Question about Kenmore 63942 Dryer
Dryer not getting hot
I have a GE gas dryer not getting hot, where do i start trouble shooting?
  • 640 Answers
If you not technicail dont try,,,unit needs to be plug in for some tests...warning,,to start im thinking unit runs but dont heat..chech your operating thermastat first ,,next check yiur hi limit thermestat..they should be closed,,if good check your ignitor there should be 110 present..
Posted on Dec 26, 2008
My gas dryer wont ignite. where do I start trouble shooting
Model number would help but I'll give some general info. Most Kenmore dryers are usually made by Whirlpool so I'll give info for that type dryer. The 1st thing to check on a no heat is if the glow bar ignitor is coming on. At the cycle start it should glow red hot or orange. If no glow the glowbar may be burned out and needs replaced. This is the most common problem in a gas dryer. If you see the orange glow for about 15 seconds and it goes out ---that is normal. That usually means you may have a bad magnetic coil on the top of the gas valve. There are actually 2 coils on the valve and if either one goes bad the valve will not open and let gas through to ignite. They need tested with a multimeter. Thats the 2 most common problems with gas dryers.
Jun 24, 2015 | Kenmore Dryers
My GE DHDSR46 gas dryer won't start, what should I
505 is the thermal limit.
Looks like this:themobilian_2319.jpg
Hunt for junk and clean that out, then replace this fuse if it is bad.
See the white button to the right of the driver?
Thats the door switch, if open, that dryer won't run.
More Here
May 07, 2011 | General Electric DHDSR46GGWW Gas Dryer
Dryer is about 5 years old. Has begun to squeak loudly when clothes begin to spin
Are you comfortable taking the dyer apart? There are just a few simple screws to remove. It sounds like a bad blower wheel. If you follow the link you should be able to trouble shoot the issue.
http://sites.google.com/site/sublimeappliancerepair/washer-will-not-spin/agitator-woes/dryer-will-not-work/how-do-i-get-inside-my-dryer/gas-dryer-quits-heating/more-gas-dryer-enlightenment/gallery-of-dryer-parts-locations-and-diagrams/frigidaire-gibson-kelvanator-dryer-101/kenmore-whirlpool-englis-roper-dryer-notes/ge-dryer-repair/maytag-norge-amana-crosley-basic-repair-info
Mar 01, 2011 | Maytag Atlantis MDE6400AY Electric Dryer
The flame from my gas/fire that heats the dryer is shooting up too high and hitting the sensor, and then the sensor registers that it's too hot and shuts the heat off completely, therefore my clothes are...
it probably has ruined the sensor eye or dirtied it so it cannot let the gas valve open,by chance,has or was this unit on L.P. gas or Natural gas at one time and has been changed over to the other gas,as this will,due to the wrong orfice in the gas flow create an over size flame
Jan 26, 2011 | GE Profile Harmony DPGT750EC Electric...
My element turns on and the gas will light ocasionally.
If the igniter is glowing and even sometimes lights the burner, it's not the igniter that's bad. I've created a checklist that most homeowner's can use to trouble shoot dryer lighting problems. Click on my username, scroll down my profile to my tips and tricks for trouble shooting gas dryers.
Hopefully, one of these tips will solve your problem. Good luck.
May 18, 2010 | Amana NDG2330AW Gas Dryer
GE Dryer Model #DWSR483EB2WW Dryer tumbles,
Does it get hot when you start the dryer, and never gets hot again when its running? The solenoid wire might be opening due to heat, the solenoid is responsible for opening the gas valve, and booster valve. The wire is located in a round plastic sleeve with two electrical contacts sticking out.
Dec 11, 2009 | GE DBSR453EBWW Electric Dryer
Have a GE M# DDG9280GELWH gas dryer. Works fine but not firing-up to dry the clothes. Gas feed is fine. Is there an ignitor or other part causing the problem? How to trouble shoot? Gary
Make sure the lint filter, vent duct and vent outlet are not clogged blocking air flow. Then check the ignitor underneath the drum. (You have to open the panel to see it) It should glow shortly after the dryer starts, then the flame starts and the ignitor shuts off. If the ignitor does not glow then it or the thermostat is bad. If the ignitor is glowing but the gas does not light then the flame sensor may have to be replaced. If the gas ignites but does not stay on either the flame sensor or the coils are at fault.
See also: http://home.howstuffworks.com/how-to-repair-a-dryer.htm
Dec 08, 2009 | Audio Players & Recorders
Frigidaire gas dryer trouble shooting gas dryer taking too long t
Check the fins on the fan impeller. They may be covered in lint or not spinning adequately.
Mar 05, 2017 | Frigidaire FGQ332ES Gas Dryer
Kenmore 63942 Dryer Logo
105 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal De
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
