Question about Arris Touchstone 450a (CM450) Modem
Pulse-dialing with Arris modem?
Is it possible to use a pulse-dial telephone with my Arris digital modem? Or to change the pulse-dial phone (nce Ultima 1 wireless model 1-700)? My service provider wasn't any help...
  • 86 Answers
If you have the current firmware for your modem, it should work with pulse. Arris had to make it's MTA's pulse compatible due to old alarm systems that still utilize pulse dialing.
Posted on Jan 20, 2008
  • 57 Answers
You are beter off changing your telephone to tone dialling
Posted on Jul 10, 2007
How do I change pulse to tone dialing?
Are you sure about the phone model number?
Tone/pulse is set in the common equipment (KSU) configuration, not the individual set.
Press Feature 9*80 to see the system software version.
Jan 27, 2015 | NorStar M7324 Telephone
Can 2wire modem be used as a fax
As long as you have phone service you should be able to plug a fax machine into the telephone port, you may need to change your fax machine to tone dialing from pulse.
Jan 29, 2013 | 2wire (1000-000057-000) Modem
Lost dial tone and phone service
Your phone line might be connected to Telephone 1 not 2. That could be the reason why you are not getting a dial tone.
Nov 22, 2009 | Arris Touchstone 450a (CM450) Modem
I have suddenlink cable and my phone is through them too. I keep having problems with my phone working. They say that it is linked to the modem. I do not know anything about this but they cannot seem to...
on an arris modem, if the telephone light is solid, then there is dial tone coming into the modem. that means the problem is somewhere in the house wiring. check to make sure the phone line is plugged into line 1 on the back of the modem. next make sure it is plugged into the wall jack. if this is correct then you need the cable co to come out and troubleshoot your inside wiring. as a quick fix, you can plug your phone into the jack on the back of the modem labled line 1/2
Jun 25, 2009 | Arris Computers & Internet
Need to change phone back to tone dialing
Here's what the manual says: Changing the Dial Mode (Tone or Pulse Dialing) (HS1 only) Your phone can communicate with the telephone network in two different ways: tone dialing or pulse dialing. These days, most phone networks use a method called tone dialing, so your phone comes programmed for tone dialing. If your phone company uses pulse dialing, you need to change your phone's dial mode. If you don't get a dial tone or can't connect to the telephone network, follow the steps below to modify your phone?s settings: With the phone in standby, press and hold [cid/menu]. Press [vol/ / ] to move the pointer to select DIAL. Press [select/channel] to set the phone to pulse dialing. Press [end]. Return the handset to the base. The handset communicates the new setting to the base, and the base activates the setting on any other handsets. Hope this helps out. K
Jun 05, 2009 | Uniden 2.4 GHz Cordless Phone System
How to dial out on a uniden Cordless phone on a pulse line
I still need a model number, but if it's not possible and you reeeally want to use the cordless, if you have a modem in your computer, you can have it dial pulse, pick up the cordless, and hang up the modem......
Mar 13, 2009 | Uniden Cordless Phone
Dial Tone - Number Dialed does not go through
The problem is possibly the keypad on the phone. Try another phone , preferrably a standard corded phone. If you still cannot break the dial tone, then the problem is with the telephone line (phone company)
Mar 28, 2008 | Lands Phones
Cordless telephone sw/from pulse to tone
In General Electric (GE):
TONE/PULSE DIALING
To set to tone or pulse dialing:
1. Press and hold the program button for two seconds. You will hear a beep.
2. Press the *tone button to select Tone Dialing or press #pause to select Pulse Dialing.
3. Press the program button again. You will hear a confirmation tone.
Nov 25, 2007 | GEH5450 Cordless Phone
Cordless phone
press menu then globel setup and then press dial mode then change the the dial tone you want
Oct 19, 2007 | Uniden DECT 6.0 Cordless Telephone...
Arris Touchstone 450a (CM450) Modem Logo
622 people viewed this question
Top Arris Computers & Internet Experts
bobkoure
Level 1 Expert
Jerry
Jerry
Are you an Arris Computer and Internet Expert? Answer questions, earn points and help others
