Can't seem to get the audio working from pc to 67" samsung dlp.Using a 15 pin vga cable from pc to tv,picture is great and a 3.5mm audio cable from audio jack on pc to right input on tv as shown in manual.can't get sound to work.it is a newer acer laptop,windows vista,sound works on pc,and plugged in headphone jack that also works.i don't have a dvi connection on pc,should i use the other configuration in manual,the 2 rc's to a 3.5 audio and purchase a 15 pin vga to dvi connector and hook into the hdmi/dvi connection on tv. thanks gary
  • 4 more comments
  • master_angle Dec 26, 2008
    tried numerous times lowering and also raising volumes on pc and tv to no avail
  • master_angle Dec 27, 2008
    thanks for the comments.The tv model is a HL67A750A1F.I tried using the 2 rc"S to the 1 3.5 audio in pc[there is a connection on tv side panel that reads dvi audio] with no luck.According to the manual you need to use the hdmi/dvi hooh up also.Like posted before the only way i can configuire this is if i purchase a dvi to a vga adapator since i don't have a dvi hook up on lap top.
  • master_angle Dec 28, 2008
    i will be going to the city Monday ,will buy the vga to dvi connector,will let you guys know if this works tomorrow nite.
  • master_angle Dec 30, 2008
    Well i think that i just give up. Took the 1.5 hour trip to the city,went to pc store and bought the vga to dvi adaptor.Hooked the hdmi/dvi end into the right port of the tv.Hooked the dvi to vga adaptor into laptop and with this setup i have no picture and no sound.Checked all connections seems good.The hdmi cord came with the high def receiver that i bought from Bell.The screen says searching for signal and then says no signal found.I used the right input on tv hdmi/dvi.At least when i used the vga to vga [to tv] i had a picture and no sound.I have one last idea,can i hook up the audio to my sterio inputs {aux input] and get the sound that way and watch the picture through my vga to vga hookup.Gary
    just wondering if more help out there
  • master_angle Jan 01, 2009
    Well i guess i solved this one on my own.Went to PC store and bought a multilplier,where i can plug in more rc cables to my stereo receiver[it was full and had no more room for inputs].Now i have beautiful pictures using the vga to vga cable and great sound from my laptop 3.5 mm to double rcs.So what did i learn 1. the pc audio inputs [both of them dvi] don't work on my tv.2.If your pc doesn't have a hdmi output, buying the vga to dvi adaptor also doesn't work,couldn't get a picture.Again the 2 figurerations shown in the samsung manual to get audio out of your pc are bogus for my unit.
  • 395 Answers
You would need to use 2 rc's to a 3.5 audio for sound and purchase a 15 pin vga to dvi connector and hook into the hdmi/dvi connection on tv,
Posted on Dec 30, 2008
    Genius:
  • 1,239 Answers
Hi
Check speaker terminal connections, then source input, then surround mode choice
Posted on Dec 27, 2008
  • ABHISHEK.C
    ABHISHEK.C Dec 27, 2008
    it may be an internal fuse which is see through be aware that you put in the same rating fuse if you need to replace them.if it has a message auto protect so it get no sound  remove the message and get sound
  • ABHISHEK.C
  • 916 Answers
The vga cable will only allow you to connect the pc screen to your samsung not to the audio in order to get the audio you try using your HDMI connection which will transfer sounds as well as video.
  • 758 Answers
The vga cable will allow you to connect the pc screen to your samsung..not the audio..in order to get the audio you can use your HDMI connection which will transfver sounds and pictures...You hould use the other configuration in manual,the 2 rc's to a 3.5 audio and purchase a 15 pin vga to dvi connector and hook into the hdmi/dvi connection on tv.
Hope that helps
Computerrep
Posted on Dec 26, 2008
    Brigadier General:
  • 6,966 Answers
Hi and welcome to FixYa,
Offhand, no problem with the video that you mentioned hence the VGA connection should do. On the audio side, try using 2 RCAs to 3.5 instead of the 3.5 to 3.5. Depending on the model of the Samsung DLP, the audio is normally synchronized to the video source selection. Perhaps it would be to your advantage to postback the exact model number of the Samsung to determine the video/audio pairing.
