Question about Soundstream EGA900D Car Audio Amplifier
I need a bass knob for a soundstream ega amp
Where can i buy a soundstream ega-series amp
  • 39 Answers
Try www.resolutionelectronics.com.au
Posted on Jul 08, 2009
Hi this is amber I have 2x4 ohm qvc audiobahn abass2012P how would I correctly run them to get best bass n max power efficiency I have a soundstream Picasso 1000watt 4 channel bridge able amp to hook em up...
I assume you are replacing the built-in Audiobahn power amplifier with your 4 channel Soundstream amp. If so, you can set the Soundstream for bridge mode which should net you 2 high power channels of 250Wrms@4ohms or 500Wrms total power (if the speakers are quad VC), or alternatively, non bridged for 4x125Wrms (if the speakers are dual VC). You can see why below.
Next, you need to confirm each subwoofers coil configuration as follows: If each woofer is quad, there will be 8 connectors; if dual VC, then there will be 4 connectors. For dual VC, if each VC is 4ohm, you can choose between 8 or 2 ohms by series or parallel wiring. If each VC is 2 ohm, you can have 4 ohms in series to use. This can be determined with an ohm meter across one set of VC terminals. If you can get 4 ohm for each speaker, this will allow you to use the 2 channel bridged mode with each speaker getting the full 250W. If each VC is 2 ohm, use non bridged mode and run each of the 4 channels to each VC. For this case, use a 2 to 1 RCA jack to sum the two channels for each speaker on the amp's input side to make the signal 2 channel instead of 4 channel. Below are examples of quad and dual VC for reference only, the wiring may not match your setup which will depend on your VC resistance (impedance) measurement. Don't forget to set your HPF(High Pass Filter) as this is a subwoofer setup.
Nov 17, 2017 | Car Audio & Video
Need bass nobb for my amp
need a remote and quote fora bass knob remote Alpha series quantum amplifier QA3000D Mono Amp.
Nov 09, 2012 | Quantum Alpha Series Qa3000d 3000w 1 Ohm...
I have just bought a soundstream pca1000d amp from.my friend but he did not have the remote bass nob so I was wondering where I could get it from
the bas control nob is just a grimack end a waste of money,You don,t need it because all the decks in the last 8 years have,Sub level control on them, Where you can adjust the level of bas from the (Deck) All your asking for to happen, Buy all so useing the bas control for the amp, Is to (Blow) Your (Subs) End fry your amp, When you use both of them for controling the bass, You are causeing the sub end the amp to over heat, I installed car audio for over 40 years , before i retired this summer, End seen lots of amps end subs that were damage, Buy guys haveing them hookup all so,End anouther thing that damage subs end amps, When they have the grain control on the amp crank right up.
Nov 07, 2012 | Car Audio & Video
Amplifiers GT Series GT5-A604 ........explain settings
the amp probably has a x-over knob, a bass boost knob, and an eq knob. the eq is probably an internal crossover switch that will take the output from either high range (tweeters) or full range (6x9s) or low pass (subs) leave it on low pass. the bass boost however, will add distortion if turned up too high. its not noticable in the car, actually it sounds louder in the car but if you open the trunk and listen, you can tell its distorted bass and actually frying your speakers. the x-over knob is used to tune the frequency at which the amp stops pushing out bass tones. if you like rock music loud, turn it up higher, if you like low deep rap bass, turn it lower. keeping it too high might give you bad sound from either type though. ALSO THE GAIN OR LEVEL.IT IS NOT TO MAKE YOUR SUBS LOUDER IT WILL BLOW THEM .the gain is used to set your amp to your head unit which there is a procedure to do it.
Jun 15, 2009 | JBL GT5A604E 4-way Car Amplifier
I need a bass knob for my crunch amp
i need an bass knob for an planet audio rxd2400
Mar 01, 2009 | Hifonics TX1505D Car Audio Amplifier
AMP shuts off
your problem could be in the fact that you are trying to overdrive the amp. sony will not carry a 1 ohm stable load and if your speaker are 4 ohm speakers wired in series then you cant drive the bass your looking for. try using soundstream tarantula amp or new hifonics block mono class d amp with about 1000 watts rms. what kicker subs do you have? that will also make the difference in amp choice. im running tarantula on 4 polk momo 4 ohm 12's and has broke my back glass in my jeep twice one time was for a show. oh well let me know. happy boom boom. i'll be glad to help
Feb 28, 2009 | Sony Car Audio & Video
Soundstream rub 500-1 mono....
U need to make sure your subs are wired correctly. And u need to make sure all your speakers are at the same ohm load. If u hook up two subs on one channel and two more on the other one u need to make sure that your subs are all 2ohm or 4ohm subs cause if u got two 4ohm subs ran parrallel then u will have a 2ohm setting and if both of them are 2ohm subs them your load will be a 1ohm load witch could harm your amp unless its an 1ohm stable amplifier.
Nov 21, 2008 | Soundstream RUB500-1 Car Audio Amplifier
Wired bass control knob
Not all controls are the same. Manufacturers use various schemes to control the level of the audio. If you use a control that's wired improperly, you risk damaging your amp.
Apr 16, 2008 | Sony XM-754HX Car Audio Amplifier
My Kenwood KAC-X1R hooked up to (2) Kicker Solobaric L5's
first get a deck with 4 volt pre outputs or more that will help a lot then a battery in the back will help like a 1000cca or more
Dec 30, 2007 | Kenwood KAC-X1R Car Audio Amplifier
Soundstream EGA900D Car Audio Amplifier Logo
215 people viewed this question
Top Soundstream Car Audio & Video Experts
richie46
ray gallant
Are you a Soundstream Car Audio and Video Expert? Answer questions, earn points and help others
