Question about GE (PSS26MSRSS) Side by Side Refrigerator
Icemaker makes ice, won't shoot it through the dispenser in door
The water dispenser works, but the ice stays in the bin and won't dispense through the slot in the door. only makes a humming sound.
  • 548 Answers
We have a similar problem with ours and GE knows that they have put out defective units. The problem for us is that we used the water dispenser a lot and the water froze in the line, causing the ice to back up in the release chute. You need to get a tech out to look at the unit. Hopefully they will be kind and recognize what this is, a bad design that has generated numerous complaints and will get you a free fix. You might want to call a few places and ask questions about it before you have them send their tech out.
On the chance that this is not what I described, have you moved the ice bin around, taken it out and put it back in, checked for frozen slush at the bottom of the tray to make sure that it is not simply clogged? Don't put fingers in the tray while it is still in the fridge.
Posted on Dec 26, 2008
Frigidaire frs6lf7fm. Ice maker dispenser, the auger won't turn (tested with ttay out). It makes ice and dumps it into the bin no problem. And the water side is fine.
[FIXED] Icemaker auger motor won't turn - ApplianceBlog
Apr 16, 2010 - 9 posts - ‎2 authors Does the auger motor need to be re-set or something? I wonder if it shut itself down to prevent burnout (because it had been unable to turn the ... FIXED Auger won't turn to dispense ice.
Jun 1, 2014
Ice maker auger will not turn
Mar 17, 2013
FIXED Ice Auger won't turn
Sep 3, 2012
GE Icemaker: Makes Ice, Doesn't Dispense In Door?
Apr 19, 2005
More results from
Oct 01, 2015 | Frigidaire Refrigerators
Why won't ice dispense from ice maker?
Pull out the ice storage bin from the refrigerator. Empty the bin if it is full. Add some ice into the bin. Reinstall bin into refrigerator. Make sure the refrigerator door(s) are closed. The ice will not dispense if the door(s) are open. Press the ice dispenser with a glass underneath it to start dispensing ice. Listen for a whirring sound. If there is a sound, then the auger that moves the ice cubes is working. Check the ice shoot in the door to see if it is blocked with ice. If you don't here any whirring sound the motor that runs the auger is probably bad. Then you will have to replace the whole ice maker assembly.
Jul 20, 2014 | GE Refrigerators
Ice maker stopped dispensing
Refrigerator - Icemaker Not Dispensing,or Not Making Ice Check that the feeler arm on the icemaker is in the down position and is not blocked. If the icemaker does not have a feeler arm make sure the icemaker paddle is not blocked under the icemaker. For more information on the causes of new icemakers not making ice. For more information on normal ice production. Side by Side models: The filter may be loaded with sediment that can cause low water pressure. The water pressure must be between 40 and 120 psi. Pressures below 40 psi may cause a malfunction of the icemaker (i.e. producing hollow cubes or no ice production). Test the water pressure: Dispense water from the dispenser into a large measuring cup for 20 seconds. If the measuring cup contains less than 13.5 ounces (400 metric centimeters), the water flow is inadequate. If the amount of water is less than 13.5 ounces then the refrigerator fails the test, remove the filter and test the refrigerator again with the by-pass plug in place. If the refrigerator dispenses the proper amount of water with the by-pass plug in place, then the filter should be replaced. If you no longer have the by-pass plug and it has been over three months since the filter has been replaced, you should replace the filter. If the refrigerator fails the test again and you know you have the proper water pressure in your home, you should call service to check the refrigerator. If the amount of water collected is over 13.5 ounces then the refrigerator passes the test and the dispenser is working correctly. Ice not Dispensing Due To Clumping Ice: Your dispenser may not be dispensing due to clumping ice cubes. The ice cubes in your icemaker may be clumping for a couple of reasons: Low food load: The defrost cycle radiates heat into the freezer. The ice in the freezer will naturally absorb the heat. This will cause the ice to melt slightly during defrost, then eventually freeze together in clumps. Increasing the food load in the freezer will buffer the warmth from the defrost cycle and keeps the ice from melting. Lack of use: When the ice bin is full, the pressure from the weight of the cubes can cause the bottom cubes to fuse and clump. To prevent this from happening, discard the clumped ice and check the bin periodically to ensure the ice is not building up. If you do not use a large amount of ice, move the feeler arm on the icemaker to the up position to turn off the icemaker and stop ice production. For more information on the causes of clumping cubes. If the ice bucket is not seated correctly, ice will not dispense properly. Make sure the ice bucket is in the correct position. Refer to Use & Care manual.
Aug 05, 2012 | Maytag Refrigerators
The Side by Side GE Profile refrigerator does not dispense any water or ice. It worked for a short period of time but just stopped working. Also, all the options that are suppose to be lite go off when the...
Could be several problems (I'm a homeowner, not an expert). GE had a problem with the water line in the freezer door: not enuf insulation so the line freezes, hence no water flow. I would look at this first, especially if you press the water dispenser handle and you hear the pump, but no water comes out. Ditto if the ice bin is empty or the ice maker isn't making any more ice. If the icemaker is making ice but not dispensing it, then the auger (thing that agitates the ice cubes in the bin) may be broken or frozen. (if frozen be sure ice cubes in bin are loose and not frozen into one big ice cube).
Aug 13, 2010 | GE Monogram ZISS420NRSS 42" Built-In...
Icemaker makes shells. Outside is frozen but
Hollow cubes are caused by not having enough water in the ice mold. Fill it up manually by pouring water in it and see how the cubes turn out.
look for an adjustment behind the plastic endcover with a +/- on it. - is less water. + is more water.
Try swapping the wires on the dual water inlet valve. Then try the water dispenser. The water should go to the ice maker. This will tell you weather or not the ice maker valve is working and if the line is clear.
There is a screen filter before the water inlet valve in the water line. It can get partially stopped up with sediment blocking water flow.
Oct 28, 2009 | Freezers
Icemaker stopped working
you likely need a new icemaker (part # 2198597) i would visit the following website to help determine this fact.
Feb 05, 2009 | Whirlpool GD5SHAX Side by Side...
Icemaker works fine, only dispenses water
make sure that the ice shoot is not clogged up with ice or the in the ice basket where the ice goes through. Sometimes the ice can be stuck together and jam and nothing will come out.
Nov 25, 2008 | GE GSS25JEMWW Side by Side
Dispenser doesn't dispense
Mar 21, 2008 | GE Profile Arctica Stainless Steel Top...
Icemaker will not was dispense ice
My icemaker stopped producing ice. We turned off the water line to it when we went on vacation for a week. We turned the water back on when we got home and since that time it won't produce ice. We can still get water from the door dispenser though.
Nov 02, 2007 | GE (PSS26MSRSS) Side by Side Refrigerator
GE (PSS26MSRSS) Side by Side Refrigerator Logo
91 people viewed this question
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
