Question about Akai LCT2716 27 in. LCD Television
Picture comes on in blocks
When you first turn on the tv it shows blocks with the picture scrambled. YOu have to turn it off several times for it to straighten out. It is hooked to Direct Tv I have changed out the direct tv box but it is still doing it . The direct tv has been hooked to AV1 Av2 and Tv but it still does it. Someone said it is the signal it is receiving. I have tried everything . Can anyone help me
  • Theresa Bass Apr 19, 2007
    The tv used to be on dishnetwork and never did this until it was hooked up to direct tv. We were thinking it must be something with their box
    Genius:
  • 1,074 Answers
Check all you connections.if that does not help call in the cable company to eliminate the cable.if that does not solve the problem then it is time to call in the tech.the problem could be in the agc circuit vertical or video circuit.good luck.
Posted on Apr 19, 2007
SOURCE:
Model pn50a550s1fxza. What is causing the tv to do this?
check the main.board n power board one of them is faulty needs replacement
Oct 02, 2015 | Samsung Televison & Video
Fuzzy/Scramble screen when first turned on.
check solder joints on top of screen some screens were sub contracted to a chineese company called chi mai and had inherant defects
Nov 30, 2012 | Samsung LNT5265FX 52 in. LCD Television
My TV pictures scrambles after warming up
Check and replace all the electrolytic capacitors.
Aug 28, 2012 | Televison & Video
Westinghouse Flat Screen Goes Blurry/has Scrambled Picture
tried first with re seating the lvds cable in the t-con board, the t-con board is mounted covered with metal shield. if can get with fixing the cable, then your t-con board has defective component parts.
Aug 13, 2012 | Westinghouse Televison & Video
I have a Westinghouse SK-32H240S 32" flat screen
First when tapping changes the picture you have somewhere a bad connection; in electrical board or wiring.
When the screen goes blank after a while means some capacitor is bad/old.
Mar 13, 2011 | Westinghouse SK-32H240S Television
My Westinghouse LTV-27w6-HD picture is scrambled periodically
Before you bother to read the text below, you might be better served looking at this thread:
Westinghouse troubles
If you aren't nauseated yet, continue with my original reply:
If the picture seems 'pixelated,' broken up into randomly sized and placed blocks, then it is losing synchronization with the digital signal coming in. This is certainly repairable and may be due to lousy assembly quality rather than a failed part. Most of our modern sets are assembled by robots but there is a degree of manual soldering still to be done and this can result in 'cold' solder joints that can fracture and fail due to heating and cooling of the innards of a set.
Unfortunately, unless you have a semi-retired TV service man in your neighborhood who is already financially independent, the labor costs could run fairly high for this kind of service since it requires methodical searching of the circuitry and could eat up some time.
Jul 24, 2009 | Westinghouse LTV-32w4 32.02 in. LCD HDTV
Sony KV-27V22 scrambled picture and loud buzzing audio
the variation from higher channels from lower channels, few things changes eg frequency, voltage, and current.
take your tv to a w/shop and have the following
tunner voltage pulse variation on a avo meter has you change channels. if the difference of voltage is not unform when you are changing from to channel then you should change the control ic on the rf stage or check the capacitors a round the rf ic for variations in value.
Mar 25, 2009 | Sony KV-27V22 TV
TV picture scrambled and getting worse
This can be a fault in the tuner, IF, or primary part of the video processing. With age and use some of the parts, and especialy capacitors, in these sets can become thermo sensitive and unstable.
To service these types of faults can be very time consuming. On top of this would be the cost of the parts.
Considering the age and type of set that you have, I would suggest that it is time to be looking for a new set.
Jerry G.
Apr 21, 2008 | Toshiba 50H82 50" Rear Projection...
Scrambled picture when cable box is hooked to hdtv plugs on philips 60 inch rear projection tv
I have a 53inch philips that is showing pictre but showing green, red as shadows..
Oct 03, 2007 | Televison & Video
Akai LCT2716 27 in. LCD Television Logo
82 people viewed this question
Top Akai Televison & Video Experts
Jaime Hernandez
Steve Allison
Steve Allison
Are you an Akai Televison and Video Expert? Answer questions, earn points and help others
