Can't ''see'' RAM
Upgraded my laptop (originally 64 m) and now half the time it doesn't ''see'' the upgrade. Local tech has worked on it twice - and charged - without permanent fix. Any ideas?
  • 2 more comments
  • jeanboling Dec 26, 2008
    Toshiba Satellite 2800-S201
  • jeanboling Dec 27, 2008
    That's what the tech put in. The computer appears to "lose" contact when it's moved. In one position, it works at 320, in another it only sees 64. He took the card back out and tested it in another computer and it worked fine - it appears to be a glitch with the connection in my machine.
  • JDTec
    JDTec May 11, 2010
    What memory did the tech install? And what did he charge you for?
    Verify that the memory you have installed is PC-100 and the most you can add is one DIMM of 256 MB. (which will total the max , 320 MB.)
    The Toshiba Satellite 2800-S201 uses PC-100 type memory and usually ships from Toshiba with 64MB of RAM. The Satellite 2800-S201 supports up to 320MB of RAM. Maximizing your system memory will allow your Satellite to operate as fast as possible and offer the most productive environment.
    Specifications
    • Banks: 1
    • Fixed RAM: 64MB
    • Maximum RAM: 320MB
    • Sockets: 1
    • Speed: PC-100
    • Standard RAM: 64MB
  • JDTec
    JDTec May 11, 2010
    what model of laptop?
  • 4,338 Answers
Check the pins on the slot, there may be a bent pin or it may that the clips are not holding the memory in place.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Posted on Dec 27, 2008
Toshiba L40 constant disk activity
Did you check if your computer is capable of running Windows 8 comfortably? Have you followed the upgrade procedure? 2 GB memory seems rather too little. What was the original Windows version? XP, Vista, Windows 7. Was the original OS 32 bits or 64 bits?
Nov 03, 2013 | Toshiba Satellite Computers & Internet
Upgraded ram 1gb wont boot hp 510 mobo 30C4
If you added another 512Mb RAM to increase the RAM to 1Gb then the new 512Mb memory stick could be incompatible with the original 512Mb or it could be faulty.
Use RAM that is same make and speed as the original RAM.
Remove both RAM and just insert the new 512Mb into your laptop and see if the laptop boots up, if not then the RAM could be faulty.
Mar 02, 2013 | HP 510 Notebook
How to get Drivers Updates after Windows 8 Upgrade for Toshiba C660D Laptop Please
This is a common problem with a new OS upgrade. Try to use Win 7 drivers. Modtify the drivers to be compatible with Win 8. Most times this will work, not always. Try here for Win 7 32 or 64 bit drivers: http://uk.computers.toshiba-europe.com/innovation/download_drivers_bios.jsp?service=UK&mode=allMachines&action=search&teddProduct=6017&selShortMod=1041
Dec 03, 2012 | Toshiba Computers & Internet
I upgrade RAM on laptop, now runs slower. Running 64-bit WIN 7 OS,
Check BIOS if all RAM is being picked and or set to max on RAM settings.
Upgrading BIOS! If it isn't broken don't fix it. Upgrading is a scapegoat fix, and many manufactures have a disclaimer. "You are on you own, and the likes for a reason. Most solutions are found elsewhere.
However, if you truly need to update read this to help you with the upgrade.
http://www.techrepublic.com/blog/10things/10-common-mistakes-you-should-avoid-when-flashing-your-bios/357
GL
PS. Many applications are written for 32 bit, hence they are unable to fully utilize 64 bit and may be bound to 4GB.
Oct 09, 2012 | Gateway NV7802U Notebook
Hi, im using vgn cr23g. i upgraded- the ram from 1GB to 4GB. Then i upgraded to Vista (Service pack 1) as advised by Windows 7 Upgrade Advisor. Now i want to upgrade My OS from 32-bit Vista to 64-bit...
I have checked the specs of your PC notebook, I can see that you can upgrade the OS of your notebook to windows 7, because your PC passed the requirements for the windows 7 OS.
I hope you have a great day.
Jul 03, 2011 | Computers & Internet
WHAT IS THE OS FOR A TOSHIBA A 105 LAPTOP IS IT 32 BIT OR 64 BIT
this computer is shipped with windows xp 32 bit, can be upgraded to vista. As for 32 or 64 bit?, the only difference you will see between them is if you have more than 3 gig of ram installed a 64 bit O/S will see and use all the ram, where a 32 bit O/S is limitted to 3gig of memory it can address.
Personally, I believe you will have a lot easier time finding the 32bit drivers for your laptop and printer. 64bit drivers for older hardware are sometimes very difficult to find. GO with 32bit on this laptop.
Regards!
Apr 03, 2010 | Toshiba Satellite A105 Notebook
Can arcer laptop graphic card be upgrade
No, your video card cannot be upgraded, it's integrated in the motherboard. The only thing you can do is to assign it more memory.
Feb 15, 2010 | Acer (9005210464), (64 MB) Graphic Card
Gateway GT5222E windows Xp upgraded to Windows 7. Need upgraded video card, integrated video not compatable. Can I upgrade with video card?If so what can I get to do this.
Just go to best buy and find a video card that meets DirectX 9 Graphic specs that will fit you mother board.
1 gigahertz (GHz) or faster 32-bit (x86) or 64-bit (x64) processor
  • 1 gigabyte (GB) RAM (32-bit) or 2 GB RAM (64-bit)
  • 16 GB available hard disk space (32-bit) or 20 GB (64-bit)
  • DirectX 9 graphics device with WDDM 1.0 or higher driver
    Nov 11, 2009 | Gateway Computers & Internet
    Upgrading Ram/Bios
    You do have to have a 64 bit OS so that windows will recognise 4 Gig of Ram.
    I have Vista Ultimate 64 Bit and 4 gig of ram in my laptop. I upgraded the OS Before I upgraded the Ram, this might be something that Microsoft Address in the near future. so if you dont want the expense of buying Vista X64 then hold off for a little bit. Although 64 Bit doesn make more sense when you are getting to the limits of 32 bit
    Aug 25, 2008 | Acer Aspire 5600 Series 5630-6951 Laptop
    Computers & Internet Logo
    35 people viewed this question
    David Payne
    David Payne
