Question about Cyberhome DVR 1600 DVD Recorder
1600 DVR disc don't spin anymore
The unit was acting strange so I took off the outer cover and the metal plate inside that has the white plastic 1 and 1/2 " circular disk with a small metal inner disk that's less then a 1/4" across. This interfaces with the inner black disk that is attached to the gray plate that is just underneath the loading tray. You can feel the magnetic pull as you interface the two together. The problem is nothing spins up. I own a Cyberhome 300 and the mechanism seems almost the same and when you load a disk in, it spins up immediately. Is there any fix or special way the two disk are suppose to interface that will make it spin again? The unit seems to be fine in all other areas, comes on, shows the time, the tray opens etc but simply will not spin up.
    Genius:
  • 1,074 Answers
Check the motor it could be bad.good luck.
Posted on Apr 19, 2007
Cyberhome 1200 dvr
First the Dvr 1200 has hard ware failure in it the tray eject unit and the display is failed ........................................it can fix in local service center.............................
Second your New DVR 1600 check the format of the dvd is it compactiable with format of the player and if face the same problem get it replaced as this is new player manual opening could lead no warranty on the player , it better to get it replaced ..
May 30, 2008 | Cyberhome DVR 1600 DVD Recorder
Licence plate falling off
why not drill to seperate holes and put self tapping bolts in to hold it on simple fix
Mar 05, 2010 | 2003 Nissan Murano
No spin
Power off the mains. The filter is located behind the silver plate at the back of the machine at the bottom. Four screws hold it on. Drain out all the water. The filter is inside the big black rubber hose attached between the pump and the main drum. Remove the plastic clip holding it to the pump unit and then the metal cir clip holding it to the main drum. Inside is a white molded cone and a big white ball which floats. You will find a lot of junk here, clean out thoroughly. To refit put white cone back inside just as you found it, at the bottom, fit ball back into the cone. Attach to the bottom to the drum and re-fasten the cir clip. Finally reconnect the gator to the pump unit and tighten the plastic clip. Check out the pump too before reconnecting.
And rate me plz……………………….
Apr 10, 2009 | Washing Machines
Cyberhome DVR 1600, where can I get the firmware update
Hi there
The best bet now the company has gone bust is trawl through the forums to see in anyone has a firmware upgrade saved and available for download. Here is a good start.
http://www.avforums.com/forums/index.php
Good luck and thanks for using Fixya!!
Feb 19, 2009 | Cyberhome DVD Recorder - DVR1600
Liteon LVW-1105HC will not record
I had the same problem.
This is what worked like a charm for me:
Take off the top cover and locate the drive.
On top of the drive will be a metal plate with a plastic circle in the middle.
This holds the disk in place when spinning.
Locate 2 little black screws which holds the plate on.
Loosen the screws slightly until the the tray opens.
If it is too tight the tray gets stuck.
I put two tiny pieces of double sided tape, about 1/16 of an inch, as spacers next to the screw holes so the plate stays tight.
It may not be necessary but I did it anyway.
Good luck and I hope it works for you too.
Feb 14, 2009 | Lite On LVW-5115GHC+ DVD Recorder
No disc displayed
The disc won't spin until the unit recognizes that there is actually a disc there. Try cleaning the lens using a cotton swab and alcohol. If that fails, try playing a CD. If the CD plays, the optics are starting to fail as reading a DVD requires higher laser power.
Dan
Mar 19, 2008 | Cyberhome DVR 1600 DVD Recorder
Need 3 digit remote code for Cyberhome DVR 1600 PLEASE HELP!!!
Don't know if this is what your looking for but give it a try.
How to convert your CyberHome CH-DVR 1600
into a Region Free DVD Player
There are two versions of the Cyberhome DVR 1600 which require different methods of changing the Region Coding
CH-DVR 1600 MU
  1. Power Up the unit with NO Disc in the tray.
  2. Press the Setup button on your remote control
  3. Press the 1 button on your remote control
  4. Press the 6 button on your remote control
  5. Press the 9 button on your remote control
  6. Press the 5 button on your remote control
  7. Press the 1 button on your remote control
  8. Press the 8 button on your remote control
  9. Select the region code with the Number buttons or the Navigation Buttons on your remote control. 0 (Zero) for Multiregion.
  10. Exit the menu
  11. Press the Power Off button on your remote control
  12. Press the Power On button on your remote control
CH-DVR 1600 ZU
  3. Press the Red Record button on your remote control
  4. Press the 8 button on your remote control
  5. Press the 1 button on your remote control
  6. Press the 0 button on your remote control
  7. Press the 5 button on your remote control
  8. Press the Red Record button on your remote control
  10. Press the Setup button on your remote control
Jan 02, 2008 | Cyberhome DVR 1600 DVD Recorder
DVD RW stucked - stall the whole system.
Hi, I found this site today cos I had a similar problem. To cut a long story short I found a slot on the bottom of the machine, below the disc tray, that has a white lever in it. After removing the power source I moved the lever to the side and the tray opened manually so I could remove the disc. It seems It was a duff DVDR as other discs now work fine. Good luck !
Oct 15, 2007 | Philips DVDR3440H DVD Recorder/HDD...
Disc loading problem
disk draw timing is probably out ( gear or mechanism jumped out of time
Jan 23, 2007 | Cyberhome DVR 1600 DVD Recorder
Cyberhome DVR 1600 DVD Recorder Logo
Top Cyberhome Televison & Video Experts
zappal
Demonic-2011
Demonic-2011
Are you a Cyberhome Televison and Video Expert? Answer questions, earn points and help others
