Question about Breadman TR2200C Ultimate Bread Maker
Not rising and meally texture
I used hawaiian bread mix mulitiple times, tried different settings but just does not rise to 2lb and is very meally.
  • 368 Answers
Hello psaulina,
When I hear of bread not rising, I always suspect the yeast first.
You said you've used the hawaiian bread mix multiple times. From the same container? Or have you tried multiple different packages (hopefully from different production lots)?
Back in the day when my Mom was baking bread on a regular basis, she'd occasionally get a bad batch of yeast, and the bread would be the weight and consistency of fruitcake, but with somewhat less flavor. (We ate it anyway).
If your yeast is separate from the bread mix (don't know, you didn't specify), you need to first check the quality of your yeast. If the yeast is too old, or just bad, your bread won't rise.
To test the yeast, mix a sample in warm water (~105 deg. F) and add a little sugar. If the yeast is good, it should start forming bubbles. No bubbles, time to get new(er) yeast.
If your yeast checks-out, then you need to see if something in the machine's process is overheating the yeast too soon - - the yeast's fermentation process creates the carbon dioxide (CO2) bubbles that causes the bread to rise (sort of like inflating a balloon, if you like). If something is killing the yeast (e.g. too much heat too early in the process), it won't react and create the bubbles.
If I can be of further assistance, let me know. If this helps or solves the issue, please rate it accordingly.
Good luck, and thanks in-advance for your rating,
Jon
Posted on Dec 28, 2008
How long should bread knead in the machine
Depends on the texture you are looking for. Typically a machine has a pre-set program that kneads a certain time and shuts off. If you are using a recipe that is a bread that you make by hand, you could use the machine to knead the bread and rise the first time, then punch it down, knead by hand and form a loaf and bake in oven.
Oct 17, 2014 | Kitchen Appliances - Others
How can i fix dough that wont rise?
Check if yeast is old out of date, expired. When making bread most items should be at room temperature unless the recipe calls for milk to be heated to a certain temperature. Follow instructions carefully. Note the differences in Canadian and American flour you will need more American flour if you are using American flour in a Canadian recipe. When making bread the type and or brand of flour will effect the outcome , humidity also affects bread. As to the outcome of bread kneading , resting, texture are something you learn. If dough is to dry add 1 tablespoon of water at a time , if too wet add 1tablespoon flour, dough should neither be sticky or to dry , should feel like silk . Seasons change the affect of how flour works. Drafts also effect dough, when dough is left to rise it should be placed in a place away from drafts and is warm. A well greased bowl large enough so that the dough can double in size this usually takes about 1 hour don't rush this part. Dough should be greased on top so it will not stick to what it covered with. Once the dough has doubled in size punch it once done, either cut into loafs or into buns, place desired greased pans cover let rise again about one hour. Put in oven set at required temperature , set timer for 15 min, check for brownness, if it is not to your liking leave it oven for another 5 mins, bread or bun's are done when they are tapped on top and it sounds hollow take out of oven let rest in pans for about 5 min's, place cooked bread on rack and let cool, do not place on flat surface as the bottom will sweat it needs to have air flow all around it to cool properly. PS remember making of bread is a labour of love, because it lets you take out any anger while you beat and fold the dough, the dough loves you for this and it will give back to you a light and airy texture. Keep on loving.
Aug 04, 2014 | Baking
Use wooworths elevation breadmaker
A bread machine that works correctly goes through these basic cycles. If your machine did not do this then it is broken and you need to replace it. The cycles are, Mix.....Rise....Mix......Rise....very short Mix of a few seconds....final rise of over 1/2 hour......bake of approximately one hour......I sell good used machines that will come with a full money back 30 dayguarantee (shipping, everything) You can reach me at daryl441@msn.com or my website breadmachineshelp.com
Jul 02, 2013 | Kitchen Appliances - Others
Bread does not rise enough I have carefully measured ingredients use rapid bake setting fleichmans rapid rise yeast checked water temp still having problems I have tried 4 times regular and rapid rise and...
A few tips.
The yeast must be absolutely fresh, use sachets instead of packets.
Keep yeast well away from the fats and liquids.
The fast rise setting will produce less rise than the full program.
You must only use strong bread flour.
Open lid immediately beep sounds.
Jan 10, 2011 | Panasonic SD-YD250 Bread Maker
Our bread has not been rising, and so it comes out sort of hard and misshapen. We've been using the rapid course, and have been adjusting the amount of rapid rise yeast
The rapid rise will not produce as good a texture of bread as the normal full program. Never let the yeast come into contact with liquids or fats in the pan. It must stay dry.
Dec 15, 2010 | Breadman Pro Dual Bread Maker
Bread is not rising. I have used two different mixes and neither rises....thwy both have yeast and i have not had this problem before with this brand. i am wondering if there is something wrong with the...
If the machine is heating up and there is no burning on the set heat that you have chosen then I dont think it can be the fault of the micro wave .
If there is burning on the sides or the bottom , then reduce the power rating and extend the timing. But if the cake seems fine, the batter is evenly cooked , the I suppose the fault can be the mix by itselt.
I recommend that you must try with new yeast, maybe the one you have used is old and ineffective. Use a good mix preferably good whipping.I am sure the next time your cake will be great.
Comment.
Aug 27, 2010 | Microwave Ovens
Bread comes out hard, dense, lump
I had a similar concern with a different breadmaker. Finally gave up and settled for a different setting and it seems to mix, and rise fine but have to settle for a different texture/hardness for the crust. I can only guess some computer chip has failed in that setting!
Mar 13, 2009 | Toastmaster 1183N Bread Maker
The bread only rises about half way.
After its mixed the ingredients and before it cooks, it should sit for a while to allow the mix to rise. Check that the heater is on in this period, otherwise, if its cold, it wont rise
Feb 14, 2009 | Betty Crocker BCF1690 Bread Maker
Half sized dish shaped wholemeal bread
Hi
I had a similar problem in making sourdough bread and noted on some websites the importance of correct salt and surgar quantities for rising. I increased my quantities to correct the problem. Of course the recipe was different but it may help.
Jan 28, 2008 | Welbilt ABMIL2P Bread Maker
Bread won't rise
We have owned a Panasonic bread maker for ten years and gets used twice a week to make bread using "spelt " flour.About three years ago the bread maker was producing flat loaves,and was very heavy.We contacted bread making company called "Simply No Knead"and asked for there advise,as we were following the same recipe and method for around six years. They suggested that we add a little more water,and this would fix the problem.We tried this and the bread still failed to rise,so we rang them again .This time they said that we need a new bearing in the bread maker and that would fix it.We did this at a cost of $40 and still no good.This happened over a period of several months.We suggested to them that there must be something wrong with the flour,which they denied.After checking the labels on the packaging we noticed that they were using flour from another country [ I think it was Hungary ],because they had run out of suppies from Australian wheat produces.
The flour was far to old,and bread won't rise if the flour is to old. As soon as they started using Australian produced flour again the bread improved dramatically.
Hope this is helpful to you
Dec 11, 2007 | Breadman TR875 Bread Maker
Breadman TR2200C Ultimate Bread Maker Logo
183 people viewed this question
Top Breadman Kitchen Appliances - Others Experts
Irene Tulloch
Steve Allison
Steve Allison
Hjalmer Lamminen
Hjalmer Lamminen
Are you a Breadman Kitchen Appliances - Other Expert? Answer questions, earn points and help others
