Question about GE 30 in. JP340 Electric Cooktop
I have a broken ceramic top on my GE stove JBP66EOR4BB
Is there an easy way to fix this ? Thanks
We went to get a plate for Santa's cookies, and the plate hit the stove top.We'll let him find his own cookies next year !
Thanks for your help with this !
  • tommcquade Dec 26, 2008
    Could you please tell me how to replace the ceramic stove top,and the parts and tools needed to replace ?Where can I obtain the parts. It is a GE JBP66EOR4BB. Thank you very much.
  • 61 Answers
Unfortunatly you will have to order a new glass top from a local G.E. parts supplier. Jot down the model & serial of the cooktop and call them for a price. The unit will have to be raised out of the cut out to change. Purchase the part have a look at it then make the decision whether you can do it yourself or not good luck
Posted on Dec 26, 2008
    Sergeant:
    Novelist:
  • 327 Answers
U can get the parts at  www.repairclinic.com and its not very costly and easily replacable Just a note when you're doing this... when you open up the top, put a towel across each side so that when you drop a clip, it doesn't go down the side between the oven and the outside wall. If it does, hope that it goes all the way to the bottom where you can get at it by removing the bottom drawer. If you put the towel all the way across the oven box before you start taking things apart, you also won't have to worry about where little tiny screws go when you drop them... and, you will drop them! ;-)
Also, the old tops had a reinforcement bar that the ground was attached to. The new ones don't. There's a tiny hole on the flange of one of the right hand burner holes... that's where the ground is supposed to go on the new top. You WILL need a smaller self tapping screw than the original one.
And, forget having a helper... get something to prop the lid open with that won't fall if you raise the lid a little while you're working on it. Helper will just get in the way and can't hold it still enough while you''re trying to man handle those tiny little clips and screws that hold the burners in place.
  • 100 Answers
The parts required can be purcgased from the link below.it will also provide u with the guide to replacement procedure if u buy parts from them.recommended link is as follows:
http://www.partselect.com/GE-Cooktop-Parts.htm
  • 4,472 Answers
Http://www.repairclinic.com/Parts?s=t-GE+JBP66EOR4BB-%3d%3d&n=2&z=10
Follow this link it has all the parts for your oven. If you need further assistance let me know. Please take a moment to accept and rate my solution accordingly.
Thank you,
Lee
    Top Expert:
  • GE Master
  • 82,285 Answers
U can't fix it but it can be replaced.
Burners ceramic top stove
FIXYA has no agents and have no idea who can assist you there
Dec 15, 2017 | Creda Cooktops
Maytag ceramic top stove with the double oven, two small burners don't get hot anymore can I fix myself and how?
It is simple . Before the process make sure the the power is off .. There screws on the back after removing them you can lift the top n easily remove the none working ones . You can buy the spear ones online or local shop . I have done it myself or search YouTube with model number youse come a cross with repair option . Good luck .
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/sam_bbe602d2c68da69b
Aug 06, 2013 | Cooktops
Gas ignitor keeps trying to ignite after stove is off.
Hi and welcome to FixYa. I am Kelly. On your cook-top the gas igniters are cycled on and off by a ceramic and copper switch on the front of each of the gas valves. Some of them are in wired Series ...i.e any burner on will cycle all igniters on the cook top and some of them are in Parallel where individual burners are controlled by each gas burner control knob. Inside these tiny ceramic switches there is a flat thin strip of copper that as the gas valve is rotated a cam of the switch actuates pushes the copper strip against the fixed contact. Those little strips over time either break or get bent and stay against the fixed contact. Hence you have and igniter on when the burner control is off. The only fix is to find out which little ceramic switch on the front of the gas valve is stuck. You do it with an Ohm meter POWER off. They all should read open with the burner controls off. The one that reads continuity across the 2 wires is the bad switch.
Thanks for Choosing FixYa.
Kelly
Sep 13, 2010 | GE Cooktops
Want a narrow ceramic cook top / hob
Look at Baumatic 90cm Slimline 4 Hyperspeed Zone Ceramic Hob. Dimensions are 350mm x 880mm
Apr 26, 2010 | DeLonghi Cooktops
Stove plates have three settings. High, med, low.
60 years old . quite possibly not worth fixing .
Mar 05, 2017 | GE Cooktops
I have a whirlpool drop in ceramic stove and a burner isnt working. i had a repair man come and he was trying to pry the stove up but was having trouble because the person that insatlled it years ago...
When you dont replace the ceramic top that ios cracked could cause issues in your circuit board. The best thing t do is buy a new stove. The parts nad labor along is going to cost you about the same price as a new one.
Apr 25, 2009 | Stoves 23 in. Premier TC600I Electric...
Whirlpool Gold ceramic cooktop removal.
the safest way for a home owner to do this is turn the main breaker off to the house that is the safest way. Then poll the cover plate off the box in th wall with the two screws. not the screws on the round conduit. Then pull out the wire nuts that hold the wires together and un screw them to separate wires I would label them so you know what ones went together. After top is in just reverse the proses above.
Dec 14, 2008 | Cooktops
I need to remove my Whirlpool Gold ceramic cooktop.
Dec 14, 2008 | Jenn-Air JED8430 Electric Cooktop
Ceramic Glass broken
when ordering you would have to know the color also
Dec 05, 2008 | GE 30 in. JP340 Electric Cooktop
Just bought a house, no manuals
After a pot spillover, the cleanup process triggered my stove top to "control lock"
I removed the pot and once the stove top cooled I pressed and held the "control lock" button.
It began to blink, I released it and then the light went off and the stove top operated normally.
You might not have to wait for the stove top to cool. I don't know.
Aug 24, 2008 | GE Profile JP930 Electric Cooktop
GE 30 in. JP340 Electric Cooktop Logo
54 people viewed this question
Top GE Cooktops Experts
Marvin
Marvin
Dave Harrison
80stech
Are you a GE Cooktop Expert? Answer questions, earn points and help others
