Question about HP Photosmart 2410 All-In-One InkJet Printer
2410 all in one printer
5 Suggested Answers
  • 132 Answers
SOURCE: HP PSC 1610 Won't Turn On
If you can, take out the ink cart. all of them.  Unplug the printer;  plug back in and then turn it on.  See if it asks for the cart's.  Let me know from there what happens.
Posted on Oct 17, 2007
SOURCE: HP Photosmart 2410
por favor me pueden ayudar con los drivers de esta impresora les quedare eternamente agradecidos mi correo es
Posted on Jun 20, 2008
  • 154 Answers
SOURCE: Printer prints blank pages.
 it a transfer belt issue....there is a test you can perform to confirm. When the first page comes out of the printer blank, open and close the back cover. If the next page comes out with print on it, then the transfer belt is the issue. One thing you can try is take the old belt down to a service station with a good air compressor and then use the air compressor to blow the heck out of the belt until no more toner comes out.
Posted on Mar 04, 2009
  • 55 Answers
SOURCE: Printer prints out blank pages
reinsatall drivers
Posted on Mar 29, 2009
SOURCE: printer not activated, error code -30
I have fixed this problem, and I also know what caused it initially. First of all, this started happening after I installed software called WillMaker Plus 2009. For some reason, that installation also had created a new "Quicken PDF Printer." I think that was interfering with my default printer. So what I did, was completely unistall my default printer driver, turn the printer off, and then reinstall that specific driver from online. When I turned my printer on, my computer sensed new hardware, and took it from there. Fixed.
Posted on Aug 09, 2009
0 characters
1 Points
I have tried a couple of the recommended solutions from this site but still to no avail. My HP all-in-one has a flashing message that indicates to check my right cartridge, which is the black cartridge. ...
Did you try to Reset the printer?
1. Unplug the power cord from the back of the printer while the printer is on
2. Now press and OK and Cancel button at the same time
3. While holding them plug in the power cord
4. Release the buttons when the printer turns On
It will reset the printer and you will see the message on the LCD also.
If this also did not help then try another cartridge and if that also does not help then there may be hardware issue with the printer .
Though still let me know what happened
Apr 17, 2011 | HP PSC 2410 All-In-One InkJet Printer
Canon lasershot lbp 2410- when it is colour to be printed nothing is printed, some faint yellow only but if set to monochrome it is OK-this printer has made BW 1100 and colour 890 prints. Please help me...
turn on/off, unplug, plug in2_bing.gif, should reset configs.
go to applications folder for your computer, dbl click printer icon for make of printer. check settings. print 'test document and clean cartridge heads', this should ensure proper printing formats.
lastly, go to web site of printer model and check site for trouble shooting if this does not work above.
hope this helps and good luck
Apr 29, 2010 | Canon LBP 2410 Laser Printer
Light flashing on 2410
Unplug the printer and leave it unplugged overnight (or just a few hours), then plug it back in.
Sep 15, 2008 | HP PSC 2410 All-In-One InkJet Printer
Hp pSC 2410 Printer
You can download the drivers from hp website here. Choose the operating system of your computer and then download your file. Install with the usb cable of printer plugged out of system and then when the wizard asks, then you plug it in.
Jun 30, 2008 | HP Photosmart 2410 All-In-One InkJet...
You could go online to and see if the drivers need to be updated.
Jun 14, 2008 | HP PSC 2410 All-In-One InkJet Printer
Hp alll in one model # PSC 2410 photosmart. Printer makes sound as if printing then stops and timer clock stays on. . tried again after shutying it off.Same problem. please help
I have a photosmart 2410 also. I found if i unplug the printer for 15 min. then plug it in, it clears the hour glass and restores function.
Jun 06, 2008 | HP Printers & Copiers
Hp psc 2310
unplug the power cable
Press and hold # and 6 on the printer while keeping these tow buttons on hold plug the power cable back in . when the screen goes off release the buttons and press the power button to turn the printer on. it ll perform a semiful reset on the printer .
if the issue still persists then unplug the power cable again
Press and hold OK and CANCEL on the printer while keeping these two buttons on hold plug the power cable back in . when the screen goes off release the buttons and press the power button to turn the printer on . follow the screen ...
it shud be resolved ..
May 06, 2008 | HP PSC 2410 All-In-One InkJet Printer
Fax HP PSC 2410
I HAVE PSC 2410 XI All-In-One AND Fax HP PSC 2410xi does not work PLEASE HELP
Feb 01, 2008 | HP PSC 2410 All-In-One InkJet Printer
turn the printer on then disconnect the power cable on the back of the printer.
Press & hold # 9 down while connecting power cable...If there is nothing on the display.... Then LCD is gone bab.
Nov 24, 2007 | HP PSC 2410 All-In-One InkJet Printer
HP Photosmart 2410 All-In-One InkJet Printer Logo
24 people viewed this question
Top HP Printers & Copiers Experts
Brian Sullivan
Brian Sullivan
Are you a HP Printer and Copier Expert? Answer questions, earn points and help others
