I have attached the AC Power Adapter, and it powers up the Boombox & Sirius Plug n Play Radio for about 3 seconds, then the "Low Battery - Powering Down" message comes on and it shuts off completely.
This is a recurring problem on more than one Boombox of this type that I have owned.
Would switch to powering by 8 "D" batteries, but cannot figure out how to change the power source.
Please help if you can. Thanks - Mark
Comments:
Jan 02, 2009
- Thanks for trying, and usually you might be correct. However, in this case, there is no alternative power switch at the rear or bottom of the unit. And while I plugged it into the AC Power Unit and left if for many hours, the unit only powered up for less than 1 minute before giving the same "Low Battery - Powering Down" message and shutting off. I even downloaded the unit's manual, and it says nothing of an alternative power source switch - just that it runs for up to 9 hours on 8 "D" batteries - which I put in new and nothing happens. Also, no mention of this problem in the "Troubleshooting" area of the manual. Given that at least 3 or 4 others have had this same problem, and no one else has posted an answer, I can only assume that it is a flaw in the basis design of the unit. I am going to contact the manufacturer in CA and complain.
-   Same problem here. No company and/or manufacturer will admit having reported problems fearing massive return request but, they all know about it otherwise why would a struggling company, like Sirius, spend the money to make a SUBX-2!!
If it was a fuse there wouldn't be any power too the unit at all. The problem is the connection point on the Boombox. I guess it was poor oversight at the China plant.
-   I have had the same exact problem over the last couple years. I've gone through 3 or 4 of them and all ended up with the same problem. The last one we had we bought in may 2008 new from the store. This time around we decided to use only battery power, thinking maybe the ones previously got fried from our outlets. By Jan2009, same issue low battery- so we took the batteries out and tried to plug it in direct to the outlet still same message. I also think this is a defect!
-   Guest
The power srouce is usaly locate at the back of the stero.. if it isnt.. its at the bottom. I would als try pluging it in.. and leaving it for a dayu... becuase maybe it charges
Have been playing my ipod thru my sirius universal boombox with no problems but lately when power is...
(More)
Have been playing my ipod thru my sirius universal boombox with no problems but lately when power is turned on the power indicator light turns red and blinks and cannot get my ipod to play then all of a sudden the indicator light will turn green and the music will play. The last few tries the light remains red and is blinking never getting the ipod to play. Can you offer any help? Oscar (Texas)
I have a sirius ST-B2R boombox and want to play my ipod through it. I put the ipod onto the audio...
(More)
I have a sirius ST-B2R boombox and want to play my ipod through it. I put the ipod onto the audio jack and it plays for about 10 seconds then goes off. Any suggestions
My boom box will not turn on.. I switched the plug to a different outlet. And previously it would...
(More)
My boom box will not turn on.. I switched the plug to a different outlet. And previously it would randomly turn off saying low battery power when it is plugged I. Do I need to buy a new radio?
the antenna connector in the back of sirius boombox is broken. would like to purchase a new antenna...
(More)
the antenna connector in the back of sirius boombox is broken. would like to purchase a new antenna harness for boombox but cant find replacement parts for internals
