Question about Amana 22.6 cu. ft. Side-By-Side Refrigerator with FrontFill Ice and Water
My amana side-by-side SQD26V is not keeping cool. Just opened the freezer up and found ice around the coils (back part of freezer). My husband is using a hair dryer to get the ice off the coils.Where do we go from here? If it's a defrosting problem (timer, thermostat,etc) how do we pin point it and fix it?
  • 700 Answers
First off make sure that the drain on under the coil is cleared, then when the ice is gone and you turn the unit back on the coil should first get good and cold before the fan tries to come on . you will have to temporarly put the cover over the coil to do this. let it run until there's good frost on the coil and then the fan should come back on. that would rule out the motor,and the thermostat. thanks for unsing FIxYa
Posted on Dec 26, 2008
Freezer not cold and forming ice in side?
Replace the defrost thermostat located on the coils in the freezer. Here is the part to order.
Dec 03, 2012 | Amana ARS2464B Side by Side Refrigerator
I have amana DRS2662W- I had turned the defrost timer but now the freezer and the fridge are not cold enough- there is no ice forming, I can hear the compressor and fan behind but not cooling.
You should never need to advance your defrost timer. If your defrost is not working properly, the coil in the freezer compartment will ice up, blocking all airflow. All of your cooling is done there, even the refrig area, so you will never get down below appx. 40-45 degrees.
my first suggestion is to look at the back panel in your freezer for frost/ice build-up. If yes, unplug the unit, open the freezer compartment and let it thaw overnight. If it starts cooling properly, you have a defrost problem. It may be a bad timer(often), thermostat(less frequent), or bad defrost heater(even less).
Nov 15, 2010 | Amana DRS2663B Side by Side Refrigerator
I have an Amana BX21VW refrigerator and both the freezer and refrigerator stopped cooling. The fan is still going and there is power, but no cooling of any kind. What is going on?
Hi!!
Check
Temp. control knobs,
Most likely, the evaporator coil is covered w/ice, obstructin the air flow thru it and to the fridge side of the unit.
Remove freezer back panel (where the little fan is) and check for iced evaporator coil, if so, unplug unit and use a heat gun or hair dryer to melt ice, make sure all ice is melted andthe air duct going to the fridge is clear.
Once this is done, restart unit and set temp. 1/3 of the dial, ie. if the dial goes from 0-9, set it on 3. wait 24 hrs to make adjustments
Keep me posted!! Rate this post!!!
Aug 12, 2010 | Amana Refrigerators
Wawwwwtewwwwwar
Hi!!
Make sure drain hose is not clogged up. Check evaporator fan, (small fan in freezer compartment). it should come on after door is open a couple of minutes. Feel air vents in fridge side for a stream of cold air, if none or too weak, remove back cover (where fan is) and check for frozen evaporator coil. If evaporator is frozen, air can't circulate thru unit, keeping fridge side from cooling and freezer side below freezing point.
If this is the case, unplugg unit from power outlet, and use a heat gun or hair dryer to melt ice, make sure all vents are clear.
Once the evaporator coil is free of ice, dry freezer, replace back cover and plug unit back on. Check temp. settings, should be about 1/3 of the dial range. If necessary, make additional adjustments every 24 hrs.
Don't forget to rate this post!! Good Luck!!!
Jul 30, 2010 | Amana 22.6 cu. ft. Side-By-Side...
Not cooling properly
Sounds like your coils are getting plugged,(excess ice in and around the coils)if you have a cooler or some other place to keep your food cold,turn off or unplug the fridge,you want to defrost it,for the freezer place pans of hot water in it to speed up the process,leave doors open,should only take around 4 to 12 hrs.A good time to clean it to lol.
Hope this helped.Let me know.Also rate me.
For more help go to live chat.
lenwest
Jan 30, 2009 | Amana ABB1927DE Bottom Freezer...
Amana Side-by-Side refrigerator hot spot
hi tanks for the question there are heaters at the spots you said were hot and those heaters are there to prevent moist air from hitting cold surface and create warer droplets from forming on those surfaces i would remove the back of the fridge and vacuum it out that should solve your problem thanks the appliance doc
Sep 18, 2008 | Amana 22.6 cu. ft. Side-By-Side...
Refrigerator
It sounds like you found it. Change the defrost timer.
Jan 16, 2008 | Amana DLE330RAW Electric Dryer
Amana sxd524ve
why did you turn off in the first place??? to defrost ice off back wall??? if so sounds like you ahce a bad defrost thermostat. (evaporator fan get power from runnig through thermo. and when the thermo goes bad the unit stops cooling correctly because of the massive amount of ice that buildsaround the coil
Nov 29, 2007 | Amana SXD524VW Side by Side Refrigerator
Amana 22.6 cu. ft. Side-By-Side Refrigerator with FrontFill Ice and Water Logo
261 people viewed this question
Top Amana Refrigerators Experts
Sal De
Steve Allison
Steve Allison
Carmen Mikulic
Are you an Amana Refrigerator Expert? Answer questions, earn points and help others
