Frigidaire LTF2140ESO front load washer won't start. Not responsive to panel button inputs (Spin Speed, Options). Only reponse is three beeps. When I move the basket back and forth, can hear a little water sloshing around down below.
  • Anonymous Dec 26, 2008
    Same problem
Electrolux washer LTF2940ES3 STOP SPINNING -- EVERYTHING SEEMS TO BE IN ORDER, I.E. DRAIN, BELT THE TURNS THE DRUM, ETC. MY GUESS IT'S THE CONTROL BOARD. IF SO, IS THIS A PART I CAN REPLACE MYSELF?
Posted on Aug 01, 2009
Are the controls locked? my son messed with my washer and then it wouldnt work but it was only locked. I didnt even know that it locked until i searched the manual and found that if you hold in the Options and select buttons at the same time, it will either lock or unlock the washer!!!
Posted on Mar 02, 2010
Slow spin speed
Assuming you have reviewed the front panel options/settings verifying your spin speed is set to a spped above slow/low, the unit will wash forward, and reverse, and there are no error codes during your cycle, your most suspect part will be the door latch/lock assy. Part# 131763202. In some cases the final leaf contacts within the lock assy that make when the wax motor energizes do not make good contact. Pleazer Appliance...
Apr 11, 2014 | Frigidaire Affinity ATF7000E Front Load...
My frigidaire front load washer will not start. anytime I push a button on the front panel the "LOL" sign flashes. on the front of the washer panel d wash rinse final spin control lights are...
Is the message "LOL" or "LOC"? I suspect the child lock "LOC" has been activated. To toggle this off, press and hold Options and Select for 10+ seconds. This feature prevents someone from accidently starting or changing a cycle selection.
There is a small padlock icon in the middle of lines linking the two buttons that let you toggle the child lock on and off.
There are two Frigidaire washers with the model ATF6000ES (the S is followed by a 0 or a 1). The manuals for both are available here: http://www.frigidaire.com/manuals?model=ATF6000ES . The child lock feature is described in the Operating Instructions. For the ATF6000ES0, the direct link to the appropriate manual is http://manuals.frigidaire.com/prodinfo_pdf/Webster/134604400.pdf . See page 2 under Washer Features.
I hope this helps.
Sep 21, 2011 | Frigidaire ATF6000ES Front Load Washer
Frigidaire affinity washer program error. When you turn the knob to normal washing, it only has 26min when it use to have 40min and now you can't make any choose any options. The options are all out...
factory reset you have to
push the Spin Speed and Soil Selection keys simultaneously and hold
until you hear a beep. This is no more than 10 seconds.
If this helps PLEASE RATE ME >.....
Jun 25, 2011 | Frigidaire Affinity ATF7000ES Front Load...
My washer says loc and wont start
The control panel may in *LOCKED* mode.
Press the *OPTIONS* and *SELECT* buttons at the same time and hold for about three seconds to unlock the control panel.
Mar 18, 2011 | Frigidaire GLTF2940ES Front Load Washer
Fridgidaire front load not starting
hi fourintow
sound to me that its the water inlet valves at the rear of the machine,they're the bits where your blue and red water hoses joint on to they are quite cheap and easy to install
Oct 28, 2008 | Frigidaire ATF6000ES Front Load Washer
Frigidaire front loader washing machine won't spin...
The problem is a faulty Door Latch Assembly. The same thing happened to my Frigidaire front load washer. The part is easy to install, costs about 60 dollars and can be picked up at most appliance repair stores . To access the switch just remove the wire around the front drum gasket, peel back the rubber gasket beside the switch assembly then remove the two screws holding it in place. remove the three wire connector blocks and swap in the new switch. My washer was giving me error code 41 witch is a faulty control board. But the problem was in fact only the switch...
Sep 02, 2008 | Frigidaire GLTF2940ES Front Load Washer
LOC ERR
The control panel may in *LOCKED* mode. Press the *OPTIONS* and *SELECT* buttons at the same time and hold for about three seconds to unlock the control panel. Make sure the detergent tray is fully closed too.
Feb 23, 2007 | Frigidaire GLTF2940ES Front Load Washer
Washing Machines Logo
1,783 people viewed this question
Top Washing Machines Experts
Marvin
Marvin
