Question about Frigidaire GLGF377 Gas Kitchen Range
Frigidaire Gallery GLGF377...oven works part of the time
Dear Expert,
I have a Frigidaire Gallery GLGF377AQF Free standing stove and cooktop. It does not heat up all the time. I will turn it on and it heats up to maybe 100 degrees. I will turn it off and immediately turn it back on and it does the same thing. Usually if I turn it off and wait a few minutes then start it up again, it will get to temperature. Seems intermittent and random. Other times it works fine.
Thanks for any help,
Pat
pconroy-criterium@sbcglobal.net
  • 150 Answers
SOURCE: frigdaire gallery stove
lock mechanism is acting up. happens sometimes. you can get to it from the back and get the thing open to use until you get the part
Posted on Apr 22, 2008
aborcass
  • 2651 Answers
SOURCE: A Broken Stove
whats the entire model number?? and you cracked the main top glass assy??? ill look up tha part for you, not a teribly hard job, but depending on glass may be expensive
Posted on Nov 17, 2008
tzweeb
  • 318 Answers
SOURCE: GAS STOVE - MODEL GLGF377 - FRIGIDAIRE - OVEN SMALL EXPLOSION
find the broken part and replace it. it really is that simple!!!!
now seriously, you need to explain what is wrong.
let us know what kind of problem you are having... ie. the oven glow bar glows but doesnt let gas in to heat.
if this is your problem then replace the glow-bar ignitor and that should fix it.
give us more info and we can help you out.
Posted on Jan 22, 2009
  • 7 Answers
SOURCE: How to lite a pilot lite on a frigidaire "Gallery" gas stove?
wet sparkers, let them dry out good
Posted on Jan 30, 2009
aborcass
  • 2651 Answers
SOURCE: Erratic/slow heating
sounds like an issue withthte ignitor in the oven cavity, part number 5303935066, easy to install comes with instuctions, be careful however teh parts pretty fragile
Posted on Mar 07, 2009
How do you remove the control panel on a slide in glass top frigidaire stove model CFES367DC2
Hey Tamara webber, thanks for your inquiry!
I see that you would like to remove the control panel on your Frigidaire range, CFES367DC2. . Regrettably, this is not a simple DIY job. I would highly recommend reaching out to an expert technician to ensure the appropriate replacement part is ordered and is installed correctly to prevent future issues. I hope this information helps to some degree and please do not hesitate to reconnect. -Matt
Jan 31, 2015 | Frigidaire Cooktops
Can I use Cast Iron Pots and Skillets on my new Frigidaire Gallery Stove Top?
Hello friend, thanks for your post!
It is not recommended to use any cast iron pots or skillets on a Frigidaire smooth top. In your manual it provides the best type of cookware material and cast iron is a poor heat conductor. Due to the weight of the cast iron it can cause scratches or damage the cooktop. I hope this information has been helpful. -Matt
Oct 09, 2014 | Kitchen Ranges
Frigidaire error code stove f 15
F15 Controller self check failed. Replace the EOC.
Here's the code explanation
Sep 06, 2014 | Frigidaire Gallery 30 Slide-In Electric...
Frigidaire gallery stove
Hello Debbie - Sounds like the unit has loss some of its heat inside of the oven cavity. This means it cannot reach the proper preheat temperature in the programmed 30 minute timeframe. A technician would be required to further diagnose this concern. They would most likely assess the convection heating element, thermal cutout, thermal oven sensor and all wired connections for repairs. Lastly the oven cavity and insulation should be checked to ensure there are no gaps or damages that will leak out the heat. At t his time, I would recommend contacting a professional to assist you further.
May 24, 2013 | Frigidaire 30" Self-Cleaning Freestanding...
My frigidaire gallery series oven made a popping noise while heating up dinner in oven and now the whole oven is not working
Hello jnjpelli - Try resetting the unit by unplugging it or flipping the household circuit breaker off. Wait approximately ten minutes and restart the unit. If the oven does not turned on, then more than likely there seems to be a power supply issue. Also try checking the breaker and the power connections located on the back of the range. If any of these suggestions prove to be ineffective, connect with a professional to accurately pinpoint any potentially more serious issues
Jan 19, 2013 | Frigidaire 30 in. Electric Gallery Series...
I have a Frigidaire Gallery Professional Series Stove and Oven unit. The oven temperature indicator light has been fading for years and is now barely visible. Everything else on the control panel (timer,...
Hello arab125 - I understand that the timer and clock works fine, however from what you have described it sounds like the range could possibly have a wiring failure, faulty sensor, or an issue with the EOC. I would suggest contacting a professional to move forward accurately.
Oct 08, 2012 | Frigidaire FGEF3031KB Gallery 30"...
Frigidaire Gallery stove top spark module is firing once every 30 seconds when turned off.
ok - this is a question regarding a stove - not a fridge - as indicated.
:D
If the ignitors on a gas stove top continuously spark and only stop when the electricity is turned off the problem may be a stuck relay.
Turn off the electricity (unplug) for a long period of time perhaps overnight. Sometimes the relay will automatically reset.
Aug 01, 2009 | Frigidaire Gallery Series GLHS269ZDB 36"...
Frigidaire GLGF377 Gas Kitchen Range Logo
103 people viewed this question
Top Frigidaire Kitchen Ranges Experts
Ismael Rodriguez...
Paul Carew
Justin Duby
Justin Duby
Are you a Frigidaire Kitchen Range Expert? Answer questions, earn points and help others
