Question about Mitsubishi WS-65857 65" Rear Projection Television
Mitsubishi VS-50VF2 Curved picture problem
The picture on the top and bottom of my Mitsubishi VS-50VF2 curves in. This happens most of the time in the last couple of years when I turn the TV on. Occasionally the picture fills the screen properly with the verticle and horizontal edges being straight. Other than the curving in from the top and bottom the picture quality is very good. The curving is faily minimal so it hasn't been much of a problem.
What is the problem and what can be done to solve the problem?
5 Suggested Answers
SOURCE: Curved picture and double images
pincushion circuit
Posted on Apr 11, 2007
Ecollier2012
  • 3459 Answers
SOURCE: picture looks curved (concave curve) on my sony KP-46WT510
You may have a convergence problem. Here are some of the most common symptoms and example photos.
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
Here is a quick test....
Using your original remote go-to the tv settings then goto the convergence section.
Try to adjust the red and then the blue convergence.
You should be able to move them up, down, left, and right.
If you can't move them in all directions your convergence chips are bad and should be replaced. This is a common problem.
You need to replace the convergence chips and convergence resistors. Check the site www.TvRepairKits.com. They have put together a kits for most models. If you don't see a kit for your set send them a quick email and they will put one together for you. Their kits includes photo instruction guides, original Sanyo STK chips, convergence resistors, pico fuses, etc.
Posted on Feb 05, 2009
  • 668 Answers
SOURCE: Mitsubishi 1080 hd series 65" Curved picture
The problem is the convergence circuit.
Mitsubishi used two different types of convergence IC's in this series. The first is a pair of STK-392-570, the second is a single STK393-110. The only way to fix the problem is to replace the appropriate IC'S. In some cases the problem may appear to be intermitent or loose solder connections. Save yourself the anguish and replace the IC'S.
Getting the PowerSupply/ Convergence board
out to do this is tricky and I recommend a professional to do it. Hidden screws on the front of the heat-sink make it difficult to take out and you can break the board easily trying to force it.
Posted on Jun 17, 2009
SD Tech
  • 14553 Answers
SOURCE: Pink and green colors seperated images rounded off
If colors are skewed and will not adjust in the customer menu---you have a CONVERGENCE circuit problem.
This model (KP-51WS500) uses two of the STK-392-560 convergence IC chips. I just got home from fixing a similar model with the same problem.
Parts cost on Ebay for the chips and such is going to be less than 30 dollars total. Shops are going to get 300 or more for this kind of repair---and some will not do it in your home---the repair takes about an hour--I have done hundreds of them here in people's homes.
If you have questions or need advice, reply to this posting and I will try to help.
If this told you something that helped you understand, rate this solution as I do this here for FREE.
SD TECH
Posted on Nov 15, 2009
Curved in at top and bottom and rainbow colors on bottom
REPLACE ALL STK?????? CONVERGENCE AMP IC'S & CHECK RESISTORS FOR THAT CIRCIUT
Apr 12, 2009 | Mitsubishi WS-55809 55" Rear Projection...
Curved picture at top and bottom
if it is bowing from top and bottom your looking at a convergance problem if you keep using your tv soon there will be no picture at all when the board crashes... convergance board needs to be replaced... hope this helps..
Apr 11, 2009 | Samsung HCN4727W 47" Rear Projection...
Mitsubishi VS-4561 picture curved inward
Its Your Convergence Chips!. And Maybe a few Resisters!. Common Problem with this kind Of Set!.....
Jun 30, 2008 | Mitsubishi VS-45607 45" Rear Projection...
Mitsubishi VS-60705 Large Screen Projection
thanks for your detailed description of what happened.
replacing the vertical output i.c will correct the problem.
the reason it failed was bad connections on it.
Apr 22, 2008 | Mitsubishi VS-45605 50" Rear Projection...
RCA Projection TV model #p61926
The convergence circuit is your problem and most times with this model the convergence power supply bd. is the problem.
Feb 11, 2008 | RCA P46921 46" Rear Projection Television
Curved picture
you have a convergence problem.more than likely will require the replacement of the convergence amp ic's. stk393-570 (2 qty)
Nov 29, 2007 | Mitsubishi WS-55819 55" Rear Projection...
PICTURE CURVED
I have the same problem, it is called the "bow tie" effect, I read in a forum a couple of years back it is because they started computer sodering instead via humans and it was not successful during that time. I bought mine in 02. I was hoping to find a picture of the the board and the specific soder joint on this forum. I hate to pay alot for a tech, (specially since it was mitsibitsi's poor craftmanship) and a 65" is not something you throw in the truck and take to them. Good Luck.
Oct 12, 2007 | Mitsubishi WS-65515 65" TV
3 curved lines top & bottom/blurred picture
This indicates a convergence problem..convergence power supply probally.. however ive seen 2 other cuicits cause this ..
Sep 24, 2007 | RCA HD52W59 HDTV Projection Television
Three curved lines have appeared approx. 6" up from the bottom of the screen. Is this a simple fix .... maybe as simple as replacing a bulb?
Are you saying that the whole picture is gone and all you see on the screen are 3 curved lines near the bottom, or is the picture there but 3 curved lines are over the picture, or is the picture there but the bottom of the picture has curved upeards?
Aug 23, 2007 | Sony KP-46WT510 46" Rear Projection HDTV
Mitsubishi WS-65857 65" Rear Projection Television Logo
94 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
