Question about Dell OptiPlex GX270 PC Desktop
Can't get benefits of service because I lease TIVO thru cable co.
I lease my TIVO box thru my cable co. TIVO just came out with a new service - link your TIVO thru your PC and buy videos on demand via Amazon Unbox. I live in a small town and we don't get a lot of perks with the cable co. I bought the adapter necessary and installed it correctly. To begin using the service you have to go to TIVO and register your box, they will then give you a password. HOWEVER because I do not own the box TIVO will not give me a password. The TIVO tech and I conferenced with the cable co. and the cable co. doesn't understand. They just keep saying "You don't get VOD in your area". Because TIVO offers this service via my computer I will buy the videos from Amazon. Any suggestions on how I can tap into this service bypassing the ignorance of my cable co?
    President:
  • 2,692 Answers
Your cable company is telling you that you do not have enought band width to download and use (VOD) Video On Demand.  They are unwilling to sell you, or your equiptment does not support such a high speed continuous download.  No.. Their is no way around it. Nextflix or Redbox may be alternitives for you.
Posted on Mar 09, 2009
I have an existing Tivo box and getting a new tivo v6 can I link up the old box with the new one. Do I just connect between the two HDMI sockets with my power line adapter that I have. Regards Clive
You connect both via cat5 cable with both units being in your network. Both units will be identified in the other by the name or location given when setting up. The location in each unit is in MY Shows and then at the bottom labeled devices.They will be tied together for moving from one to the other.
Aug 31, 2017 | Tivo Televison & Video
How do I set up a tivo series2 to a new digital tv. Do I need analog to digital converter?
Analog to digital converter is for OTA transmission. You are using a cable system, right? If so you have to feed into your Tivo the cable output signal from your cable box and set your tivo to correct rf or video input. Since cable tuner is determining channel all you can do to record is set the channel on your cable unit and program your tivo to turn on and record the input at appropriate time..
Aug 28, 2017 | Tivo Televison & Video
What Are The Benefits Of Leasing Equipment?
The benefits of equipment leasing include preserving cash, considerable tax deductions, and flexible terms, maintaining contemporary equipment, and decreased incidental equipment expenses.
Aug 19, 2016 | Retail Supplies
Will a dvr/tivo built for direct tv convercablet to a cable tv service with a cable card from suddenlink its a sd80 tivo dvr mfg 2004
Unfortunately, DIRECTV TiVo DVRs will work ONLY with DIRECTV. They cannot be modified to work with cable.
However, there are many TiVo boxes that do work with cable and they are as low as $99. See, for example:
http://www.weaknees.com/4
http://www.weaknees.com/5
Oct 28, 2013 | Televison & Video
NEW SAMSUNG CABLE BOX TIME WARNER &TIVO SERIES 2
the IR is located next to the power button and you will have to select pioneer as your cable box brand and it will work fine
Jul 28, 2010 | Samsung Televison & Video
My tivo HD is not broadcasting or recording in HD
As far as I know, you need the cable cards to get HD through the Tivo, because they're what does the HD decoding and output.
Jan 18, 2009 | Tivo HD
Tivo won't change my TV Channels anymore with direct cable
I re-did the guided setup in the Tivo under Messages & Settings/Restart-Reset System/Restart menu section in Tivo. Once I did that, it cleared this issue, even though I didn't have to change any of my settings thru this guided setup. I tried a reset alone first, but that did not fix it. Only this fixed it. We had lost both power and cable during a recent tree fall in a storm, and when both were restored, this problem started. I have a cable coax directly in the back of the TV (no cable box/IR etc) and the system is on a home wireless network. I actually have 2 identical Tivo's in the house set up the same way but only one had this problem. The other worked no different after the outage.
Oct 12, 2008 | Tivo Series 2 80-Hours Video Recorder
TIVO Remote Control Problem
A similar problem happend to me. Buying a new remote fixed it - for about three weeks.
Maybe your new one will work longer.
Mar 06, 2008 | Tivo DirectTV Remote Remote Control
TIVO DVR : Won't Change Channels
Set up your infrared blasters connected from your IR port on the Tivo and by placing the two lead lights in front of your cable box so it (the cable box) can read the signal.  Then go to Channel settings accessed through Tivo Central and follow the questions. It will ask you to change channels until the remote is working correctly.  This all worked on a different "input" on my Mitsubishi TV (it has multiple inputs.  I have the cable input on a different "input" to make it work.  Hope this helps.  Call TIVO tech assistance because they are the ones who talked me through this.
Mar 01, 2008 | Tivo Series2 TCD649080 Video Recorder
Tivo HD will not record when Onkyo HT-SR800 is off
Do you want to run all your cables thru the receiver? There really is no benefit for you to do this since that receiver doesn't handle HDMI audio nor do any kind of component to HDMI conversion. Might as well connect your tivo box directly to the TV with HDMI. You'll have to switch inputs on your TV between the cable box, but its not a big deal.
Feb 20, 2008 | Onkyo HT-SR800 System
Dell OptiPlex GX270 PC Desktop Logo
Alun Cox
mukhtar21 shaikh
mukhtar21 shaikh
