Question about Minolta XG-A 35mm SLR Camera
Mirror problems I have a minolta xg-a 35 mm camera. When I look through the view finder all I see is black. When I take the lens off the mirror is in the "up" position and will not stay down. Can this be fixed ?
  • cesar8 May 17, 2009
    The mirror will not stay down and I cant see anything through the eyepiece but black.
    Problem Solver:
  • 5 Answers
Could be 1 of two things: 1. Mirror linkage failed. 2. Something is holding the mirror; sticky foam or the lubrication has dried out. Remove the lens, use slow shutter speed to release the shutter. While mirror is stuck in the up position, very gently pull down on the front edge of the mirror. If it frees up immediately it was stuck on the foam. Might be able to see a mark on edge of mirror from the foam. Hope this helps.
Posted on Apr 23, 2007
SOURCE:
Can i use tamron 90-300 mm af macro on my minolta 404 si dynax ?
Tamron makes lenses with a variety of lens mounts. If the lens has a Minolta mount then yes, you may use it with your camera.
Sep 21, 2013 | Konica Minolta Minolta Dynax 404 Si 35 Mm...
Minolta x700 cannot see through the lens. help
Which lens? Is this happening with just one lens, or with every lens you mount on the camera?
If you remove the lens and look through it, can you see light? Perhaps an upside-down view of whatever is on the other side?
If you look into the camera body after removing the lens, do you see a mirror at a 45-degree angle?
Aug 28, 2013 | Minolta X-700 35mm SLR Camera
WHEN I LOOK THE THE VIEW FINDER IT IS VERY DARK.
mirror is struck to ground glass/failure of the mirror mechnism
Mar 02, 2010 | Minolta XG-A 35mm SLR Camera
Does the minolta xg-a have to have batteries to use the view finder? if so, what kind of batteries does it take
The XG-A requires batteries, not just for the viewfinder, but also for the shutter. It uses two alkaline A-76 (or equivalent) or two silver-oxide EPX-76 (or equivalent).
If you need an owner's manual, you can download a PDF version from http://www.butkus.org/chinon/minolta.htm
Feb 16, 2010 | Minolta XG-A 35mm SLR Camera
Cannot Wind nor See Thru View Finder
Whew!!! Many things to check. It sounds like the camera is not opening the lens up between shots. It could be a linkage issue. Look into lens while its on the camera. can you see the blades of the aperture? Turn the aperture ring. Any change? It is supposed to stay wide open except during exposure. Remove the lens. Move the lever on the back of it. See a change? Does it snap when you move it? If not, then the lens needs repair, not the camera. I forget...does the XGA have a DoF preview button? If so, its likely on front at bottom of lens mount. Push and release. If its in Preview mode, the lens remains stopped down(not wide open)based on the setting of the aperture ring.
Sep 22, 2009 | Minolta XG-A 35mm SLR Camera
Strange Foggy line across view finder of Minolta XG-A
sounds like liquid damage. take the bottom cover off and see if there is any rust or corrosion. if all is ok and the camera is working, don't worry about it. it has no effect on print quality.
now if you find rust or corrosion your camera is about to become a fancy paper weight. not repairable economically.
Jul 18, 2009 | Minolta XG-A 35mm SLR Camera
Minolta XG-1 Film Camera View Finder has Door Seal Foam stuck in it.
jrbw123,
the top cover must be removed and the flex circuit on top of the prism must also be removed. then remove the prism to access the fresnel lens. the lens is extremely fragile and very difficult to clean.i would try to replace it with a good used one if possible. unless your a intricate instrument repair person i would let a camera repair person do this.
Nov 05, 2007 | Olympus Stylus Zoom 140 35mm Point and...
Minolta XG-A 35mm SLR Camera Logo
946 people viewed this question
Top Minolta Photography Experts
Parshiv Luthra
k24674
Are you a Minolta Photography Expert? Answer questions, earn points and help others
