Question about Nikon F3HP 35mm SLR Camera
Missing F3 ON/OFF Switch
One of my F3's is missing the ON/OFF switch that is concentric to the Shutter button/ Where can I but a replacement switch ring? I know how to tear the camera down to replace it.
Thanks,
Ed
    Scholar:
  • 95 Answers
Try Nikon directly as they still supply parts for the F3. Call them at 1-800-645-6687
Posted on Dec 28, 2008
2001grand Cherokee 4.7fuel shut off switch location
You don't have one.
Are you missing anything besides fuel? Engine cranking, do you have spark at the plugs and fuel injector pulse?
If you missing fuel--spark--injector pulse, I'd have to check signals from cam and crank sensors. Just my opinion.
If your only missing fuel, then you can concentrate on the fuel system.
May 01, 2018 | Jeep Grand Cherokee Cars & Trucks
Shutter button for easy share z712is
hi,
what is shutter button? is it snap button? if yes, it is available with AlDees Camera repair center in Dubai.
Feb 11, 2016 | Cameras
The exposure lock button on my Nikon F3 is missing
ebay is your friend, most any part can be found there
Apr 19, 2014 | Nikon F3 35mm Film Camera
How do I change the shutter speed?
This is "shutter lag," the delay between pressing the shutter release button and the camera actually taking a picture. This is a common situation with many compact cameras. The camera has to focus on the subject, meter the exposure, and switch the circuitry from displaying on the screen to recording the image and saving it in memory. More sophisticated (and expensive) DSLRs eliminate this shutter lag by having more dedicated hardware for this.
With a compact camera, you can reduce the shutter lag by anticipating the shot. Press the shutter release button halfway to focus and meter the exposure. Continue to hold the shutter release button halfway until the right time, then press it the rest of the way.
Jan 17, 2010 | Canon PowerShot SX100 IS Digital Camera
The oven isn't working and it says FO in red letters
GE / Hotpoint / RCA
Oven Fault Codes
Display Condition Remedy
F0 & F1 Failed Thermistor Control Replace ERC
F2 Oven Temp Exceeds 590 with unlocked door High resistance in Sensor, likely a bad sensor
F3 Open Sensor circuit Open (blown) sensor fuse or bad Sensor
F4 Shorted wire or Sensor locate short and correct it
F7-A Function pad button stuck Clean and unstick
F7-B Bad Clock Replace Clock
F8 Electrical component failure Replace ERC
F9 Program with door circuit Check wiring
Frigidaire / Westinghouse / Tappan / Gibson
Oven Fault Codes
F0 & F1 EOC failure Replace EOC
F2 Oven over heat Defective Sensor or EOC
F3 Oven Sensor Open Replace Sensor
F5 EOC failure Replace EOC
F6 EOC failure Replace EOC
F7 EOC failure Replace EOC
Maytag / MAYCOR / Magic Chef / Jennair / Admiral
Oven Fault Codes
F0 Function key shorted or stuck button Clean and unstick button or replace Touch Pad or Clock
F1 Defective Touch Pad or Membrane Replace Touch Pad or Membrane
F2 Oven over heat defective Relay Board or (if present) or defective Sensor
F4 Shorted wire or Sensor locate short and correct it or replace Sensor
F5 Hardware, safety circuits disagree Replace Clock
F6 Missing AC (power) signal Check for proper voltage (plug, breaker, etc.)
F7 Function key shorted or stuck button Clean and unstick button or replace Touch Pad or Clock
F8 A/D Warning Replace Clock
F9 Door Lock Warning Check door lock circuit or Replace Clock
Amana / Caloric
Oven Fault Codes
Type with display - glass link ERC
F0 No Safety Signal Replace adapter board
F1 No Safety Signal Replace ERC
F2 Oven over heat Replace defective Sensor
F7 Shorted Touch Panel Replace Glass Panel
F9 Door Latch Error Check latch
FF Lock Error Check switch and motor
ERC III - Relay board with separate board/push buttons
F0 Shorted Push Pad Replace Push Pad
F1 Defective ERC Replace ERC
F3 Oven Sensor Open Check/Replace Sensor
F5 Defective ERC Replace ERC
F6 Defective ERC Replace ERC
F7 Shorted or sticking button Clean button or replace touch pad
F8 Defective ERC Replace ERC
The following diagnostic chart Does not apply to Whirlpool 'Y' line products. If the model number contains a Y near the end of the number, DO NOT use this chart.
