Question about LG Electronics 16X DVD-ROM IDE ATAPI DVD Drive
Error with LG ATAPI DVD DH20A4H
When I try to burn a master of my video project with Ulead movic Factory 5, the burn process stops and a window pops up that say's disk is not empty, even thought it's a new disk. I've tried multi disk and I still get this.
Thr process has workeed fine up until this pass week. I tried burning a cd with windows media and it worked fine.
I thought it might be a problem with the software so I removed and reloaded movic factory same results.
I loaded movice factory on another system and the bun process worked fine. So I think it's something with the dvd players in this particular system, there are two, both give the same error.
How can I fix this?
I'm a novice, but had the same problem. I followed the manufacturer's advise and went into the Registry and changed the "drive type" to a "1" instead of the "3" that was listed. Apparently, a "3" indicates that the drive is only capable of reding discs. Changing the value to a "1" or "2" enables Windows to viw the drive as a recordable drive. Hope this helps.
Posted on Nov 22, 2010
My ATAPI DVD DH20A4H will not burn a DVD, but it will burn a CD-R. I know it's a dvd burner, yet it refuse to burn one..
Hi, Try a different brand of dvd disks as quite often a drive will burn one brand but not another,you could also try using a different burning program.I use Ashampoo Burning Studio 6 FREE, which as it says is free and can be downloaded from the web.
Regards Bill
May 04, 2010 | Pioneer DVR-107D DVD±RW Burner
Program shuts down during the burn process.
reinstall the program again and make sure your drivers are properly working
Dec 02, 2009 | Ulead DVD MovieFactory for PC
Having Problem with burning CD R with computer drive ATAPI DVD A
Make sure its a CDR and NOT a CDRW. Also make sure you have finalized the disc when you burned it.
Oct 29, 2009 | Computers & Internet
Tried to burn a DVD using Power Cinema by going Create DVD, Author & Burn etc. Get to the end for the buring process and got a error code: FF037303. What does that mean?-
means you have a faulty or failed DVD burner (error is Power Calibration Error, returned through the ATAPI driver). Test with different /branded/ blank media, if none work then replace the drive.If you find one that works, stock up.
Jul 16, 2009 | JVC Everio GZ-MG130 Camcorder
After burning a DVD / DVD has no sound!
try play the video with VLC PLAYER or diferent player like don't have a good codec video on pc
Jan 21, 2009 | Ulead DVD MovieFactory for PC
Not sure what it means, but I found a way around it.
I get the same error when I try to burn a WMV (Windows Media Video) file to a DVD.
As a work-around, I converted the file to a MPG (MPEG-2) file. That took the size from 41 Mb to 357 Mb.
I was then able to burn the MPG file to a DVD successfully.
If you still have trouble, I would suggest creating an ISO image of the MPG file. That takes the size from 357 Mb to 508 Mb. You should then be able to create a DVD directly from the image file.
Apr 22, 2008 | Ulead Videostudio 8 for PC
Ulead dvd workshop 2
You can install and run a Ulead software for Windows XP on Windows Vista by running
the Program Compatibility Wizard. We do not guarantee full stability for Windows Vista though.
To run Program Compatibility Wizard:
1. Open the "Program Compatibility Wizard" by
clicking the [Start] button, clicking [Control Panel], clicking [Programs],
and then clicking "Use an older program with this version of Windows".
2. Click [Next] when the "Program Compatibility Wizard" dialog box comes up.
3. Select "I want to use the program in the CD-ROM drive" and click [Next].
If the installer is not detected from the CD-ROM drive, please manually browse for the installer executable.
4. Under "Select a compatibility mode for the program" step, please click on "Microsoft Windows XP (SP2)" and click [Next].
5. For the display settings, please click on "Disable Visual Themes" and "Disable desktop composition" then click [Next].
6. Click on "Run this program as an administrator" and click [Next].
7. Click [Next] to start testing the compatibility settings.
This will launch the installer so if you have your firewall enabled, it will prompt for a permission request.
Please grant permission for the setup to continue. 8. The setup will now run.
You can allow it to finish or switch back to the "Program Compatibility Wizard" dialog box.
9. It will ask you if the program ran correctly. Click "Yes..." if no other pop-ups appear.
* Try another compatibility setting if it reports a problem with the display. For the display settings,
enable the option "Disable display scaling on high DPI settings" as well.
10. For this next step click "Yes" to send the info to Microsoft and finish the process.
* Now that you have the software installed, you will also have to run the "Program Compatibility Wizard"
for the application to run correctly. Use the same procedure except for step [3],
select "I want to choose from a list of programs". Follow the same procedure for the other steps until you finish the setup.
Nov 16, 2007 | Ulead DVD Workshop 2 for PC
What editing program do I get with this camera?
The PC Kit provides movie capture, DVD authoring, DVD-R burning, photo editing, and DVD playback capability on PC based computers equipped with Windows 98, ME, 2000 and XP. The kit includes a USB Cable, USB1.1 Driver, UDF2.0 Writer, CyberLink Power DVD XP, Ulead® DVD Movie Factory SE for DVDCAM and Ulead Photo Explorer7 Lite.
Sep 05, 2005 | Hitachi DZ-GX20A DVD Camcorder
Computers & Internet Logo
324 people viewed this question
Top LG Computers & Internet Experts
Alun Cox
Are you a LG Computer and Internet Expert? Answer questions, earn points and help others
