Question about Sharp AL-1000 Copier
Toner low signal
Loaded new toner. Can't get toner signal to go off. I have tried to reload toner many times.
  • james carpenter Apr 18, 2007
    Signal came on for low toner. Reloaded toner many times. Is there a switch I am unaware of?
    Triangle showing!
  • 31 Answers
Try turning your copier off & back on. Allow the machine to cycle after turning it back on - until it comes to ready or displays add toner signal again. You can try this three or four times as it sometimes takes the machine a few trys to advance the new toner to the toner sensor. If after 4 attempts you are still getting the add toner message - you may have a dirty or faulty toner sensor. The toner sensor is located inside the developing unit that you are loading toner into. Toner sensor is usually located on the bottom of the developing assembly & is held in by 2 scews. It can be cleaned with a dry cotton rag & reinstalled. 90% of the time power cycling the copier a few times will solve this problem.
Posted on Apr 18, 2007
Konica minolta pagepro 1500w toner low error
recharge toner powder. 'BROTHER' toner powder is suitable for it.rate 100 Rs. only.
Sep 15, 2013 | Konica Minolta PagePro Office Equipment &...
When printer is turn on that time printer reddy and cartridge light on so what is the problem
You can see four LED's on control panel, from top to bottom,1st is toner indication 2nd Attention 3rd is Ready light, 4th go light.. Observe led's are 'blinking' or 'On' condition.. # If toner light is blinking ="toner cartridge missing or contact problem or memory faulty.
# If toner light & ready lights are on= "toner low indication or refilled cartridge loaded".
Jul 12, 2012 | HP LaserJet P2015dn Printer
White lines when printing
Usualy white lines are a signal for you that is time to replace a toner cartirdge.
Your machine may inform you that you need to replace a toner cartridge, but sometimes the toner levels are low and the machine doesn't indicate that.
Another thing that you may try is to clean all toner cartridges using each corona wire.
If you need to replace your toner cartridge check this easy and helpful way to replace toner cartridge.
May 16, 2012 | Brother MFC-9320CW Color Laser Printer -...
Estudio 181,when first toner end,second toner refill but show the toner signal low.
toshba e studio 211 toner cheap problam nat toner sing plz halp me
Sep 12, 2011 | Toshiba e-Studio 350 Copier
The orange light is blinking. Above the light is a triange with an exclamation point in it. I have tried deleting and reloading the printer and that doesnt work.
Do you have a new toner cartridge loaded? The red/orange light will blink when toner is low, even if everything else is working fine. Try printing out a test sheet and see what that tells you about your toner level. (Test sheep prints by holding the orange button down a second or two and releasing.)
Since I'm mainly printing drafts for my own use, I've just let the light blink while I eke out whatever I can from the remaining toner (occassionally removing the cartridge and shaking it -- being careful of clothes and surroundings -- to re-distribute the toner on the inside.
Oct 17, 2010 | Samsung ML-2510 Laser Printer
The orange light keeps blinking and won't go back
This could be signaling that the toner is empty. Replace the toner and see if the light goes back to green. Hope this helps.
Oct 16, 2009 | HP LaserJet 1100 Printer
Received "Low Toner" message. Replaced toner with new Brother cartridge still have "low Toner" meaasge and [printer will not print.
Please check if you removed the Plastic Tapes which is placed in the side lock of the new Toner Cartridge.
Apr 24, 2009 | Office Equipment & Supplies
Canon ImageClass MF 6550 Error Toner Low- Prepare New Toner
There are two contact on the right wall off the printer cartridge chamber area. They can get pushed in causing the printer cartridge to not read correctly. Take a small Flathead screwdriver and bend them up so the cartridge ink level can be read.
Dec 17, 2008 | Canon imageCLASS MF6530 Monochrome Laser...
Error light on and toner low/ replace drum light on
I was talking to dell and they said it was because of my toner. Guess I will try a new dell toner.
Feb 21, 2008 | Dell 1710 Laser Printer
Sharp AL-1000 Copier Logo
216 people viewed this question
Top Sharp Office Equipment & Supplies Experts
k24674
George Mclaughlin
Ed
Ed
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
