FixYa.com
Tags:
RCA DTC210 DirecTV DTV Receiver
Lost some HD Channels
By Gary10 - usenet poster
I have a RCA DTC210 HD receiver(DirectTV).  It has work pretty good until
about a month ago.  I started getting pixelization and drop-out on some HD
channels. Now I have pretty much lost 3 of the 5 channels.  I can still
watch channels 74 & 78 fine, but the other 3 channels(73, 76, 79) either
don't tune at all or blink in and out making it impossible to watch.
I've done soft boots and hard boots, checked alignment, switched cables on
LNB and still have the problem.  I get a 90%+ on Sat A, 88%+ on Sat C, and
0% on Sat B.
The unit is 6 months old.  Any known defects with this receiver?
What can I do?
Thanks,
Tom
"That man is richest whose pleasures are cheapest."
        -Henry Thoreau
"The original point and click interface is a Smith and Wesson"
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
Solution #1
posted on Aug 08, 2005
Not Rated (0)
Rachel007
Rachel007 - usenet poster
Rank:Apprentice Apprentice
Rating: 0%, 0 votes
: I have a RCA DTC210 HD receiver(DirectTV).  It has work pretty good until
: about a month ago.  I started getting pixelization and drop-out on some HD
: channels. Now I have pretty much lost 3 of the 5 channels.  I can still
: watch channels 74 & 78 fine, but the other 3 channels(73, 76, 79) either
: don't tune at all or blink in and out making it impossible to watch.
: I've done soft boots and hard boots, checked alignment, switched cables on
: LNB and still have the problem.  I get a 90%+ on Sat A, 88%+ on Sat C, and
: 0% on Sat B.
: The unit is 6 months old.  Any known defects with this receiver?
Dunno about the receiver (I have an older dct-100) but it's possible the "B"
LNB just crapped out being you are getting a zero reading, or the dish went
out of alignment.
I know they moved things around but was under the impression some of the HD
stuff was mostly fed off the C though. They have some test channels around
490-496 I think that is a barker channel for each satellite and polarity.
One thought, on the dct-100, there is a config menu for dish type, not sure
if it was carried over but you need to tell the receiver the type of antenna
you have, single, dual or triple. If it's not on triple, it doesn't send the
correct tone signals to the multiswitch, so again, C or B could be missing
because of that.
The receiver going bad is always possible but not likely in this case.
Can't say a simple troubleshooting process but in order:
1) improper configuration on the receiver
2) dish alignment, especially "tilt"
3) bad lnb
4) bad jumper on lnb to multiswitch assembly if it's the older type
5) bad multiswitch
-bruce
b @ripco.com
Was this solution helpful? Show your Appreciation by rating it:
Solution #2
Not Rated (0)
pawa
pawa - usenet poster
Rating: 0%, 0 votes
As Bruce Esquibel so eloquently stated:
Thanks for the info.
I think I've narrowed it down to the LNB(multiswitch). It just ticks me off
that it went bad in 6 months. And DirectTV want to charge me $70 to replace
it(service call) since it only carries a 3 month warranty and one year
parts.
Thanks,
Tom
        -Henry Thoreau
Can you Help with these TV Receivers and DVRs problems?
i have lost my code list
I have a goodmans freeview box... Answer This...
I changed my digital...
... and I m unable to lovate... Answer This...
help please!!!!
a yamaha receiver i lost the... Answer This...
my remote wont work
do i need to program it? i have... Answer This...
RCA TV's 32 inch screen
Sir I have a large body 32 in... Answer This...
Repair Service
Find TV Receiver and. Repairman Near You:
FixYa does not evaluate or guarantee the accuracy of any information provided through its proposed solutions, posts, or Expert Assistance Sessions. By entering this site you declare you read and agreed to its Terms. You may NOT copy or distribute the content that appears on this site without written permission from FixYa Inc.
© 2005-2008, FixYa, Inc. or its affiliates
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
