Question about Dell Inspiron 1200 Notebook
Single keystroke causes two different characters to display.
When I type the g key, g5 is displayed onscreen. When I type h, I get h6. Also, the delete key deletes not the next character but the character after the next one on the page. The computer is a dell inspiron 1200 laptop.
Thanks for any help/suggetions.
Karen
My h key pr\ints h6. my backspace does not backspace. my g prints g5. H^elp
Check you have the correct keyboard driver, in the control panel, icon keyboard.
Also the keyboard is effected by the language you choose, so check the Language icon as well.
Mar 16, 2015 | HP Pavilion dv9823cl Notebook
Keyboard typing multiple letters/ numbers when pressing certain keys.
Keyboards on Windows computers can repeat letters when key press sensitivity is too high. This problem can be rectified by adjusting your keyboard's repeat frequency. Once this is lowered, key presses will occur slower and you will not have the letters repeated instantly.
Click"Start," then "Control Panel." Click "Hardware and Sound," followed by "Keyboard." Move the "Repeat delay" slider further to the left below the "Character repeat" option. The further left the slider moves, the longer the delay will be before a character repeats.
Feb 03, 2013 | Computers & Internet
HI, KEYBOARD IS NOT WORKING PROPERLY, IF I PRESS H IT WRITES H6,IF I PRESS G IT DISPLAY G5,IF I PRESS H IT GIVES H6,IF I PRESS,\ IT OPENS MS HELP.AND ENTER BUTTON AND AEROWS KEYS ARE PERMANETLY NOT...
HI DEAR FRIEND
I know what problem having you
step1 right click to my computer
step2 click manage
step 3click device manager
step 4clic keyboard
step5 UN install the the keyboard driver
step 6install CORRECT keyboard DRIVER IN YOUR SYSTEM
OK
Apr 08, 2011 | Lenovo 3000 N200 T7100 1.8G 1GB 160GB...
Keyboard displaying double character
Could be several things. If dirty or under humid conditions, you might be able to just remove the keyboard and clean off the touch pad buttons. If not, I did a simple google search for the keyboard and found dozens for sale online for around 25 to 30 dollars.
May 30, 2009 | MPC Computers TransPort T1200 Notebook
Extra characters display when key pressed
Check the NumLock Key. If your keyboard isn't typing the correct characters, you may have the incorrect input language selected. Many laptops will convert most of the keyboard into a number pad if NumLock is enabled. Press Num Lock + Function or Function then NumLock to make sure its disabled.
Cheers!
J the Guru
Aug 12, 2017 | Microsoft Visual FoxPro Professional...
Incorrect key assignment
do you have an fn key anywhere on your keyboard
Feb 08, 2009 | Dell 0Y3740 Keyboard
Denon AVR-3802 Front Display problem
This can be either the display itself or the display driver IC havng problems. Something as simple as poor solder connections may cause this as well. Without seeing hte unit, it is difficult to say what the real problem is. If you can solder, try resoldering all of the voltage regulator ICs in the unit. These look like transistors and will be marked 7805 or 7812. If the voltages drift too low because of bad connections, the ICs can get "confused" and not work properly.
Keep us posted.
Dan
Aug 26, 2008 | Denon AVR-3802 Receiver
The text dictionary keeps giving me the wrong words and i cant change, how do you knock it off. the phones a samsung d900i
Using T9 mode
T9 is a predictive text input mode that allows you to
key in any character using single keystrokes.
Entering a word in T9 mode
1. Press [2] to [9] to start entering a word. Press
each key once for each letter.
For example, press [4], [3], [5], [5], and [6] to
enter HELLO in T9 mode.
T9 predicts the word that you are typing, and it
may change with each key that you press.
2. Enter the whole word before editing or deleting
characters.
3. When the word displays correctly, go to step 4.
Otherwise, press [0] to display alternative word
choices for the keys that you have pressed.
For example, OF and ME use [6] and [3].
4. Press [ ] to insert a space and enter the next
word.
Other T9 mode operations
• Press [1] to enter periods or apostrophes
automatically.
• Press [ ] to change case. Lower case (No
indicator), Initial capital ( ), and Capital lock ( )
are available.
• Press [ ] to insert a space.
• Press the Navigation keys to move the cursor.
• Press [C] to delete characters one by one. Press
and hold [C] to clear the display.
Adding a new word to the T9 dictionary
This feature may not be available for some languages.
1. Enter the word that you want to add.
2. Press [0] to display alternative words for your key
presses. When there are no more alternative
words, Spell displays on the bottom line.
3. Press <Spell>.
4. Enter the word you want using ABC mode and
press <OK>.
"The faulty interface lies between the chair and the keyboard"
Apr 21, 2008 | Sony Ericsson w580i Cellular Phone
Keyboard problem
turn of the number lock holding 'fn' key + 'num lock' key on your keypad...thats all
Dec 21, 2007 | HP Compaq Evo n610c Notebook
Dell Inspiron 1200 Notebook Logo
475 people viewed this question
Alun Cox
