Home | Humidifiers | Aprilaire 760 won't sta...
Humidifiers
Problem for Humidifiers
Generic problem for all Humidifiers
Aprilaire 760 won't start
By homeownernew on Dec 26, 2008
My humidifier wont start. I can hear a clickl when I rotate the humidistat from off position. But i never see the water flowing out of the solenoid valve. I changed the solenoid valve thinking it must be faulty, but still this wont work.
I am planning to check if the voltage (24V) is coming in to the solenoid valve. My other question is if i remove the front part (cover) of the humidifier from its base which has a power cord connected and plug it in, should the fan work?
What else should I do?
Sunny
Clarification Request
Posted by chowmix66 on Jan 02, 2009
does your humidistat have a test setting? and yes the fan should run when you plug it into a wll outlet. Steve
Same Problem
Dec 30, 2008
-   I do have the same problem- I hear a "click" when adjusting the humidity level but do not hear any fan motor/water flow. I have viewed both the control knob assembly and the fan/exchange unit attached to the air ducting flowing from the furnace. I have very little experience in household appliances, etc. but would appreciate any advice anyone may have!! Steve -   Guest
Solution #1
posted on Mar 29, 2009
Not Rated)
hvac teacher
Rank: Guru
Rating: 91%, 51 votes
No. when you remove the front cover it will automatically disconnect the power supply. Try changing the water panel and cleaning out the orifice and filter screens located in the water lines connected to the solenoid valve.
Was this helpful?
Yes
No
Popular Solutions for Humidifiers
Questions and Unsolved Problems for Humidifiers
Answer
I have a Lakso model 110 humidifier that needs a filter. Can you advise me where I can find... (More)
Answer
Hi, Could anyone please recommend filter free cool mist humidifiers (3-4 gallon). I am sick of... (More)
Answer
motor has burn't up
Answer
i threw out my directions & need to know instructions on how to propperly clean my...
Answer
how does one clean the humidifier? do you have to change the filter? where do you get more?
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Humidifiers:
Top Humidifier Experts
Rank: Guru Guru
Solutions: 1582
Experience: I run a Full-time Appliance Service Co.with HVAC/Auto Air Conditioning and Small Engine Service.
Ask Me
Find more Humidifier Experts
Top Air Conditioner Repair
Service and Repair, System Maintenance, Advantage...
Aire Serv Heating & Air Conditioning
ARS
(866) 800-3823
When it comes to air conditioning systems,...
ARS
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
