Question about Yamaha TSS-1 Computer Speakers
None of my computer outputs are functioning. Much like this proble here: http://www.d-a-l.com/help/general-hardware-issues/6844-computer-output-problem-serious.html symptoms are exactly the same, however solution does not work. I turned computer off, fitted my new ram, that didnt work with the computer so i turned it off and put old ram back in. Now none of the outputs work, any ideas?
  • 77 Answers
The first thing you can try is reset the CMOS and see if that helps. Sometimes you cause BIOS issues when changing RAM
Posted on Jan 14, 2010
  • 103 Answers
If the outputs are not working try to fully delete and reinstall the audio drivers if problem continues then you have a bad audio card/or bad motherboard....period...
Posted on Aug 15, 2009
  • 73 Answers
Try resetting the CMOS battery at the same time for a complete clean reset.
Posted on Jul 17, 2009
I just installed a Acer S211HL LCD monitor. All my connections are tight. I get a No Signal on screen and monitor goes off. what the proble?
If you get a no signal message then check your video card, if the monitor gets no power at all then try replacing the cable, try a different outlet, if none of those work then the monitor is defective.
Mar 04, 2011 | Acer Computers & Internet
Function key plus number pad doesnt work. numpad is supposed to be fn key plus the four rows of 7890 uiop jkl; m,./ if NumLock is off, the +-*/ work, but not the numbers. the numbers behave as...
A numpad usually outputs the cursor movements with the shift bar depressed. That suggests to me that you need to turn of the Caps lock key, or otherwise make a change to the keyboard setup. Maybe there's a Fn key combo that needs to be toggled.
Oct 15, 2017 | ASUS 90-A4C1K1000 Keyboard
No output from graphic card
The video output on many portable computers toggles off and on with one of the function keys. Look for a function key with the image of a monitor on it, then hold down the Alt key and push the function key once or twice. It usually has several choices that you rotate through - computer monitor only, video out only (your screen goes blank) and both screen and video out.
Sep 13, 2009 | Sony VAIO NS Series VGN-NS110E/L NoteBook...
My cpu shot down evry more aften
try to check the fan in your processor maybe if didn't function that is why your processer got to hot and shut down it self or try to check  the connector inside your System UNIT. Then if the same proble occurs try to find a technician to check the current status of your Unit.
Jun 19, 2009 | Computers & Internet
None of my computer outputs are working
If your computer is bang up-to-date with all Windows/Linux system updates and Drivers for your set-up, it sounds like your Sound Card has had a terminal fault. I would try a newly purchased card, so as to be sure the outputs are functioning.
Dec 26, 2008 | Yamaha TSS-1 Computer Speakers
Dial lights up, all control functions O.K. bou no sound.
Hello: Thanks for your feedback. I was surprised that the type of unit and manufacturer did not appear with the request for help, because without that information it made no
sense. However I did resolve the problem by experimenting with the controls and connections on the unit. Just got it.
Thanks again....
Sep 01, 2008 | Audio Players & Recorders
Jawa void
you should not use arguments in void function in java ... in java pertaining to void the compiler doesn't understand the arguments and treats that as invalid... in c it is ok
Aug 07, 2008 | Sun Java Studio Standard 5 (SSJI9501TL9M)...
No sound
try to reinstall the driver, if still not work maybe your builtin speaker is defective, or maybe you should try the earphone look for the audio output, if it's functioning then your builtin speaker is deffective..
hope it will help, thanks.
May 28, 2008 | Toshiba Satellite U205 Notebook
Yamaha TSS-1 Computer Speakers Logo
83 people viewed this question
Top Yamaha Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Yamaha Audio Player and Recorder Expert? Answer questions, earn points and help others
