Question about Mitsubishi WD-52725 52". Rear Projection HDTV
WD52725 not coming on
Changed lamp now red status light blinks .. troubleshooter at dlplampsguide says problem is fan not detected .. Is threre a common problem this TV has with that ?
  • 179 Answers
It is not a common problem with this set. are you able to tell the pattern of the blinks.? is it (a)1 long 1 short, or (b) 1 long 2 short, or (c) 1 long 3 short. this will let you know which fan is blocked or has failed.a=Chassis Fan (above chassis) b=Ballast or Exhaust Fan
. exhaust fan is easy to see. ballast fan is hidden between ballast and vent tunnel.c= lamp fan, this is under the lamp. you can measure the yellow wire voltage on the suspected fan, if it is more then 1 volt the fan is bad or jammedlet me know whic one and i will post the part number
Posted on Jan 07, 2009
My 73" mitsubishi dlp WD-73827 turns off and has a red status light blinking. I have replaced the bulb and the heat sensor... any answer to what else could be the problem?
It is helpful to have the sequence of the blinking red light. This may help:
MODELS: WD-52627 / 52628 / 62627 / 62628 / 62827 / 62927 / 73727 / 73827 / 73927
Page 43
3. Error Code Operational Check
Note: The TV must be in "Shut Down" and not have been switched Off, to perform the Error Code Operational
Check. When the TV is switched Off, the code automatically resets to "12" No Error.
Pressing the front panel "DEVICE" and "MENU" buttons at the same time, and holding for 5 seconds,
activates the Error Code Mode. The LED flashes denoting a two digit Error Code, or indicating no problem
has occured since the last Initalization.
Note: The front panel buttons must be used, NOT those on the Remote Control.
• The number of flashes indicates the value of the MSD (tens digit) of the Error Code.
• The flashing then pauses for approximately 1/2 second.
• The LED then flashes indicating the value of the LSD (ones digit) of the Error Code.
• The Error Code is repeated a total of 5 times.
Example: If the Error Code is "23", the LED will flash two times, pause, and then flash three times.
4. Error Codes
The Error Code designations indicating malfunction, or no malfunction, are listed below:
POWER
LED
STATUS
LED
LAMP
LED
Power
Status Condition
Off Yellow Off Low
Power Excess heat. Check Lamp Filter
Off or On Off Yellow No
change
120w usage time over 7000 Hrs.
150W usage time over 3500 Hrs.
Off Off Blinks
Yellow
Low
Power Lamp Cover open
Off Blinks
Yellow Off " Filter Cover Open
Off Off Red Stby Lamp did not turn On
Off Blinks
Red Off Low
Power Fan Stopped
Off Red Off " Circuit failure (short or DVI
connector unplugged)
Abnormal LED Indications
Error Codes "DEVICE" & "MENU"
Error Codes Description
12 No error detected
22 Recovery from Reset
32 Lamp cover is Open
34 Lamp abnormality
35 DM Fan failed (Chassis Fan)
36 Exhaust or Lamp Ballast Fan failed
37 DMD Engine Fan failed
38 Lamp temperature abnormally high. Remove Lamp to check filter.
39 DMD temperature abnormally high
41 Short is detected (Standby Power Supplies)
42 Lamp Fan failed
44 DVI cable between Format and Engine disconnected
46 DMD Temp. Sensor not detected (check DT connector))
47 DM Temperature too high
48 Engine power supply short detected
51 Speaker Drive circuit short detected
52 HDD excess temperature (V30+ & V31 only)
55 HDD Fan Stopped (V30+ & V31 onlyt)
Jul 18, 2014 | Mitsubishi WD Televison & Video
Wd-60737 mitsubishi blinking yellow status light ?
Mitsubishi TV troubleshooting
Here's something that might also be useful. After you turn on the set, and get the regular red blinky lights, hold down the Device and Menu buttons together for about 5 seconds.
The Power light will start to flash in a two digit sequence.
For example, 3 flashes, then 7 flashes = 37.
Here are the error codes, and the corresponding problem:
12 = No error detected, check power supply.
32 = Lamp Cover is open.
33 = Air filter cover is open.
34 = Lamp abnormality
36 = Light Engine (DMD or Lamp Fan stopped)
37 = Exhaust or Lamp Ballast Fan stopped
38 = Lamp Temperature High
39 = DMD Temperature High
41 = Short is detected
44 = DVI cable between FMT and Engine disconnected
Oct 25, 2012 | Mitsubishi WD-60737 TV
RED FLASHING STATUS LIGHT
Possible lamp failure but lamp light not status should blink-I have suggestions but want you to try the self check first--if set has been unplugged plug it up and turn on and when it fails:
Mitsubishi TVtroubleshooting
Here's something that might also be useful. After you turn on the set, and getthe regular red blinky lights, hold down the Device and Menu buttons togetherfor about 5 seconds.
33 = Air filtercover is open.
