Question about Kenmore 15864/15862 Top Load Washer
Electrical clicking, motor lurching sound during spin cycle
110.28974891 Washing cycle worked great, no problems that I noticed. (granted I don't stand next to my washer everytime it washes) During the spin cycle however, my washing machine started a loud, fast clicking sound (about 4 or 5 clicks per second). When I went to inspect the noise, I saw that my ceiling light fixture was pulsing to the lurching sound coming from the motor. The spin cycle was not reaching top speed and was really irratic - slowish, then speed up a little, then slow again with no pattern or rythm. The click, the heave of the motor ,and the pulsating of my light fixture are all in unison. When the click would slow down, so would everything else.
I took all the clothes out, tried all the different spin cycles only to recieve the same results. I am very apprehensive about taking this thing apart, as I know nothing about washing machines. This does not sound like something that will just ''go away''. I've found this website informative, as your advisors sound very knowledgeable. I look forward to hearing a response. Thanks for your time. Please advise.
  • Greg Swedberg Dec 28, 2008
    This is not the issue. This washer has been on this circuit for last 6 years-- no issue. The machine has something wrong, not the electricity. Please try again.
  • 640 Answers
Its not your unit it your electricity,,you have to many thing on 1 breaker..the unit is asking for power ,,a washing machine needs a breaker of 15 amps by its self..put the unit on a oulet by its self..with no other load
Posted on Dec 26, 2008
4 Suggested Answers
onthejob5130
  • 640 Answers
SOURCE: Kenmore 90 series - clicking during slugish spinning cycle
try your unit on a outlet by it self ,,nothing can be on this line,,sounds like weak ampage,,this machine needs 15 amps line by it self...
Posted on Dec 28, 2008
  • 188 Answers
SOURCE: 110.28974891 Washing cycle worked great, During
Look for loose wiring connection at the motor capacitor (located beside the motor). Remove the connectors to the capacitor (one at a time), adjust connectors so they crimp the capacitor connection tabs tighter if necessary, and re-install. *Be very careful not to touch both capacitor connection tabs at the same time or you will get a good zap!*
If that doesn't help, you may have a defective motor.
Posted on Mar 02, 2009
blueextc3221
  • 15935 Answers
SOURCE: electrical lurching and click sound during spin cycle
It appears your motor controller or motor has failed in this instance.
For replacement parts - head on over to PartSelect.com or RepairClinic.com and enter in your full model number for a full parts listing.
I recommend both sites because ...
FixYa has no affiliation with either site - I have been using and recommending them for years - trouble free.
PartSelect has a great schematic database for locating the part on your unit and great "testimonials" for each part that often times includes HOW-TO information.
RepairClinic has pictures of each part they sell and also a great how-to and troubleshooting for basic repairs.
If your unit has never been serviced - there should still be an original service manual enclosed in plastic taped to the inside of the shell.
In the service manual are Error codes, maintenance procedures, and troubleshooting steps you can follow.
Anything too complicated or beyond your scope should be handled by a professional.
If you think you want to tackle the repair - and have gotten stuck on a step - reply to your question and I will be glad to help you out.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Posted on Sep 12, 2010
My washer will spin but very slowly. Motor and shaft spins out of washer.
Your problem sounds like the drum/tub drive clutch is worn. Especially if the motor operates fine and attempts to spin the tub. This model is a direct drive unit, no belts, so if the motor operates during the spin and drain cycles but the tub is barely moving, only two problems can cause this, bad clutch (which is engaged only during the spin cycles) or worn drive coupling on the motor. If the coupling were a problem, though, you would also notice sluggish or erratic agitation during the wash cycle.
Hope this helps
kcomp1863
Jan 04, 2011 | Roper RAS6233KQ Top Load Washer
Loud noise during washing/rinsing cycles
I just replaced the bearings on my Front loader Maytag MAH5500B, as it sounded like a freight train during the spin cycle. The bearing replacement fixed the train problem.
NEW PROBLEM NOW: It's been about a month now since the bearing job and now something is clicking/binding when you spin the back belt wheel. I have taken the belt off and carefully move the wheel and I still get this clicking noise. It sounds as if someone is hitting the plastic drum that the tub is surrounded by. I really doubt it's the bearings this soon, as the sound is not the same! No leaks or metal shavings to speak of or rubbing of the belt wheel.
Seems like it's more noticeable during the wash/rinse cycles then the spin.
Can anyone help.???
Oct 09, 2009 | Maytag Neptune MAH5500B Front Load Washer
Mar 01, 2009 | Kenmore 24032\24036 Top Load Washer
Washer making noise during the spin cycle
Hi!!! it looks like your motor coupler is failing..Good luck..
Jan 03, 2009 | Kenmore 24032\24036 Top Load Washer
Agitater does not spin
the transmission needs to be replaced
Jan 02, 2009 | Maytag Atlantis MAV6000 Top Load Washer
Dec 27, 2008 | Kenmore 24032\24036 Top Load Washer
Electrical lurching and click sound during spin cycle
Dec 26, 2008 | Washing Machines
Roper RAX7244EQ1 Vibrates during spin cycle
Dear customer
Please perform the following checks
This may be a spin problem or a drain problem
Drain:
  • Make sure the drain line is clear
  • Check the drain hose for a partial blockage
  • Inspect the water pump
Spin:
  • Test the lid switch
  • Test the timer control
  • Test the centrifugal switch
  • Test the water level switch
  • Inspect the motor coupler
  • Inspect the drive belt (belt drive only)
  • Inspect under the washer for soot (clutch)
  • Test the motor
  • Inspect the pulley
  • Test the transmission
Please rate this,Thank u
Nov 21, 2008 | Roper RAS8445KQ Top Load Washer
Lsb6300pw whirlpool topload
does it wash have you tried on wash since youve had the spin promblem
Jan 13, 2008 | Whirlpool LSB6300PW Top Load Washer
Kenmore 15864/15862 Top Load Washer Logo
175 people viewed this question
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
