Question about Sony Handycam CCD-TRV68 Camcorder
Sony ccd-trv68 dosen't always power up when turned on? tried 2 different batteries sometimes it will turn on for a short period of time, then shut off. when i plug the power cord in the charge lite comes on then turns off after a min or so? when it powers up i can work the camera. when it suhts off i'll try the same thing again plug the ac cord in this time nothing happens no charge lite. please help ty jay
    Sergeant:
    Champion:
  • 319 Answers
Unit has circuit problems, have serviced
Posted on Aug 14, 2008
I have an older camcorder that hasn't been used in a while. When I went to try to view the tapes made on the camera, I just get a blue screen with a white play arrow. The tape is moving inside though. It...
The video drum inside the tape mechanism consists of two sets of heads. One set for recording and one for playback. It's possible the playback heads are damaged, in which case the video drum will need to be replaced. It's also possible the video drum may simply be oxidized in and the camera only needs servicing and the drum deoxidized. I don't reccomend using "cleanning tapes" as they can sometimes do more harm thab good although you try. You might get lucky and this will solve your problem.
Aug 03, 2010 | Sony Handycam CCD-TRV68 Camcorder
I have a sony camcorder CCD TRV68 & door for tape is "stuck" with tape inside. How do I eject/fix?
Hi-
can you still turn the unit on? Turn it off, remove the battery for a few minutes and reinstall it. then turn it on and try ejecting it.
Hope this help
Jul 16, 2008 | Cameras
Tape will not run
The "will not run problem" was solved by replacing the CR-2025 Lithium battery. The eject symbol continues to appear sometimes and I can remove it and continue operating the camera by turning the power supply "Off then On" again. Camera is now running a recorded cassette but quality of picture is low.
Jan 14, 2010 | Sony Handycam CCD-TRV68 Camcorder
Manual for camcorder/sony-HI8 camcorder-ccd-trv68eE9EVT.HTML SONY CCD-TRV68 HANDYCAM
Download the manual from:
http://www.henrys.com/manuals/sony/CCD-TRV58(En).pdf
Please rate this solution as it helps us in helping you and others like you.
Sep 08, 2009 | Sony Video Cameras
How to transfer hi-8 tape to cd or dvd pls teach me
You can set the date and time by following the steps in the instructions manual which can be found by following the link below.
http://www.retrevo.com/support/Sony-CCD-TRV68-Camcorders-manual/id/763dj989/t/2/
Hope it helps,
~regards,
Jegan
Jun 03, 2009 | Sony Handycam CCD-TRV68 Camcorder
Ccdtrv608 sony handycam stuck in nightshot mode
Below image of CCD-TRV608 shows NightShot Button location, turn it Off for normal mode recording.
Mar 24, 2009 | Sony Handycam CCD-TRV68 Camcorder
How do I change internal clock battery in sony trv68 hi8 camcorde
There is an internal battery, but it is a built in and I don't believe it can be removed. However there are clear instructions in the manual on page 69 that detail the steps you should go thru to recharge the exhausted lithium battery for the date.
Here's a link to the manual
Dec 11, 2008 | Sony Handycam CCD-TRV68 Camcorder
Unknown sign
Most likely the lithium Ion battery has been discharged. Leave it plugged in for 24 hours without turning it on and it should charge the battery.
Sep 11, 2008 | Sony Handycam CCD-TRV68 Camcorder
No power and does not indicate charging Problem
Sony camcorders C:31:23 error
Take the battery out and turn selection switch to camera and then turn it off. Put the battery back in and its working again.
if that doesn't work try
Try smacking the side of the camera relatively hard with the palm of your hand. Eject the tape and reinsert. You may need to do this a couple of times.
good luck
please mark the post with a fixya
Mar 17, 2008 | Sony Handycam CCD-TRV68 Camcorder
Handycam CCD-TRV68 control panel/tape door acting like it died.
In order to solve this problem please order the control switch block (control pad) pn: 147642411. If you need more info please advice.
Mar 28, 2007 | Sony Handycam CCD-TRV68 Camcorder
Sony Handycam CCD-TRV68 Camcorder Logo
111 people viewed this question
Top Sony Video Cameras Experts
Parshiv Luthra
Jose Ma DM.
Jose Ma DM.
Are you a Sony Video Camera Expert? Answer questions, earn points and help others
