Question about Toshiba CF27H50 TV
Set needs to be slapped to get a picture
When I first turn on the set there is no picture until I tap or slap the top or side. The picture might then start fuzzy with no color and another slap will usually bring it around. Once the set has warmed up there is usually no more problem. I can't just keep slapping it. I'm sure that will cause even more problems eventually. I feel like I'm adding insult to injury!
  • 4 Answers
Initially the transformer is generating the heat to the surrounding before it can get heated up. Its not that the TV need's a slap, its because of improper contact, have a technician check the transformers contact. I had the same problem for my sony tv and it was due to this only.
Posted on Apr 19, 2007
There is obviously a dry joint or alternatively line out put transformer needs a technicians touch sorry
    President:
  • 1,284 Answers
TV's need a good slap once in a while to set them right! Just kidding. Sounds like you have a bad connection that once the set is warm it mends itself. Have a technician look at it.
Engine got a knocking cold start, silint when hot
It has developed a clicking engine noise on a cold start. After the car has warmed up, the sound goes away. ... Clicking or a sharp tapping from the valve cover on top of the engine would point to a valve train noise. A dull tapping or slapping sound from the side of the engine block would point more toward piston slap.4 Nov 2011
Cold-start engine clicking is a nuisance, not a disaster - StarTribune.com
Dec 13, 2016 | Cars & Trucks
Engine starts and idles but has a loud slapping noise.No smoking from exhaust has good oil pressure any help or suggestions what it might be and approximate cost of repair.Thanks
Hi Mike:
What kind of bike and how old? Vintage Harleys sound like that most of the time. Just kidding all you Harley guys & gals!
Mike, can you tell where the sound is coming from, and most important, what happened immediately before this noise started?
If it was from the engine, I would not run it until I had it figured out.
Mar 20, 2015 | Motorcycles
Tapping noise
rocker arms need adjusted gap is too wide . the increased rpms make it noisy. stp would muffle it but it needs the gap set cause if you really rev it hard something up top can let go from the slapping of the rocker arms on top of your valves
Nov 07, 2013 | 2006 Mazda 3
Freezes food, adjusting thermostat does not help, a slap on the control seems to fix the problem for a day or two. model msd2542v
The thermostat's contacts are sticking and needs replacement. By slapping the side you are opening the thermostat contacts until the stick again.
Jun 21, 2010 | Maytag MZD2766GES Side by Side...
Blinking red light at power button if you slap the set it will come on but any movement will turn the picture off and the blinking light back on
this is a dry canaction problum in pcb do not slap tv.
* cont. tv tech. nr. at your home solve this problum in fuw mint. it is not expanciv but. if you slap tv then posibal spear damage in inside tv.set.and he is very expanciv.
Oct 31, 2009 | Toshiba 36A50 36" TV
CLICKING NOISE IN THE ENGINE AREA
Nope. This is an Exhaust Leak. You need to replace the Exhaust Manifold Gaskets.
Jan 10, 2009 | 2002 Chevrolet Silverado 1500
Mitsubishi TV
Hi jmvca:
Most likely the tuner is starting to fail. When it is first turned on, tap or slap the side of the cabinet to see if it makes any difference.
The set will have to be repaired in a shop when it goes out completely.
Feb 22, 2008 | Televison & Video
Rca tv with remote control.
While the set is playing tap or slap the side of the cabinet, to see if the picture flickers or goes off. (This is a deep dark secret technique of expert technicians :) )
If it does then you have an intermittent connection in the electronics, which will have to be repaired at a service shop.
Feb 19, 2008 | Televison & Video
Door will not open on dvd player
Is there a "lock mechanism" that will need to be undone?....accordianman
Jan 19, 2008 | TruTech TT320
Televison & Video Logo
101 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
