Question about Kenmore 15864/15862 Top Load Washer
Kemore waser leaking
My top load kenmore washer is leaking during the filling & rinse cycles.
  • 2 more comments
  • rayduslak Dec 26, 2008
    from the front on the bottom
    Thanks, How do I take the cabinet off or do I not have too?
    Are whirlpool parts compatable to Kenmore?
  • onthethejob1
    onthethejob1 May 11, 2010
    from where the back the side the bottom ????
  • 640 Answers
Center front ,,pump is bad ,,if you need help changing,,post question
Posted on Dec 26, 2008
  • onthethejob1
    onthethejob1 Dec 26, 2008
    yes whirlpool makes kenmore for sears only,,there the same,,i belive you can change pump your self...first unplug unit..now grasp the two end caps on console firmly with your hand and pull each end cover off,,remove the 2 screws on left and right corner,,flip the hole console back..now remove the lid switch connection,,easy so ...now remove the two brass clips ..leave the machine ,,pull the cabnit awaystraght forward...look straight down that beige plastic backward c part rite in front with the 2 hoese coming from it that your pump..remove to clips unsnap and a little twist,,there you go.remove drain hose and tub to pump hose..replace pump..reverse to put together.
Water is leaking onto floor during filling and also during the rinse cycle.
you will have to check the hoses coming from the water inlet solinoids as it sounds as if there is a leak in one of them.
Jul 27, 2011 | Kenmore 23822 Top Load Washer
Front load kenmore washer will not fill on rinse cycle
yes you should have both hot and cold hooked up. if that is not possible splice the line you have and y it into both inlets. thats not the best way to do it but will solve the imediate problem.
Jan 24, 2010 | Kenmore Elite 45986 Front Load Washer
Kenmore series 70 washer leaks during rinse?
the was exhaust hose is either plugged or cracked. also check the drain it is put into as this sometimes will be puleeged with fabric from the clothes you wash
Jul 10, 2009 | Kenmore 22422 Top Load Washer
Kenmore top load washer 110-24642300 is leaking when it fills
tip the unit back and lean against the wall so you can look under it you will see the pump it is plastic. more than likley this is your problem. let me know if you need more assistance
Feb 24, 2009 | Kenmore 22642 Top Load Washer
Pf and of codes comming up on screen
PF - Power Failure - PF error code indicates a power failure during the dryer's cycle. Press and HOLD start to continue the cycle, or press off/pause to clear display.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Feb 11, 2009 | Kenmore 22422 Top Load Washer
Kenmore washer overflows during rinse cycle.
SOME OF THESE MACHINES HAVE TWO PRESSURE SWITCHES IN THEM, ONE FOR THE MAIN WASH WATER LEVEL AND ONE FOR THE RINSE WATER LEVEL. CHECK FOR A PLUGGED AIR PRESSURE HOSE FIRST AND THEN CHECK THE PRESSURE SWITCHES.
Jan 27, 2009 | Kenmore 22422 Top Load Washer
Kenmore top load washer approx. 10 years old
f7686aa.jpgPump is leaking around the drive shaft.
To get to the pump CLICK HERE
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Dec 28, 2008 | Kenmore 24032\24036 Top Load Washer
WASHER LEAKING
DO YOU MEAN THE SPIN RINSE CYCLE OR FILL UP?THE FRONT COMES OFF FROM UNDER THE TOP SEAM,USE A PUTTY KNIFE ON EACH OF THE FRONT SIDES,PUSH IN ON THE CLIP AND PULL OUT ON THE FRONT PANEL,DO THIS ON BOTH FRONT SIDES,LET ME KNOW,THANKS-MIKE
Jun 23, 2008 | GE WBSR3140DW Top Load Washer
Kenore 80 top loading washer leaks
If is leaking at the front of your washer its gonna be the pump
May 04, 2008 | Kenmore 24032\24036 Top Load Washer
Kenmore 15864/15862 Top Load Washer Logo
79 people viewed this question
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
