Question about Apple iPod nano
Are the ipods supposed to pause when the earphone jack moves slightly?
  • dinh nguyeb
    dinh nguyeb Dec 26, 2008
    yeah i tried two different aux. cords, mine and my brothers but same thing, then i used my earphones to see if it would pause if i slightly moved it and it paused. i gave my brother the ipod to bring it into the apple store to see what they could do, im just waiting on the response
    Problem Solver:
  • 6 Answers
No, but they do pause when they detect that the headphone has been disconnected. If it's only moving slightly, something's wrong with the headphones or the ipod. Try another set of headphones.
Posted on Dec 26, 2008
The earphone jack connection produces sound in only one ear. Partially with drawing the jack produces sound in both ears. Clearly, the jack is not making a good connection once inside its 'port'.
This is usually the result of faulty earphones. Try replacing the earphones you are using with the ipod and it should work normally.
Good Luck!
Jan 13, 2011 | Apple iPod nano
What cord do you need to plug the ipod into the karaoke machine
This depends on the karaoke machine in question. Mostly the Ipod accepts a 3mm earphone jack and the karaoke is supposed to support the regular av in 2 pin jack. so all you need to do is get the single 3mm headphone jack to 2 pin av in jack. that should work perfectly.
Hope this solution has been helpful?
Dec 29, 2010 | GPX Karaoke Party Machine
Hi i have a 1st gen 16gb ipod touch. When i insert the earphones into the socket i either get no sound, very poor quality sound, or ok quality sound which disapears when i move. i think this is because of...
Some devices such as yours have a 4 conductor jack, (used for earphones and microphone) and most earphones have a 3 conductor plug. They are not compatible. This would be my first guess. Second is earphones and earbuds get tossed around, put into pockets, etc. The cords can get damaged, and not be visible from the outside as the wires inside are very delicate. I would try a set that works in a different device.
Dec 02, 2017 | Apple iPod touch 1st Generation (8 GB) MP3...
Is the earphone jack supposed to be VERY loose?
Unfortunately it sounds like you got a bad model. You'll need to return it for a replacement or repair work.
Jan 26, 2010 | Apple iPod nano
My ipod touch plays the music, but the lyrics are distorted. Tried different earphones, but it's still the same. If I move the plug a bit, it sometimes clears up.
Sounds like a bad headphone jack. Contact Apple at 1-800-275-2273 (1-800-APL-CARE) if it's under warranty. If not, find an iPod repair company to see if they can re-solder the headphone jack.
-=/ MLF /=-
Oct 21, 2009 | Apple iPod touch
My itouch earphone jack creates static in earphones.
sounds like the typical ipod and ipod touch common situation. It seems to be the dreaded headphone jack on the bottom or top of the device has gone belly up. You can either take it to your local apple store or look online and search your problem and see if anyone else has the same issues you have and see what can be done.You can send it to ipodsquad.com to get repairs or check your local apple store.
Oct 12, 2009 | Apple iPod touch
Apple ipod mini 6GB earphone jack not working
The earphone jack is connected to the logic board, open up your ipod mini and see about replacing the logic board with one from ebay. Easy to do, just be careful.
May 05, 2009 | BoxWave Corporation Apple iPod mini (6GB)...
Ipod cuts out when played through speaker system
i have somewhat of a similar problem with my ipod Touch and my JBL docking station alarm clock thingy. It may just be that the ipod is not compatible on some of the levels that the Igroove is. With my docking station, it wont charge my ipod touch itll only play music
Apr 11, 2009 | Apple iPod nano
Ipod pauses itself
it will always pause when you plug it into another device. there is nothing wrong with the iPod
Dec 26, 2008 | Apple iPod nano
IPod Not Working
Does your iPod come on? If not, your battery could be bad.
If you can see the music playing, but cannot hear anything, you could have a bad earphone jack or a bad circuit board.
You can tell if it is the battery the iPod will not come on at all unless it is attached to the computer or to a power outlet.
If you can move the earphone jack around while playing music and hear something, then it is the headphone jack. If you move the jack around and hear nothing, then I would suspect the circuit board.
If you have a device that can play your music out of the USB port on the iPod, you can make sure that it is the circuit board that way. When the circuit board is bad, music will not play out of the headphone jack or the USB port.
Hope that helps.
Dec 09, 2008 | Apple iPod MA446LL/A MP3 Player
Apple iPod nano Logo
32 people viewed this question
Top Apple Audio Players & Recorders Experts
Nagendra Baliga
Parshiv Luthra
Mohamed Ismail
Mohamed Ismail
Are you an Apple Audio Player and Recorder Expert? Answer questions, earn points and help others
