Question about Bissell 9500 ProHeat 2X CleanShot Upright Deep Cleaner, Red Berends Vacuum
The water does not shoot out of my bissell proheat shampooer. The red spinner has stopped spinning.
  • 3 Answers
I'm not sure I have the same kind of machine as you because I don't think I have a red spinner. However, I did have the problem of water not shooting out (although the solution was being used up, just not the water). The problem turned out to be the plug underneath the main tank. To find out if this is your problem, lift out the main tank and take it to the sink. Feel underneath for the plug. Push inside of it. Water should squirt out (assuming there is water in your tank). If it doesn't, turn the tank over, unscrew the plug, and push the thing inside until you get it to spring up and down. If it won't do that, you might need a new one. If it springs, screw it back and try your machine again. Mine worked good as new after I did this. Good luck!
Posted on Dec 29, 2008
My bissell proheat 2x carpet shampooer will not put out any water
Have you cleaned the filters? Check your User's Guide for directions. One is located under the Water Tank Cap (small screen) the other is under the Flow Indicator. Bissell Consumer Care 1-800-237-7691 Hope that helps.
Jun 23, 2014 | Bissell 9500 ProHeat 2X CleanShot Upright...
Bissell Proheat 1699-5 won't spray, belt ok
Hi There,
It sounds like to me that this may be your pump. The newer ProHeat 2X models actually have a Silinoid problem right now which is more common then the pump going bad, but if you have the original ProHeat series, then it sounds lik you have a bad pump.
Here's a link to a very, very helpful repair guide directly from Bissell that will explain to you step by step how to trouble shoot, and replace the pump if needed. I would be lost on the ProHeat series without this handy repair guide.
I'm pretty knowledgable now on these machines, if you need some help or some clarification on how to repair this, please feel free to reply to this repair by using the Clarification request form. If you found this helpful, please be so kind and rate my repair, and give feedback.
Here's the link:
http://lib.store.yahoo.net/lib/vacuumcleanerbacgs/bissell-proheat-repair-guide.pdf
Thanks again,
Chris Jones
GoVacuum.com
Apr 19, 2010 | Bissell 7901-1 ProHeat Scotchgard Upright...
How to change the belt on my bissell 12amps powerheat shampooer,
the belt is simple there is a door on the side of the machine remove it and you will have easy access to the belt. For the other problem use this repair guide.
http://newzealand.bissell.com/images/IncludeContent/Service_Center_Help/Troubleshooting_ProHeat2X_9400F.pdf
Apr 17, 2009 | Bissell 1699 ProHeat Clear View Upright...
The Water will not spray out(it just dribbles) of the shampooer
Here is a tip that will give you all the information you need to fix your BissellProheat Vacuum Problem.
Bissell Proheat Upright Wet/Dry Vacuum Problems
heatman101
ewrtwy
Nov 27, 2008 | Bissell 9500 ProHeat 2X CleanShot Upright...
Bissell won't release soapy water solution
heatman101
hjf
Nov 14, 2008 | Bissell 9500 ProHeat 2X CleanShot Upright...
Want to Buy a Repair Manual for Bissell Proheat 9500 Clean Shot
I have the manual and would be more than willing to share...contact me at brewcrew2u@aol.com
Aug 19, 2008 | Bissell 9500 ProHeat 2X CleanShot Upright...
Older Bissell Proheat 12 amp black shampooer, BLADDER separate / LEAKS
Depending on the model yes:
Google turned up several sites -
http://www.svcvacuum.com/bissell/tanks.htm
You can also look at Bissell www.bissell.com
Jun 24, 2008 | Bissell 9500 ProHeat 2X CleanShot Upright...
Bissell 9500 ProHeat 2X CleanShot Upright Deep Cleaner, Red Berends Vacuum Logo
156 people viewed this question
Top Bissell Vacuums Experts
Jim Thurston
Are you a Bissell Vacuum Expert? Answer questions, earn points and help others
