Question about Whirlpool 24 in. ADP5962 Free-standing Dishwasher
Hello.have whirlpool dishwasher 4404/5. green light flashes x 4
Hi green start light flashes 4 times...float in tub standing freely....water pipe clear...drains clear... hear motor.
have turn on off and on again...no change.
any further suggestions please thanks.
( have already paid once for advise)
kind regards
Dave.
  • blueextc3221
    blueextc3221 May 11, 2010
    I had this exact problem with my dishwasher but i managed to fix it. It was such a simple problem, the water outlet pipe had a kink in it and wouldnt let the water drain. I straightened the pipe, put duct tape around the kink to strenghten it and the dishwasher worked straight away. I hop this helps.
  • blueextc3221
    what is the full model # ?
  • Whirlpool Master
  • 3,235 Answers
Sorry...
This is the WRONG PLACE for paid advise...
You need to contact the CLOWNS who charged you...!!
FIXYA is entirely FREE... (all volunteer)...
Not ever to be confused with money grubbers...!!
Good luck with your scammers.
Carnac the Magnificent
Posted on Dec 03, 2017
2 Suggested Answers
  • 1550 Answers
SOURCE: WHIRLPOOL dishwasher 4404/5.
The water pressure is not upto the mark in your dishwasher , try switching it on when there is no other water being used.
Posted on Dec 27, 2008
Whirlpool adp 4404/5. Green light flashes 7 times !! Any idea ?
F7 - Flow-meter failure
Symptom: water inlet valve (WV1) is switched on and the water indicator (WI) is on (level reached).
Could be:
1. Water tap closed during water inlet
2. Water inlet hose blocked
3. Water inlet valve (WV1) defective
4. Flow-meter (FM) sends too few / much pulses (less than 10 imp.in 10 sec.)
Flow-meter counts wrong (or the sump is full in less than 30 sec. Causation: Hose felt down and slipped the disc of the valve. The effect is a displacement of the valve tappet).
5. Aquastop defective
6. Flow-meter defective
Dado
Jul 26, 2015 | Whirlpool Dishwashers
Dishwasher runs but no water comes in the dishwasher. Checked water supply, good up to begining of solnoid, but water doesnt go through it. Model DU810SWPQO WHIRLPOOL 2004
Heres what to check
FLOAT IN TUB...check it for sometime stuck under it, or it stem under float is gummed up
FLOAT SWITCH....if float is down and moves freely check for continuty on float switch
WATER VALVE ...check for 120 volts ac into wires on valve solonoid when supposed to be filling,
it's supposed to fill and beginning of cycle
Gene
Aug 14, 2011 | Dishwashers
Water standing in tub
If there is a lot of water sitting inside the applicance, it's possible that the high water float switch has been activated and is preventing the dishwasher from running. Open the door, remove the bottom rack, dip as much water out of the bottom as possible with a shallow ladle or even tupperware container. When that is accomplished, shut the door and try to run a drain cycle. If the unit won't start, you may have to remove more water. You don't have to have the rack in place to run the drain cycle.
Jul 09, 2010 | Whirlpool 24 in. GU2500 XTP Built-in...
I have a whirlpool adp951 with a green light flashing
HI,
press back and forth between hi-tempwash and sani rinse several times to get all lights to come on if not then press sani rinse and heated dry back and forth several times. one of though combos will start the test mode
thank you for using fixya,rate my answer,
vijay
Oct 02, 2009 | Whirlpool 24 in. ADP5966 Free-standing...
Dec 26, 2008 | Whirlpool 24 in. ADP5962 Free-standing...
Flashing light
I had this problem at home too, it turned out to be a kink in the water outlet pipe. I straightened out the kink in the pipe, put duct tale around it to strenghten it and the dishwasher has been working perfectly since.
Aug 08, 2008 | Whirlpool 24 in. ADP5962 Free-standing...
I have a whirlpool ADP4400 the green light is flashing and the pump continues to pump but the cycle will not start
I had this exact problem with my dishwasher but i managed to fix it today. It was such a simple problem, the water outlet pipe had a kink in it and wouldnt let the water drain. I straightened the pipe, put duct tape around the kink to strenghten it and the dishwasher worked straight away. I hop this helps.
Apr 28, 2008 | Whirlpool 24 in. ADP5966 Free-standing...
I have a Whirlpool dishwasher model ADP951. the green light is continually flashing and will not run, help with this would be most appreciated.
Have a look underneath dishwasher by removing front bottom access panel, the one touching the floor. Look for a round plastic disc about size of 4 jam lids together, centre front of dishwasher. Inside of it is a foam disc that will float up off the base of the dishwasher if water causes it to do so. This floating up will trip a switch. Clean base of dishwasher of water and maybe test the switch with multimeter. Reset fault by holding down start button.
Apr 26, 2008 | Whirlpool Dishwashers
Flashing green light
Hi there. It looks like water is present in the flood catching tray at the bottom which usually indicates that there is a leak somewhere. More often than not this is just a pipe with a poor fitting and simply tightening the clip is enough to stop the leak. Our machine had a very slow leak from one pipe (not enough to trigger the alarm) which was fixed in this way. The leak is detected by a small float switch located in the flood catch tray.
Undo 4 screws on the metal plate under the dishwasher 3 at the front 1 at the back, this reveals The pump check the seals are in place on the waste pump.
Mar 10, 2008 | Hotpoint 18 in. BCI45 Slim-Line Built-in...
Whirlpool 24 in. ADP5962 Free-standing Dishwasher Logo
Top Whirlpool Dishwashers Experts
Oloyede Monsuru
Mike
Are you a Whirlpool Dishwasher Expert? Answer questions, earn points and help others
