Question about Kenmore Elite 22.4 cu. ft. Bottom Freezer Refrigerator with Adjusta Cube Ice Maker
Loud fan noise near bottom of freezer on my kenmore elite
It just started today the 26th and it stopped once but its loud continuely now.
Thanks Dustin
  • 306 Answers
There is a fan down on the bottom of your unit it sounds to me like the fan is making the noise as the bearings are getting dry. You should be able to move the unit out from the wall and get behind and look at the fan right next to the compressor. let me know how it goes. ken
Posted on Dec 27, 2008
Kenmore elite french door refrigerator and freezer not cooling
Check the compressor start device. The fans will be running and the compressor fan will be running but the compressor is problaly not running. If it is then it could be the compressor itself that is not oumping.
Mar 25, 2014 | Kenmore 73502 / 73504 / 73509 Bottom...
Right Door is making loud popping noise
HI,
Noise can come from these areas:
The inside of the freezer
The outside back of the refrigerator
The bottom of the refrigerator
The inside of the freezer Self-defrosting refrigerators use a circulating fan to move the air through the freezer and refrigerator compartments. This fan runs whenever the unit is cooling. The fan is located in the freezer, as follows:
  • If the freezer is on top, the fan is on the back wall, near the top or bottom, in the center of the freezer.
  • If the freezer is on the bottom, the fan is on the back wall, near the top of the freezer.
  • If the freezer is on the left, the fan is on the back wall, halfway up or near the top.
Over time, the fan may become noisy--usually making a chirping or squealing sound, though it may make a loud groaning noise instead.
To find out if the fan is causing the noise, just open the freezer door and push in any fan/light switches. If the noise is louder when the door is open, the evaporator fan motor is the cause. You can't lubricate or repair this motor. You must replace it.
The outside back of the refrigerator There are three components on the outside back of the refrigerator that may become noisy: the compressor, the condenser fan motor (if self-defrosting), or the defrost timer (if self-defrosting).
  • The compressor is a football-sized case with no apparent moving parts. You can see it on the outside of the refrigerator at the back near the bottom. It is usually black and has black or copper-colored tubes and various colored wires attached to it. If the compressor is the device making noise, there is probably no repair that will reduce the noise. You will have to replace it--which can be quite costly.
  • If the condenser fan is making noise, there may be a build-up of lint or other debris on the fan blade. The fan is located near the back of the machine, sometimes behind a thin panel. To clean it, first unplug the refrigerator, remove the thin panel, and use a soft bristle brush to clean it. If there is no lint build-up or debris on the blade, you will have to replace the motor.
  • The defrost timer is often located at the bottom of the refrigerator, near the front and behind the kick plate. Occasionally the electric motor inside the timer may become noisy. The timer must be replaced to solve this problem.
The bottom of the refrigerator Noises detected at the bottom of the refrigerator almost always originate from the back of the refrigerator. However, sometimes the drain pan under the refrigerator will rattle. You may need to tape the pan in place to stop a rattle. Also see the “Outside back of the refrigerator.”
Aug 22, 2008 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
I have the Kenmore refridgerator with the freezer on the bottom, and lately it has been making a loud noise when it comes on. It has been doing this for a week or more, today I noticed that the temperature...
You need to check for the refrigerator level, drain pan, condenser fan, evaporator fan and inspect the compressor mounts for the cause of noise. Any popping or hissing sound is normal on frost free refrigerators.
Good luck
Jul 27, 2010 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
What does ER FF mean on my Kenmore Elite bottom
Hi
Thanks for using FixYa. Error ff is freezer fan fault. This usually happens when either the rear board has gone bad or the freezer fan itself is bad and needs to be replaced. To check what is causing the error you can start with checking the fan which is located behind the back wall inside the freezer. Also check the rear board as it might not be putting the fridge into defrost long enough and is causing the ice to build up in the freezer and thus stopping the freezer fan from turning and so causing ff error. Leave the fridge unplugged for 24hrs which will melt all the ice then plug it back if still the issue is not resolved and you hear the fan running then it is the rear board that needs to be replaced. Please do rate the solution if the issue is resolved or else revert for further assistance.
Thanks
Rylee
Jun 30, 2010 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
My LG ice maker fan is making a really loud noise right after the water stops going in
Hello, Self-defrosting refrigerators use a circulating fan to move air through the freezer and refrigerator compartment. This fan runs when ever the unit is cooling. The fan is located in the freezer, as follows:
  • If the freezer is on top, the fan is on the back wall,near the top or bottom, in the center of the freezer.
  • If the freezer is on the left, the fan is on the back wall, half way up or near the top.
Overtime the fan may become noisy, usually making a chirping or squealing sound, though it may make a loud groaning noise instead.
To find out if the fan is causing the noise,just open the freezer door and push in any fan/light switches, if the noise is louder when the door is open, the evaporator fan motor is the cause. You can lubricate or repair this motor. You must replace it.
There are three components on the outside back of the refrigerator that may become noisy: the compressor, the condenser fan motor(if self-defrosting), or the defrost timer (if self-defrosting).
Thanks
Jun 17, 2010 | LG LSC26905TT Side by Side Refrigerator
Our kenmore elite bottom freezer is making a loud humming noise. It shuts off when door is open..and continues when door is shut. Temperatures are fine, no error message, it rarely stops..like it is trying...
Turned off the fridge, emptied the Freezer, used a blow dryer for 20-30 minutes, to melt ice that had built up in vents at rear of freezer.
Cleaned the freezer and reloaded...no hum..at least for now.
Sep 13, 2009 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Kenmore Elite Trio 596.76529500 It makes a
It is the Freezer Fan, he ice maker fan. I experienced the same conditions of a two year period. The tech allows said either unplug overnight. I as you couldn't take the noise. Oh by the way it will be getting worse!!! The solution replace the Freezer Fan motor.it cost about $78.00 plus shipping. they are located behind the freezer rear wall. They are very labor intensive to replace because the electrical leads are attached just out of reach. I have a 33" arm and I had to act like a contortionist to unplug them.
Jul 24, 2009 | Kenmore 73502 / 73504 / 73509 Bottom...
Kenmore Elite Trio = clicking and fan running constantly
Sounds like a problem with the compressor.  Get a service tech in.
Nov 20, 2008 | Kenmore 73502 / 73504 / 73509 Bottom...
Kenmore Elite 22.4 cu. ft. Bottom Freezer Refrigerator with Adjusta Cube Ice Maker Logo
358 people viewed this question
Top Kenmore Refrigerators Experts
Sal De
Jim Goldsmith
Jim Goldsmith
ka4iup
ka4iup
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
