Question about Samsung HLP4663W 46" Rear Projection HDTV
Samsung HLP4663W 46 in. fan noise when shutting off.
The TV works just fine, things turn on, and run just as if it were brand new. Now when you turn the TV off it sounds like something is rubbing up against a fan (which i have no clue). Is this the fan or color wheel? I have read other posts where people describe the wheel failing as a "squeel". This is more of a grind. Thoughts? How many fans does the TV have? I have seen 2 back by the lamp but I don't think it is either of those.
Thanks in advance.
T
Had the same thing . . . had to have the lamp and fan replaced . . . all one unit. Tech person changed both units.
Posted on Feb 24, 2009
    Champion:
  • 217 Answers
It is definately the color wheel, unplug it and don't turn it back on
Posted on Dec 26, 2008
How do I fix loud humming noise in my DLP HLP4663W 42 IN Samsung TV?
I would start by checking all the cooling fans to see if one is dirty or possibly failing.
Aug 30, 2015 | Samsung HLP4663W 46-Inch Widescreen DLP...
I have just inherited a samsung HLP4663W, It had a color wheel that was making noise. I have replaced the color wheel. Now I am getting a fan speed warning. it will come on but shut off after approximatley...
You have 4 different fans inside of your TV. The biggest challenge - to pinpoint which one is bad. I would recommend just to get 'em all and replace 'em all. They will start fail one after another anyway.
Mar 10, 2010 | Samsung HLP4663W 46" Rear Projection HDTV
TV made humming noise for past few months and after it warmed up the humming would go away. It that same thing today and a pop noise came and the screen will not come on, and the tv shuts off and then...
i took off the back and pulled out the the fan. Then put in a fat screw between a slight gap whick kept the fan from hitting what ever is causing the noise. probably not safe but nothing bad happened yet.
Apr 17, 2009 | Samsung HLP4663W 46" Rear Projection HDTV
Humming noise from tv
Yes a humming noise on that model is usually related to the color wheel It will get progressively louder
Jan 17, 2009 | Samsung HLP4663W 46" Rear Projection HDTV
TV on/off
How long is your TV on before it turns off? Check the fans and make sure they are all working. The TV may be shutting off due to overheating if a fan quit working.
If you think the lamp is still good maybe try replacing the lamp ballast.
Jan 16, 2009 | Samsung HLP4663W 46" Rear Projection HDTV
Sporadic Hum on HLP4663W
I would guess that its the fan for the lamp, as the color wheel will power down as soon as the power is cut. the cooling fans will continue to run
Jun 12, 2008 | Samsung HLP4663W 46" Rear Projection HDTV
you may have several problems but the one I know for sure is the fan noise you hear is not the fan but the color wheel, the barring is screeching. you may need a lamp as well. if you are not a tech DONOT ATTEMPT THIS REPAIR leave this to the pros.
Dec 25, 2007 | Samsung HLP4663W 46" Rear Projection HDTV
Samsung HLP4663W 46" Rear Projection HDTV Logo
192 people viewed this question
Jerry Greenberg
Jerry Greenberg
