Question about LG LDF6810ST Stainless Steel Built-in Dishwasher
LG dishwsher will not drain. error Code OE
I have completely cleaned the drain assembly inside the DW. I have completely cleaned the entire drain hose. I disconnected the drain house at the sink air vent and ran DW, still won't drain. I disconnected the wire assembly to the drain pump and hooked up to power, it works. I replaced the main PCB, still won't drain. Any suggestions? Thanks
  • LG Master
  • 13,433 Answers
If the water doesn't drain from your dishwasher, check these:
Drain line/air gap A clog in the drain line or air gap (if there is one) is the usual reason that a dishwasher won't drain. Often the problem is at the point where the drain line attaches to the garbage disposer or household drain line. If you remove this line, you can clear any debris from the hose or hose connection. Be sure to reattach the hose before starting the dishwasher again.
Pump Your dishwasher pump ejects the water. The pump is usually mounted directly to the motor, then attached to the bottom of the dishwasher. You can reach the pump from inside the dishwasher, but first you need to remove the lower rack, the spray arm, and the spray arm support.
Look for an impeller--a round plastic fan blade-type of device that spins around. This is the wash impeller, which forces the water through the spray arm. Beneath the wash impeller is the drain impeller, which is similar in size and shape to the wash impeller. The drain impeller pushes the water toward the drain port. These components make up the pump. If any of the pump components are defective, you need to replace them.
Drain valve and/or solenoid Many dishwashers use a drain valve with an electric solenoid. When electricity flows to the solenoid, the valve opens and diverts the water to the drain. Sometimes the solenoid, or the diverting lever, sticks and prevents the dishwasher from draining or filling properly. Try to free up the solenoid to lubricate the lever. Otherwise, you may have to replace the solenoid or pump assembly. With these systems, the motor always rotates in one direction. When it's energized, the drain valve diverts the water.
Other dishwashers simply reverse the direction of the motor to drain the dishwasher. These units don't have a drain valve. Instead, there's a drain hose connected directly to the pump housing.
Belt One brand of dishwasher uses a belt to drive the pump. If this belt is broken or has fallen off, replace it.
Motor If the motor isn't turning or working, the unit won't drain. First check to be sure you have power to the dishwasher. If not, see the section "It doesn't work at all." If the motor hums but doesn't turn, it may need to be replaced.
Some dishwashers are susceptible to getting stuck if you don't run them regularly. If you haven't run the dishwasher for more than a week, you may need to manually spin the motor to free it up. If the motor is defective, you need to replace it. Dishwasher motors can't be serviced.
Timer Part of what the timer does is control the motor and drain valve. If the timer doesn't work properly, the water may not drain and you need to replace the timer. This problem is uncommon.
Posted on Dec 26, 2008
Oe code. Will not drain. Steps to fix?
Hi
OE in your dishwasher is a drain error and dishwasher not draining issue usually occurs due to kinked drain pipe, clogged drain filter or drain pump. First make sure that the drain is not clogged and remove clogs if present. If no visible lint is present then remove the lower front access panel to check the drain filter and drain pump for any clogs, you'll need to clean the drain filter and drain pump completely. Also, check for any food pieces stuck near the pump impeller & clean the chopper assembly. If the issue returns after cleaning then the drain pump assembly should be replaced. Hope this helps...please post back for further assistance.
Daniel
Aug 30, 2011 | LG LDS4821 24 in. Built-in Dishwasher
Hello, LG LD 14AT1 dishwasher, starts cycle runs 3 minutes, starts stops on off no water in bottom. Then displays OE chimes! Checked tap under sink water there, checked filter inside bottom, turned off for...
Hi
Daniel
Aug 27, 2011 | LG 24 in. LD-12BS6 Stainless Steel...
I am getting an OE code on my dishwasher
Hi
Daniel
Aug 24, 2011 | LG LDF6810ST Stainless Steel Built-in...
LG 1419LF My dishwasher stops during its cycle, it shows an error message: OE, there is 2 inches of water at the bottom of machine...Please help...
Hi
Daniel
Aug 04, 2011 | LG Dishwashers
Stopping during rinse cycle . not spinning. OE light
The code OE is a draining error. The washer has sensed that the water has not completely drained all of the water within 10 minutes and will display this error code. The grinding noise you are describing is most likely a failed drain pump or clogged with foreign debris.
  1. Locate your drain pump access door on the front of the machine.
  2. Clean out the filter area.
If you are unable to resolve the issue by cleaning, I would recommend replacing the drain pump.
Jan 17, 2011 | LG Washing Machines
My LG 2277HW gave the LE error and we replaced the entire motor based on a Washing Machine Repair Company's advice. Within the month the machine would not spin the clothes all the way out and eventually...
http://136.166.4.200/contents/Laundry/WM2277/WM2277xx_Service_Manual.pdf
The LE issue should of been for the followinig, not a motor:
LE LOCKED MOTOR ERROR
• The connector (3-pin, male, white) in the MOTOR HARNESS is not connected to the connector (3-pin, female, white) of STATOR ASSEMBLY.
• The electric contact between the connectors (3-pin, male, white) in the MOTOR HARNESS and 4-pin, female, white connector in the MAIN PWB ASSEMBLY is bad or unstable.
• The MOTOR HARNESS between the STATOR ASSEMBLY and MAIN PWB ASSEMBLY is cut (open circuited).
• The ball sensor is out of order/defective.
The OE error means it is not draining. Two diffrent issues.
Are you sure you cleaned out the drain filter on the bottom? Not just drained it. You have to drain it then pull the filter out and clean it.
Mar 01, 2009 | LG WM-2277HW Front Load Washer
Hi. I have a 3 year old LG dishwasher. It will not drain. Display shows OE. I completely cleaned the drain assembly inside the DW. I checked the discharge line, it is completely clean. I disconnected the...
Measure the electric resistance of the Drain Motor. (Value should be 20-40 Ohms) If it is out of spec, replace it.
Please reply with what worked best. Thanks!
Dec 26, 2008 | LG 24 in. LDF 7811 Built-in Dishwasher
OE error code on LG front loader
The OE error code means:-
The Drain hose is kinked or blocked or the drain filter is blocked
Solution:-
Clean and straighten the drain hose and clean the drain filter
Nov 01, 2008 | LG WD-14124RD Front Load Washer / Dryer
LG LDF6810ST Stainless Steel Built-in Dishwasher Logo
Top LG Dishwashers Experts
Mike
Mike
Mike
Are you a LG Dishwasher Expert? Answer questions, earn points and help others