Good luck and Thank you for using FixYa. Happy Holidays.
  • Louie  Role
    Louie Role Dec 27, 2008
    I guess you are right since the option(s) are rather limited to what is available as Video out on the laptop.
    Cheers.
  • Louie  Role
    Louie Role Dec 30, 2008
    and I was about to suggest split the audio and video. Hook the video whichever way the Samsung HL67A750A1F will perform best and the audio to a home theater system.
    Hey, its not a workaround, it might prove to be better.
  • 10,594 Answers
Lower the volume bar in laptop, near to minimum then increase volume of TV.
If still no joy, unplug tv for couple of minutes, replug and power it again.
  • 2 more comments
  • Shahid Electronics
    Shahid Electronics Dec 26, 2008
    OK, unplug audio wire from laptop and touch it, do you hear any hummmm or static noise from TV speakers?
    Please increase TV volume up to 50-60% for this check.
    Thanks
    Shahid Electronics Dec 28, 2008
    Issue is no sound,
    VGA to DVI connector is unnecessary, in my opinion because "Picture is great" and HDMI to DVI will give video only in TV.
    Shahid Electronics Dec 30, 2008
    If your TV has another HDMI input, try it and put audio in related input in TV.
    master angle,
    do you see my messages?
How do I change source resolution on my TV?
connecting PC to Tv through VGA - Tom's Guide
www.tomsguide.com/answers/id-1891563/connecting-vga.html
Nov 20, 2013 - Q: Can I connect the TV to the PC via a VGA cable...bearing in mind the .... Forum; SolvedI'm trying to connect my Sony bluray player home ...
Connecting my Plasma to my PC via the VGA port. - Forums - CNET
www.cnet.com > Forums > Samsung
CNETJun 11, 2015 - Ensure that the VGA cable is working properly using other methods. Perhaps .... I am trying to connect my pc with my samsung tv. .... I'm very sorry to hear that has happened, and I apologize for any inconvenience this may have caused you. Connection between Dell laptop and Samsung TV
Jun 11, 2015
How to connect computer to tv with sound and picture?
Jun 5, 2015
PC Audio won't play through connected Samsung LCD TV
Jun 4, 2015
Connecting computer to TV
Jan 18, 2008
More results from www.cnet.com
My custom built PC will not connect to my TV via VGA cable ...
www.tomshardware.com > Forum > Graphics Cards
Tom's Hardware Guide
Jun 28, 2013 - 5 posts - ‎2 authors
Jan 31, 2016 | VIA Computers & Internet
Samsung LN-T4671F HDMI PC hookup and Audio Problems
Pls bear with me, have you tried not using the HDMI/DVI cable but simple straight connection PC > Standard 15 pin VGA cable and audio cable that has "stereo mini-plug" on both ends to the PC IN of the Samsung?
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards. Thank you for using FixYa.
Aug 09, 2008 | Samsung LN-T4671F 46 in. LCD Television
Can't figure out how to connect pc to video component to my Acer laptop
You shouldn't be using video component cables, instead you should be using a VGA cable and a 1/8". stereo audio cable. Your laptop and your TV should have a VGA port; it is D-shaped and has 15 pins over 3 rows. Next to your TV's VGA port should be an audio jack that you can hook up to your laptop's headphone jack. The cables be be bought at Radio Shack or any decent electronics/computer store.
Jul 19, 2011 | Televison & Video
How do I connect a PC to a LG50PG20 50" HDTV Plama?
You need a VGA cable (15 pin) connected from PC (monitor out) to the PC input on the HDTV (15 pin) this is for the video. For the audio, connect from PC to HDTV, audio cable, either 3.5mm from earphone out on PC to HDTV 3.5mm audio input (next to PC VGA input) and also be sure to set PC screen resolution to compatible output for HDTV like 1024 X 768 or 600 x 800 etc.
