Question about Yamaha TSS-1 Computer Speakers
None of my computer outputs are working
None of my computer outputs are functioning. Much like this proble here: http://www.d-a-l.com/help/general-hardware-issues/6844-computer-output-problem-serious.html symptoms are exactly the same, however solution does not work.
I turned computer off, fitted my new ram, that didnt work with the computer so i turned it off and put old ram back in. Now none of the outputs work, any ideas?
  • duncan_lewis Dec 27, 2008
    thanks,
    i sorted this problem but now i have a major one lol.
    i will post it, but i dont think it is in your field.
    Scholar:
  • 67 Answers
If your computer is bang up-to-date with all Windows/Linux system updates and Drivers for your set-up, it sounds like your Sound Card has had a terminal fault. I would try a newly purchased card, so as to be sure the outputs are functioning.
Posted on Dec 27, 2008
2 Suggested Answers
jasonamoss
  • 77 Answers
SOURCE: None of my computer outputs
The first thing you can try is reset the CMOS and see if that helps. Sometimes you cause BIOS issues when changing RAM
Posted on Jan 14, 2010
Our projector shows a blue background and does not seem to be connecting to the computer
Several things to check.
Make sure both the input selection on the projector is for PC and make sure the PC output selection is for the external output, as in an external monitor. The PC does not care or need to know that the external output is a monitor or projector.
If none of these works, try a different cable and output on both the laptop and projector ie, Switch from PC output to a DVI or HDMI.
Nov 22, 2014 | ASK Proxima Office Equipment & Supplies
I just installed a Acer S211HL LCD monitor. All my connections are tight. I get a No Signal on screen and monitor goes off. what the proble?
If you get a no signal message then check your video card, if the monitor gets no power at all then try replacing the cable, try a different outlet, if none of those work then the monitor is defective.
Mar 04, 2011 | Acer Computers & Internet
Function key plus number pad doesnt work. numpad is supposed to be fn key plus the four rows of 7890 uiop jkl; m,./ if NumLock is off, the +-*/ work, but not the numbers. the numbers behave as...
A numpad usually outputs the cursor movements with the shift bar depressed. That suggests to me that you need to turn of the Caps lock key, or otherwise make a change to the keyboard setup. Maybe there's a Fn key combo that needs to be toggled.
Oct 15, 2017 | ASUS 90-A4C1K1000 Keyboard
One Connector not working on Durabrand SA-SP9 Surround Sound
you have to test electrical out put, maybe loose wire inside or blown component
Jul 06, 2009 | Durabrand 5.1 Surround Sound Computer...
Samsung 204B random blank screen
I too have a dual monitor Samsung SyncMaster 204 setup. My monitors started flickering, then a week later had turn on problems like your describe. I found a fix on this fixya website and followed the fairly techie suggestion. It worked. I wrote up a .pdf set of instructions so others might also benefit. Hope this helps. Doug
Feb 07, 2009 | Samsung SyncMaster 204B 20.1" LCD Monitor
PROBLE
your computer need to reformat your operating system is Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} Corrupted........
Sep 20, 2008 | HP Computers & Internet
Jawa void
you should not use arguments in void function in java ... in java pertaining to void the compiler doesn't understand the arguments and treats that as invalid... in c it is ok
Aug 07, 2008 | Sun Java Studio Standard 5 (SSJI9501TL9M)...
No sound
try to reinstall the driver, if still not work maybe your builtin speaker is defective, or maybe you should try the earphone look for the audio output, if it's functioning then your builtin speaker is deffective..
hope it will help, thanks.
May 28, 2008 | Toshiba Satellite U205 Notebook
Yamaha TSS-1 Computer Speakers Logo
190 people viewed this question
Top Yamaha Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Yamaha Audio Player and Recorder Expert? Answer questions, earn points and help others
