Question about Canon EOS-50E 35mm SLR Camera
EOS50E Program ring on the top moves hardly
How can I remove and clean program ring (on the left od flash) on the top of body EOS 50E.
I don't want to do it with force.
Thanks.
  • 50 Answers
I have just submitted a solution today for a broken dial which explains how to remove the dial assembly.It isn't difficult.Bob Carllson.
Posted on May 11, 2009
What could cause norstar m7208 phone to not receive incoming calls
If you have lines appearing on your phone and they don't ring you need to program lines to ring. This type of programming is done from a M7310 phone. Page 323 of this manual shows how to program this on a NorthStar MICS Ver 6 phone system.
http://pdf.textfiles.com/manuals/TELECOM-F-R/Nortel%20MICS%20System%20Installer%20Guide%206.1.pdf
Enter the programming mode : Feature **266344
Password:266344
You will have 4 programming buttons on your phone, normally the 2 top left and 2 top right of the 2 vertical rows.
top left = move up one level
lower left = back
top right = select
lower right = next
once you enter the programming mode press next to "Terminals and Sets"
press select
enter your extension number
press select
press next to "Line Access"
press select
press next to "Line Assignment"
press select
use the next key to go to the line you want and use the soft-key below the display to change it from "Appear" to "Appear and Ring"
May 05, 2015 | Nortel Norstar M7208 Telephone
Mirror lock up
Turn it off the green rectangle setting and see if it still does this (for example, turn the mode dial to P instead). If it stops doing that, then the flash up shaft in the top cover is bent. If it still does, then either the phase switch on the bottom of the mirror box needs to be cleaned, the shaft the phase switch gear is on is broken (common) or the shutter has a problem.
Mar 28, 2014 | Canon EOS-50E 35mm SLR Camera
Shutter speed dial just started to change the speed in one direction only this morning no matter which direction I moved the dial. Now I am stuck on "Bulb" setting and the dial makes no change at all
Possibly spillage/water damage/corrosion, or may be bad contact in the wheel assembly itself. Best thing to do is to disassemble the wheel assembly, clean the circuit contacts with a good pen eraser and alcohol (not rubbing alcohol!), and reform and clean the contact brushes
Remove the back and front covers (you have to remove the back and grip and side rubberette), unplug the two flexes from the top cover at back board (be very careful with the flippers on the connector, they are very fragile), remove the top cover (screw holding eyepiece adjustment ring, screw by right strap lug, two silver screws under top cover at right and left sides. Discharge the flash capacitor (caution - may have 300 volts, major shock potential!). (make a discharge tool with a 1K 5 watt resister). You can then reach the wheel to diss-assemble/clean
Oct 04, 2013 | Canon EOS 30D Body Only Digital Camera
Manual for canon eos 50e
The EOS 50 is called the Elan II in some parts of the world. You may download the Elan II manual from http://butkus.org/chinon/canon/canon_eos_elan_ii_iie/canon_eos_elan_ii_iie.htm
Feb 05, 2012 | Canon EOS-50E 35mm SLR Camera
We have one incoming line that we don't want to ring. How do we program the Avaya System to stop ringing when a call comes in on that line?
At ext 10 or 11
press feature 00
LEFT intercom
LEFT intercom
Right intercom
enter extension number to change ringing on
the line buttons will light up if you touch the line it will change the flashing and the ring style.
Once done, press feature 00
Repeat for all phones.
Aug 03, 2011 | Avaya 700340193 Corded Phone
I have a Nikon D70, and a Quantaray lens (28-90mm). I have had this camera for about four months, and it has been working fine with the lens. When I received the camera, the aperture ring moved, but the...
In order for the aperture to be controlled by the camera's program or primary and secondary control knobs, the lens must be set to the smallest opening - or highest number value f stop. The aperture must be operated by the ring if it is not left in the smallest opening position.
The FEE code you are seeing refers to a communication error between the lens and the camera body. Sometimes, simply removing the lens from the body and reseating it to the body will solve the problem. While the lens is off the body, carefully inspect the gold colored contacts on the lens and mating contacts on the camera body. Remove any dirt or debris found, being careful not to allow it to fall into the camera - or land on the back glass of the lens.
I found another explanation and possible remedy that stated:
"A flashing "FEE" is an improperly set aperture ring in 99.9% of all cases with this error message (i.e. user error). In very rare circumstances it can be caused by a damaged aperture ring (small lug broken from back edge) that can't "tell" the camera it is at the minimum position. If the aperture rings on the lens is set to minimum aperture (highest number) and locked there, but you still get a FEE error, it's possible that sloppy tolerances are causing the lens aperture ring to not move the little switch at the 8 o'clock position (on the D70 lens mount) as far as necessary to get a proper indication of minimum aperture. Try to see if the aperture ring (while locked) will move slightly when mounted on the camera to clear the FEE error.
Another remote possibility is that the little switch at the 8 o'clock position mentioned above is not functioning properly (sometimes they get dirty). Try "exercising" it by moving it back and forth with your finger, then try the lenses again. Usually FEE has nothing at all to do with CPU contacts (with a reverse engineered third party lens anything is possible I suppose), but it doesn't hurt to clean them to eliminate that possibility."
You can also try a different Nikon compatible lens. If the trouble is still present, the camera may need to be returned for repair. If the the problem goes away, then the issue is tied to the lens itself. This would mean the the lens needs repair.
I hope this helps and good luck! Please rate my reply - thanks!
Jun 30, 2011 | Quantaray 28-90mm f/3.5-5.6 for Pentax
30D locks up and won't take pictures.
are you taking photos of still or moving subjects? One shot is suitable for still subjects, someone sitting down or still life shots. The camera will balk at you if you are constantly panning or have moving items in the fiewfinder field of the focus points and it is set in one-shot mode.
try changing to AI Servo and see if the problem continues.
Nov 30, 2009 | Canon EOS 30D Body Only Digital Camera
Canon eos 50 flash
According to the manual, if you have the selector set in any of the "creative" modes (P, Av, Tv, M) the built in flash will only work if you press the button to pop up the flash. It also references a "hot shoe cover" which, if inserted into the hot shoe for external flash, will prevent the built in flash from working.
You can download the manual here. (The EOS Elan II is the same as the EOS 50.)
May 27, 2008 | Canon EOS-50E 35mm SLR Camera
Canon EOS-50E 35mm SLR Camera Logo
85 people viewed this question
Top Canon Photography Experts
old marine
old marine
pontelemon
pontelemon
David Payne
David Payne
Are you a Canon Photography Expert? Answer questions, earn points and help others