Select the PC input on the HDTV using TV remote.
Hope this helps.
Mar 06, 2011 | LG 50PG20 50 in. Plasma HDTV
I am unable to connect my IBM Think Pad Laptop to samsung 37lcd
you should be configure the display option , as extended monitor (2nd) output ,
Feb 24, 2009 | InFocus VGA Cable - 15 pin male-male, 4...
Connecting Laptop to LCD
the following connections available to connect ur computer to an TV:
S-Video output: If you have video card(external u will have this), you require an s-video cable and you connect s-video out of your computer to the s-video int of our TV.
TV-OUT: if you have video card(external u wil have this) you you require an coxial cable and you have to connect TV-out of your computer to TV-IN of our TV(it is place where cable connection goes from your cable operator)
DVI-D: if you have video card(external u will have this) you require an DVI-D cable you haveto connect DVI-D out of your computer(a white 15-pin port which looks like VGA port) ....
VGA: it is the port on your computer which is only used to connect to your computer but not to your TV or LCD(strictly)
Thanking you,
M. Sridhar
Dec 29, 2008 | Gateway GM5442 PC Desktop
HOW TO CONNECT SAMSUNG LCD TV TO ACER ASPIRE
Atlast I got some help from the right people (Samsung)! I would like to share it with others facing the same problem:
If you are using the D-sub 15 pin jack (VGA Monitor Cable: make sure its 15 pin and NOT 14 pins), follow these steps:
  1. Make sure your TV and computer are off.
  2. Using a 15 pin D-sub (standard) video cable, connect the Video Out jack on your computer's video card to the PC In jack on the back of your TV.
  3. Using an audio cable with a min-stereo plug on one end and two RCA jacks on the other, connect the Audio Out jack on your computer to the left and right PC Audio In jacks on your TV. (Note: If you have your computer connected to separate speakers, you can skip this step)
  4. Switch on the Notebook and Adjust the Resolution (800 x 600 pixels would do). You can go to Control Panel and Adjust the screen resolution. (Keep ‘Screen Refresh rate’ at 60hz in the Monitor Settings)
  5. Switch on the TV and try to Select the Source as 'PC' (you can do this by either pressing the 'Source' button several times on your TV remote or go to the Menu - Setup and Select the 'PC' as source there).
  6. In most cases, after following the above steps, the TV would start to show 'Auto Adjusting' message and it will start showing your Desk top on the TV. But incase it doesn't work, you can do the following:
a. Mostly the problem lies with the VGA cable. Make sure you have the right one (15 pin) and its securely attached at both ends. If you are not using the right VGA Cable, it means that there is no connection between your TV and Notebook. Your TV will show 'PC' in Grey in the Source Input list (Go to ‘Menu’ from the TV remote).
b. Both your Notebook and TV should be switched off when you are connecting the cable otherwise one of them might have a problem detecting the other one.
c. Try Pressing Fn + F5, F6, F7 (depends on which Notebook brand you are using) on your Notebook several times. At times, you will see some signs that the Notebook and TV are trying to connect. Select 'CRT' from list of displays available to you.
May 09, 2008 | Televison & Video
Samsung LCD TV not receiving PC signal
Check your vga cable. Some cables have only 14 pins, some have all 15. The missing pin is pin 9, in the 15 pin cable it carries 5v from the graphics card to the screen. Without that 5v signal most LCD and Plasma television screens won't recognise a PC input. I had the same problem and only managed to fix it when my girlfriend swapped a cable over for me and as she did so glanced inside and said "it's got a bit missing" The cable that came with your PC most likely only has 14 ins as that is all a monitor screen needs.
You can buy a 15 pin cable at most PC or electronic shops, just check that isdoes have all 15 pins befiore you buy it. The cheap ones are just as good as the expensive ones unless you are buying 20 foot cable. For 6 foot cable the cheap ones are just as good as the expensive ones.
Mar 08, 2008 | Televison & Video
43 people viewed this question
 Grubhead
Grubhead
