Question about Mintek DTV-263 26 in. LCD Television
Air Digital No signal on the screen. Cannot change channels
The remote nor tv will change channels.
The screen shows Air Digital TV No signal
the cable box works.
Volume, cause etc work
Charter cable cannot solve it.
  • 63 Answers
Hi my name is mark, since you have a cable box. you need to switch the tv back to the analog signal on the tv through setup or menu screen. then use cable remote to change channals. thanks for your question.
Posted on Mar 14, 2009
Lost signal
You have changed channels and now it's on the air. If your box is providing a signal on the 3rd or 4th channel you have to get back to those.
Aug 29, 2017 | Televison & Video
My remote scanned all the tv channels (Cable TV, TV, DTV and Cable DTV). The channels that do not show up now are the Cable TV channels. They are there if I type in the channel number but the remote...
U are recieving an using DTV Free AIR broadcasting tv signal wright,get a better antena like a roof or a newly design digital antena for uses.This problems dose not happen to cable or sattellite services,i know this because their broadcasting tv signal frequencies are very strong and very high ranges of a broadcasting signal output for their recieving boxes.
May 09, 2011 | LG 42LH40 LCD TV
TV is not responding to remote. While changing channels this morning it stopped working. It will not change channels, sound or shut off. tried 2 other remotes with same results.
What is the make and model of this TV?
LG?
You need some verification first.
Testing remote control:
The remote control puts out IR (InfraRed) signal that human eyes cannot see, to find out if the remote is sending out the signal or not you just point the remote at the digital camera's Lens (Digital Camera can detect IR), you should see flashing light on the camera's screen when any one of the remote button is pushed. If you do see the flashing on the camera, then the problem is in the TV IR receiver or the main logic board; more troubleshooting with scope will be needed to look at the signals.
Parts: www.shopjimmy.com
www.remotes.com
Ebay.
Dec 13, 2010 | Televison & Video
My insignia tv shows a NO DATA BASE error on screen. How do i fix this.
Try these tips:
Connecting your Cable box through Coaxial to the TV.
1- Turn on the TV and the Cable Box, secure all the coaxial connectors.
2- Press the "TV" button to be sure you are in the TV mode.
3- You need to set the TV in a specific channel for receiving the signal from the Cable Box, usually they are channel 3 or 4. Please press in the TV's remote those channels numbers and check if you are receiving signal about the Cable Box in any of them.
4- If you do, afterwards remember to continue using the Cable Box remote to change the channels instead of the TV one.
Connecting your Cable Box through RCA to the TV
1- Turn on the TV and the Cable Box, secure all the RCA wires.
3- Press the "Input" button to go to AV1 or AV2 depending where the Cable box is connected.
4- You should be receiving signal instantaneously after you have changed the Input and keep using the Cable Box remote for changing the channels.
Jun 21, 2010 | Insignia LCDTV26 26 in. Television
TV doesn't respond to the remote control...can't change channels
You have to find out if the remote is sending out the infrared signal to the TV remote receiver or not, you can test that by pointing the remote at the digital camera, you should see flashing light on the camera screen when any one of the remote button is pushed (digital camera can detect infrared light). If get the flashing light then the problem is in the TV remote sensor.
http://s807.photobucket.com/home/budm/allalbums
http://en.wikipedia.org/wiki/Capacitor_plague
http://www.badcaps.net
Jun 15, 2010 | Hisense TL-3220 Television
Digital Visio 42" LCD TV stopped receiving digital TV
Check all your connections in the back, if they're all good replace the main board in the tv.
Aug 22, 2009 | Televison & Video
Digital channel signal blue screen only
Press the "INPUT" button and make sure "TV" is highlighted.
Mar 21, 2009 | Vizio VX20L 20 in. LCD TV
No freaking signal
Double check ALL your ant wire connections. Then reprogram the converter to check for stations again. If that doesn't work then reposition your antenna and reprogram again.
May 21, 2008 | Insignia Digital-to-Analog Converter for...
No signal on digital TV
If you are talking about over the air digital channels I would lean toward ant problems
Apr 26, 2008 | Televison & Video
Digital or Analog>
I believe this tv has a built in digital tuner. To verify this, using your remote attempt to change the channel to say 3-1 or 3.1 if you have a digital tuner this is how a digital channel will show up. Also if you go into your menu under channel scan you should see a choice named dtv. And finally on the back you will have a coax connecter named dtv. The latter is not always true. If it does turn out to be standard format tv, you can still purchase a digital set-top box that will decode digital for you. Keep in mind that you must have a good uhf off air signal in your area to recieve digital signals. Good luck.
Feb 20, 2008 | Televison & Video
Mintek DTV-263 26 in. LCD Television Logo
259 people viewed this question
Top Mintek Televison & Video Experts
Jaime Hernandez
Are you a Mintek Televison and Video Expert? Answer questions, earn points and help others
