Question about Frigidaire GLTF1670A Front Load Washer
Frigidare Washer Drum making noise when in spin
I have a frigidaire Gallery Model GLTR1670ASO Serial # XC319975 which has been the greatest over the years exception of now the washer drum is making a clunking noise when turns in spin and also when ever it spins in any cycle but different clunking. Could it be the bearings, could you give me info and or print on how to fix this myself if I can get the parts locally. Thank you
  • 179 Answers
It is your bearings you need to replace both tubs and the basket but it will be cheaper and easier to buy a new machine to rebuild your washer it a pain in the **** because you need to take the whole machine apart. if you do decide to rebuild it make sure that you have someone else there to help the tub is bulky and has some weight to it
Posted on Dec 26, 2008
Hard bang on spin with my frigidaire gallery frontload washer
When my washer did that, I found that the shocks that hold the tub were bad...
Check out this tip I wrote about that...
http://www.fixya.com/support/r3663122-washer_problems_washer_noise_when
heatman101
Apr 15, 2010 | Frigidaire GLTF1040A Front Load Washer
My washer makes a loud noise in the spin cycle. It's a Frigidaire Gallery Washer Model 417.39012890. Any idea how expensive the repair will be?
In my experience with 417 Frigidaires is that when there is a noise in the spin cycle as you describe the drum bearing is failing. This is a very expensive repair that that when I looked up labor and parts could exceed 600 smakeroos.
Feb 14, 2010 | Frigidaire ATF6000ES Front Load Washer
Spin cycle is making loud clunky noise to a frightening degree. Frigidaire Gallery Washer.
The drum inner bearing which holds the drum unit will be damaged kindly replace the bearing along with the washer to get rid of noise
Dec 30, 2009 | Frigidaire ATF6000ES Front Load Washer
My model #gltr1670aso makes loud noises during spin cycle
Usually this is due to either the drum support breaking or the back bearing being bad-neither easy to fix- or worth it. Try lifting the drum up and down, if it moves up and down they are bad. I see this a lot, and the price of repair isn't worth it. Craig
Aug 02, 2009 | Frigidaire ATF6000ES Front Load Washer
FWT445GES1 Washer makes loud banging noises like it's going to explode.
Washer- you need a complete tub and bearring kit. this is a common problem for people who have well water. (also just happens) the rear yoke has become corroded and broken. its a costly repair.
dryer - you would need a new front slider seal. very simple to install.
May 28, 2009 | Frigidaire GLTF2940E Gallery 3.5 Cu. Ft....
During spin cycle started making loud noise now drum feels loose DURING SPIN CYCLE DRUM SOUNDS AS IF IT'S HITTING SIDE.. FEELS LOOSE WHEN I PUSH IT AROUND FRIGIDARE GLTF1040ASO
ckd your warranty papers sounds like rear drum support(spider) has broken will require new basket and rear drum half est cost 400-600 spider is not a separate part and rear bearing is probably damaged that too is not a separate part and require rear tub replacement
May 20, 2008 | Frigidaire GLTF1670A Front Load Washer
Drum makes loud noise when spinning
HI thanks for the question. Frigidaire has a life time warranty. on that part .call them. thanks the appliance doc. please rate my answer. thanks.
Apr 29, 2008 | Frigidaire ATF6000ES Front Load Washer
Will not extract on spin cycle
After oheming motor control board as stated in the service manual. Tracing the 6 pin lead wires from the control board to the motor plug. I found that one of the pin on motor plug was not making proper connection. I used a screw driver to pry the pin open so it made a better connection. Tried the washer and so far it has been working 7 washes.
Mar 27, 2008 | Frigidaire GLTF1670A Front Load Washer
Frigidaire GLTF1670A Front Load Washer Logo
555 people viewed this question
Top Frigidaire Washing Machines Experts
Archie Ferrarini
Archie Ferrarini
Jason Harris
Jason Harris
Sal De
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