Whirlpool / KitchenAid / Roper
Oven Fault Codes
Ovens with 4 digit displays
F0-E0 Analog to Digital failure Disconnect panel for 30 seconds. if error re-appears then replace control
F1-E1 Defective ERC Replace ERC
F2-E0 Shorted Keypad Replace Keypad
F3-E0 Sensor or Sensor Fuse Open Replace Sensor or Fuse
F3-E1 Shorted wire or Sensor locate short and correct it or replace Sensor
F3-E2 Oven over heat Replace Sensor
F3-E3 Cleaning Temp over heat Replace Sensor
F5-E0 Door Error Check Door
F5-E1 Door Latch Check Latch
F5-E2 Door Switch Check Switch
Ovens with 2 Digit Displays
F0 Defective ERC Replace ERC
F6 Problem with time keeping circuit Reset Time or cooking operation and check for proper ground
F7 Shorted or sticking button Clean button or replace ERC
F9 Door Latch Error Check latch and latch circuit
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Dec 18, 2009 | Ovens
Broken and missing button for Overdrive switch
Did you try replacing the housing and button? There could be a reason why that is, perhaps the overdrive has or had an issue from prior owner because of the transmission having problems. If your not comfortable with replacing the housing and button, get a few qoutes from a reputable shop, then decide if it is worth it.
Feb 19, 2009 | 1997 Ford Explorer AWD
Missing power button
there is one thing you can do cheaply,
open the tv by pass the switch, put straps a cross switch contacts.
only two polarities enters your tv live and netrual, each one goes a cross the switch.
program your remote
0156,0060,0154.
or 060,019,014,052,054,075.
Jan 22, 2009 | Toshiba 35A44 35" TV
Nikon F3 w/MD4 motor drive...Not working!
Check to see if the manual shutter release (the one that is to the left of the lens when you look at the camera head on) is not cocked and ready. It should have its lever resting against the lens collar. Since this is the manual release of 1/80 second, this can sometimes be the cause of the problem. Also, make sure the shutter speed dial is set to something other than the 80 speed.
Since you can get a reading on the light meter, its likely not a power issue, plus the F3 is capabale of pulling power either from the drive or from the battery compartment.
Sometimes the electronic F3 shutter button can seize due to lack of exercise. The curtains won't need placing unless they are worn, but the switch may need replacing.
Dec 10, 2008 | Photography
Need to know
unless you can get them free , don't waste you time on them
they were a cheap camera to start with
Apr 18, 2017 | Cameras
Starview northwest
If you only need 1 line of codes m8 try the NEW line.
On your remote PRESS ON menu,
press yellow button enter your provider number V. M. is 5A 01
THEN in the 00 section
put in code 75 4A 66 04 CF 7F 55 F3 (NEW)
then in the 01 SECTION put in code 2A 09 4D DF CD 33 00 B9
then on remote select ok. best of luck with it. Let me know if they work.
Your TV = A, RADIO= B P- = C P+ = D, INFO= E RECALL BUTTON = F
C & W. 5C 01 00= 0E 0E D3 03 A7 A4 57 39
01= BF C5 F3 56 A8 51 A8 0D (NEW)
Jul 13, 2008 | StarTech.com StarView SV211K 2-port KVM...
Nikon F3HP 35mm SLR Camera Logo
123 people viewed this question
Top Nikon Photography Experts
Ric Donato
pontelemon
pontelemon
TC CAMERA REPAIR.Com...
Are you a Nikon Photography Expert? Answer questions, earn points and help others