44 = DVI cablebetween FMT and Engine disconnected
Jun 11, 2012 | Mitsubishi WD-62525 62" Rear Projection...
When I hit the start button on my NP 115 it begins to sound like the fan labors and pulses until it shuts down and the red light blinks in a series of 6 blinks. It also has a very hit frequency squeak that...
after 5 minute image go out n power indicator steady light orange n status indicator red light blikns in a series of 6 blinks. in the manual book said lamp error.. what mind "lamp error". please help me.
Jul 28, 2011 | NEC NP115 DLP Projector
Just changed the lamp and the "status" light is
you must install the lamp door after lamp replacement to get the "yellow" blinking to stop. if the status is blinking red then you may be having a fan failure internal to the tv. also make sure that the side filter door is installed and secure
Dec 22, 2010 | Mitsubishi WD-52525 52" Rear Projection...
I have a wd65100 when powered on i get steady orange light then status blinks red & green,unpluged for 1 hour tv is working but dark picture
Hi
This issue can be due to ballast fan, lamp or high temperature. However, to figure out this we'll need to check for the TV from inside(wiring & testing the components) or the other way is when the lights blink again then follow the procedure given. After you turn on the set, and get the red blinking lights, hold down the Device and Menu buttons together for about 5 seconds.
For example, 4 flashes, then 1 flash = 41.
Please do accept the solution if the issue is resolved or else revert for further assistance.
Thanks
Rylee
Jul 28, 2009 | Televison & Video
Red flashing status light
Press and hold the "Device" and "Menu" for 5 seconds and see what code comes up....... 12 No error detected
22 Recovery from momentary Reset
32 Lamp Cover open
33 Air Filter Cover open
34 Lamp abnormality
35 Chassis Fan failure
36 Exhaust (Back Cover) or Lamp Ballast Fan failure
37 Engine (DMD or Lamp) Fan failure
38 Excess Lamp Temperature
39 Excess DMD Temperature
41 Short Detected
44 DVI Cable (between Chassis and Engine) disconnected
Apr 03, 2009 | Mitsubishi WD-62525 62" Rear Projection...
STATUS LIGHT SOLID RED ON 73 DLP MITSU MODEL WD73735
The colorwheel is your problem. To confirm this, unplug the tv, then listen thru the air vents in the back as you plug the tv in. You will probably hear a ticking sound. If you do, that is the colrwheel. If the colrwheel is working, youwill be able to hear it "spin up". It will be a sudden high pitch whine. Let me know if I can be of further assistance
Dec 19, 2008 | Mitsubishi WD-52525 52" Rear Projection...
Mitsubishi WD52725 DLP
Your DVI Cable may be defective as a 44 code is DVI cable
Jun 21, 2008 | Mitsubishi WD-52525 52" Rear Projection...
Tv keeps turning off?
cutta, you will most often hear a click on boot then the fans start up and lamp will then fire. The picture will start to show up....at what point does it shut off? and do you hear a click when the tv is turning off? Is it the complete tv shutting down, fans and everything that turns off? Do you see any lights on the the front panel "POWER", "STATUS" or "LAMP", what are they doing? If you see a Power, Status or Lamp light after it shuts off the below are what they mean if there is an issue. POWER - STATUS - LAMP - CONDITION/ISSUE: Off - Yellow - Off - Temp. high/dirty filter/excess room temp Off - Off - Yellow - 4000 hrs. Lamp usage warning Off - Off - Blink Yellow - Lamp Cover open Off - Blink Yellow - Off - Air Filter Cover open Off - Off - Red - Lamp failure (failed to turn On or broken) Off - Blink Red - Off - Fan Has Stopped Off - Red - Off - Circuit failure (short) or DVI cable disconnected If you want to check for the last "Error Code", after you first turn the TV on, by pressing the front panel ?DEVICE? and ?MENU? buttons at the same time and holding them for 5 seconds, it activates the Error Code Mode. The ?Power LED Light? blinks/flashes (1/2 sec delay) and then flashes again denoting a two digit Error Code indicating no problem or an error has occured since the last Initalization. i.e. "Power light" blinks 3 times (1/2 second delay) and then blinks 4 times then 1 sec delay and repeats a few times. This would mean "Error 34 - Lamp abnormality". See below for error codes..... Error Code - Description or issue 12 - No Error detected, check Power Supply 32 - Lamp Cover is open 33 - Air Filter Cover is open 34 - Lamp abnormality 36 - Light Engine (DMD or LAMP Fan stopped) 37 - Exhaust or Lamp Ballast Fan stopped 38 - Lamp temperature high 39 - DMD temperature high 41 - Short is detected 44 - DVI cable between FMT & Engine disconnected. Sorry for the long answer but it was an open ended question.
Jul 11, 2007 | Mitsubishi WD-52525 52" Rear Projection...
Mitsubishi WD-52725 52". Rear Projection HDTV Logo
254 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
