network.
Oct 06, 2013 | Konica Minolta bizhub C250 All-In-One...
How do you please enter an email address into the address book?
the web interface is the easiest. you need to type the ip address in your web brouser on your computer connected to the copier. then login admin. password is 00000000 or 12345678 it may have been changed and if so i can help with changing it back to factory default. once logged in you may need to refresh webbrouser to get the scan tab. there is your address book. and a place to add more
Jun 16, 2011 | Konica Minolta Bizhub c203 Copier
Konica Minolta BizHub 222. message "Now
This message usually comes up when someone is accessing the BizHub via the web GUI. Disconnect from the webGUI, and that message should go away.
May 27, 2011 | Konica Minolta bizhub C250 All-In-One...
Pls. help us,how can we used land cord to connect printer konica 7035 to computer. we already down load a driver from internet . we try many times to check sa IP address and test print but still we cannt...
Using arp command (UNIX)
From UNIX you can use the arp command to assign the IP address to the network interface card.
Perform the following procedure:
1. Turn off the print controller and the main body printer.
2. Log in as superuser on a host on the same subnet as the network interface card. However, if
the server resides on another subnet, complete this procedure to store the IP address in the
3. Find the MAC address of the network interface card. The address is printed on the Status Page
each time you turn on the print controller and the main body printer.
4. Edit the hosts file (usually /etc/hosts) or use NIS or DIS to add IP address and node name of
the network interface card. See the network administrator for the IP address. For example, a
network interface card with a name of printfast and an IP address of 192.9.200.200 has the
entry:
192.9.200.200 printfast
5. Add an entry to the arp cache for IP address and Mac address of the network interface card,
as:
arp -s 192.9.200.200 0:40:c8:0:0:ff
RS6000 (AIX) requires the ether option after arp -s. For example:
arp -s ether 192.9.200.200 0:40:c8:0:0:ff
6. Check the print controller and the main body printer to see that the network interface card is connected
to the network. Turn on the print controller and the main body printer.
7. Send a ping command to the network interface card to verify it is running on the network, as
for example:
ping 192.9.200.200 or ping printfast
The network interface card will not respond to this ping command but it will read its IP address
from the packets.
8. Turn off the print controller and the main body printer and back on again and then send the
ping command again to verify that the network interface card obtained its IP address. A confirmation
message displays as:
192.9.200.200 is alive
9. Remove the entry from the arp cache using the following command. Specify the network
interface card either by its IP address or by its name, for example:
arp -d printfast
Konica Network Interface Card INSTRUCTION MANUAL 2-5
Chapter 2 Setting Up the Network Interface Card
Using MAP
By using MAP (Management Access Program) included the CD-ROM that comes with the network
interface card, you can automatically identify the network interface card on the network and set it up
for TCP/IP by using Web Utilities. To use this method to assign the IP address to the network interface
card, the following procedure should be performed on computers in advance:
• TCP/IP correctly configured
• IPX/SPX-compatible protocol installed
• MAP installed and MAP setup correctly executed
About how to set up TCP/IP and how to install IPX/SPX-compatible protocol, refer to Windows Help
menus for example. For MAP, refer to “Using MAP (Management Access Program)” in this chapter.
To change an IP address already assigned to a network interface card, you can not use the
arp command. Use Web Utilities instead. These methods also allow you to set up subnet
mask and default gateway, etc.
Using NIManage
Refer to “Chapter 7 AppleTalk Configuration”.
 Accessing Web Utilities
The network interface card is provided with an HTTP server having Web Utilities. By accessing this server,
you can change settings of the printing system. There are two ways to access Web Utilities, through a Web
Browser, either through Netscape Navigator, version 4.x or greater or through Internet Explorer, version 4.x
or greater.
• Use MAP to have the network interface card on the networks identified automatically, thereby accessing
Web Utilities.
• Use a Web Browser to type the IP address assigned to the network interface card, and thereby access
the Web Utilities. For example:
http://192.168.0.128/
If you designate the proxy setting in your Web Browser you cannot access the Web Utilities.
For more information see your network adminisrator.
2-6 Konica Network Interface Card INSTRUCTION MANUAL
A utility called MAP is provided on the CD-ROM that comes with the network interface card.
This program automatically identifies the network interface cards on the networks and lists them on Web
Browser screen. From this Web Browser list you can select a network interface card to change its settings
and control Web Utilities.
Aug 31, 2009 | Konica Minolta Office Equipment & Supplies
I need to scan to email using the c353 konica Minolta. I used the same settings that the copier has that is working, but this one i set up won't scan to email.
This are the the information you need to setup scan to email and maybe you know how to access the web browser to setup the network. first you need to know the smtp host name or ip address, second you must create a valid email address for the copier. To access the web browser input the ip addrress and press enter click administrator and the password is 12345678 or 8 zeros. there are tab system info print, scan and network. click the the scan tab. choose scan to email first thing you will see enable scan to email smtp ip address or host name. enter the right smtp. witch this you can get to your mail server. do not change the port # and that is 25. Input administrator email address and the machine email address and turn on the authentication enter your user id and a password iof there is any.
Jun 12, 2009 | Konica Minolta bizhub 350 All-In-One Laser...
Konica minolta c252 how to sharing pc....
If you are just adding your PC to the network first go to control panel click network set-up wizard.
to add your PC to print add printer from the control panel and look for the network printer. last you want to scan go the internet web browser input the ip address of the scanner or copier click public or administrator enter password 12345678 and click scan tab and add your PC host name or your email address if scan to email.
HH
Jan 10, 2009 | Konica Minolta bizhub C250 All-In-One...
Dear Sir Plz Help Me Plz.
If the button on the touch screen is not visible for the network settings in the administrator settings there is definately something going on. Try connectng to the web interface by typing the current IP address of the copier into the address bar in Internet Explorer. If you do not know the IP address that was assigned to it then Google for Angry IP Scanner, download, and install it. Let it scan your network and find the IP address that way. If you have the right IP address nd cannot access the IP then try it in Mozilla Firefox. You PC must be in the same IP range for any of this to work.
Once you get into the web interface you need to hit LOGOUT as you are in public mode. Then log back in as administrator. The default password is 00000000 or more likely, 12345678. YOU MUST LOG OUT OF ADMIN MODE. DO NOT JUST CLOSE THE BROWSER WINDOW. This will lock up the control panel and cause problems.
You can change the IP address from the web interface in admin mode.
If none of this works then contact me and I will go further. Hope this helps.
Oct 05, 2008 | Office Equipment & Supplies
Konica Minolta bizhub 350 All-In-One Laser Printer Logo
610 people viewed this question
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Adorjani Laszlo
carpediemweb
Level 1 Expert
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
