Question about Kenmore 44042 Front Load Washer
I get a code E 10
If you could please tell what this E 10 means. It runs in the wash cycle then half way thru this code comes on and the washer stop
  • 15,935 Answers
Over sudsing. use He soap only.
Posted on Dec 26, 2008
Bosch washer E12 error. About 10 minutes into washing, the washer stop with half a tank of water in it. I'm able to run a drain and spin cycle afterward to drain the water out.
E12 mean washer take to long to fill check inlet valve an made sure the drain hose is at right high were the washer not siphon out ok
Dec 22, 2017 | Bosch Washing Machines
What does 5ud mean 10 minutes from finishing 5 Ud displayed can't open door?
The SUD (not 5UD) code is displayed when excess foam is detected (possibly because excessive detergent is being used). If your machine does not cure itself, you may have to run an "Eco drum clean" cycle (if your machine has it) or a 90 degree cotton cycle with no detergent and no load.
Aug 29, 2016 | Samsung Washing Machines
Washer stops running and displays code SUD. The water doesn't drain until It's put on the rinse/spin cycle.
Make sure you are using HE (High Efficiency)detergent. The codes could mean your washer is telling you it has used a built in "SUD" routine during final rinse
Jul 18, 2015 | Whirlpool Duet GHW9150P Front Load Washer
Indesit widl102 washer dryer has 2 led lights flashin
unplug it for a few minutes and plug it back in again might be a pain but till you can get it serviced it should delete the fault code and run thru a full cycle. hope this helps a little.
Not a true fix just a work around.
best to you.
Nov 30, 2017 | Indesit W 123 Front Load Washer
Cycle ctopped and is flashing f 05
F05 means pressure jammed on full.
Check pump for blockage, or filter if waher has one.
Please rate my solution.
Jun 21, 2009 | Hotpoint Ultima WF865 Front Load Washer
Stops about half way thru cycle anf error code HF appears
F/H No water detected entering machine or Pressure switch trip not detected.
If after 30 seconds the control does not detect water entering machine and then valves will be turned off and the error code will be displayed.
If the control has turned the water valves on and after 8 minutes the flow meter has detected 10.5 gallons of water passing through it, but has not detected the pressure switch trip, the valves will be turned off and the error code will flash.
Press PAUSE/CANCEL twice to clear the display.
If there is no water in the unit:
1. Make sure that both valves at the water source(s) are turned on all the way.
2. Check for plugged or kinked inlet hoses or plugged screens in the inlet valves
3. Verify inlet valve operation
If there is water in the unit:
1. Verify Drain pump operation
2. Pressure Switch Hose is in good condition and properly connected to Tub and Pressure switch
Verify there is not a siphon problem
Verify wire harness connections to:Inlet Valves, Pressure Switch, Drain Pump, Flow Meter, and Central Control Unit (CCU)
Check all hoses for possible leaks
Verify pressure switch operation
Verify flow meter operation
Verify CCU operation.
Nov 21, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Smeg WD1 12C, error code 10
I have a smeg wd1 12c washer dryer showing error code e01 any idea how to fix it?
Nov 06, 2008 | Smeg WDI12 Front Load Washer / Dryer
Washer wont rinse
we had the same problem with ours....nd means not draining and that means that there is something, probably coins stuck in your drain hose. pull the drain hose out and check it for change and make sure something isn't stuck.
Jul 21, 2008 | Maytag Neptune MAH9700 Front Load Washer
Kenmore 22082
OL on my washing machine
May 17, 2008 | Kenmore 22062 Top Load Washer
Kenmore 44042 Front Load Washer Logo
83 people viewed this question
Sal De
 Brian Main
Brian Main
