I soft-modded my Wii and I after a while I started messing around with the more experienced stuff like Preloader. One day I go to turn on my Wii and nothing happens. The power button on the Wii is green but there is no picture nor sound coming from the TV. My Wiimotes won't connect either. I've checked and everything is hooked up correctly. Someone told me before that it might be the bluetooth module but I'm not sure. Someone please help!
I also have the exact same problem using the wiikey2. Can turn the power on and get a green light, but nothing happens. Cannot turn the power off with the power button unless i hold it in for a few seconds. It takes a disk but it doesnt spin. when i power off and power it on with disk in the drive it spins and does its normal thing but still no video an sound. everything worked fine the day before. Did no updates still at 3.3. Help someone please. I also have the exact same problem using the wiikey2. Can turn the power on and get a green light, but nothing happens. Cannot turn the power off with the power button unless i hold it in for a few seconds. It takes a disk but it doesnt spin. when i power off and power it on with disk in the drive it spins and does its normal thing but still no video an sound. everything worked fine the day before. Did no updates still at 3.3. Help someone please.
You can't post conmments that contain an email address.
You may be to close to the wii receptive piece. Try putting it above or bellow your tv (I have mine sitting on top) and sit back away from the screen. Also use steady movements, nothing too fast
The Wii has a known video problem. At fault is the nVidia video chip which gets hot and separates connections to the motherboard. The solution is on utube. Search for the oven solution for nVidia chips.
I AM NOT GOING TO AWNSER YOU Q BUT I CAN TELL YOU THAT THAT IS THE SAME THING THAT IS HAPPING TO OUR SO IF YOU GET THE SOLUTION BY ANY CHANCE WILL YOU LET ME KNOW
Hi, maybe you can take a try of this rescue program called BootSuite. I came across similar blue screen situaiton on my HP laptop (win 7) and it helped me get rid of it and rescued my data back. It is an awesome toolkit that includes a boot CD and several other data rescue tools that help get your PC going even if Windows won't start or computer won't boot up at all. Good luck.
Turn on the Wii console, when at the home screen press any button on the wii remote, if the lights on the wii remote remain dark then it needs new batteries.
If the lights all light up at the same time then stop this means you are not synced. Press the 1 and 2 buttons at the same time to sync, this will work if they have been synced before.
If your four lights still blink blue then you need to open the little compartment on the console that is right below the disc tray. Inside is a little red button, press the button. Now open your battery compartment on the wii remote and take out the battery, then press the red button inside. Put the battery back in and the controller should sync up. If you are still having trouble you will need to contact Nintenedo Technical Support.
you have to press A and then the remote buttons at the bottom will turn blue and make sure you have the gray thing that sits on top of ur tv is where you can directly aim the remote at and the little hands should appear.:) Hope it helps.:)
