Question about Celestron AstroMaster 130EQ Telescope
Obscured view through telescope
It appears that the focus mirror is being seen in the center of the view. We have focused a very bright star - but have a cross in the middle of it - and no it is not the Finder we are looking through, and it is not simply crosshairs. There is a specific obstruction. It is visible with both with the eyepiece and without.
Any idea what we could be seeing? And how to fix the issue? I've found the same problem as well - I'm using a Celestron Astromaster 130EQ Newtownian Reflector. I've had a look at a couple of stars and Venus and am getting very poor results- a cross in the middle of the viewfinder and very blurry and grainy image. Doesn't seem to matter what I do with the focus knob - the image just gets more or less blurry (what you'd expect) but the cross is still there.
  • branty1970 Dec 26, 2008
    I've messed around and fiddled to try and find a fix and eventually everything started working properly. Not 100% sure what the problem was but this is what I tried:
    1. Tried another eyepiece - no difference.
    2. Tried pointing the scope straight up - better.
    3. Tried pointing the scope at a bright source again - not good.
    4. Left the camera pointing at the ground for a while.
    5. Tried again and everything started working properly - with both eyepieces.
    I think that the problem might have been some moisture on the eyepieces or the mirror. The scope had been left out for a while before I started observing to let the temperature equalize but when I was experiencing the problems the temperature was dropping like a stone.
    Oh well, experience now a little more than it was 2 hours ago.
  • lspe07 Dec 27, 2008
    I have the same problem with the same telescope.
  • 3,186 Answers
You can slow down dew forming on the mirror by NOT pointing the telescope toward the sky during cool-down-- just leave it parallel to the ground. Same goes for your eyepieces -- leave them covered, or inside a case.
Posted on Dec 28, 2008
When using telescope for the first time (looking at venus) it would not focus, also the cross at the front of the tube was most prominent.
Do stars appear as small pinpoints in your scope? If not then it sounds like you have not adjusted the focus properly. I recommend you take your telescope outside in the daytime and point it toward a building or tree or hilltop that is somewhat distant from you. The exact distance is not important, but it should a block or more.
With the telescope pointed at the distant object, focus the telescope until the object is sharp and clear. The object might appear upside down -- that's normal for many astronomical telescopes. When you have achieved a sharp focus, leave the focus control alone until you are outside at night under the stars.
The focus should now be fairly close for viewing stars and planets. Small adjustments of the focus control may still be necessary for the sharpest view.
Venus is sometimes a difficult object. It is often fairly low in the sky where the atmosphere is most likely to blur the view. Find a bright star and focus it to a pinpoint, then swing your scope toward Venus.
- Jeff
Dec 27, 2016 | Celestron Optics
Why can I not see the difference from the sky and a star even when I allign my laser well?
It sounds like you have not adjusted the focus properly. I recommend you take your telescope outside in the daytime and point it toward a building or tree or hilltop that is somewhat distant from you. The exact distance is not important, but it should a block or more.
- Jeff
Jun 08, 2014 | Celestron NexStar 4 SE Telescope
I used the collimation eyepiece to collimate my telescope.But I dont know if it's properly aligned. The knobs on the bottom of the tube are turned fully clockwise, and the black dot in the eyepiece is...
Before you do anything else, take the scope outside on a good night, find a semi- bright star (Polaris will do). Let the scope cool down! (about 45 minutes) use your highest power eyepiece and put the star in focus.
Now take the star out of focus (inner focus or outer focus) you should see a dark circle in the center with symmetrical rings around it (airy rings). If the dark circle is in the center and the airy rings are symmetrical, your telescope is collimated
Check both inner and outer focus, they should be close to the same. If not you should re-collimate.
Best done with fainter stars but for now stick to the brighter ones.
Because I own 3 scopes, I use a Hotech laser collimator. its quick and easy. Worth it if you travel with your scopes to dark sites
A good guide on how to collimate
http://www.skyandtelescope.com/howto/diy/3306876.html
Oct 16, 2010 | Celestron NexStar 130SLT (31145) (306 x...
When viewing venus or other stars there a black spot in the center of the object. It appears to be the 2nd mirror refleting to the main miror. what have I done incorrect?
You are NOT in focus. Turn the focus knob a little until you see a perfect "disk" for the planet. Stars are always POINTS of light, with a telescope or without a telescope.
Aug 28, 2010 | Celestron NexStar 114GT (269 x 114mm)...
Having a clear sky last night i took my new scope out and started to view the night sky, but focusing on a star ! i found that when viewing it at magnification a could clearly see the the area infront of...
Stars are ALWAYS pinpoints of light when the scope is focused no matter how much magnification is applied.
You are NOT focused properly -- when you are you cannot see the secondary mirror or the "spider" bracket that holds the mirror.
You will NEVER see a star as a disk, only as a pinpoint light. If you are seeing what looks like a donut with a dark center you are not focused.
May 07, 2010 | Celestron PowerSeeker 114 EQ Telescope
Like others, I have trouble seeing stars. There is an obstruction, an image of the secondary mirror which obscures most of the star. Is this the spider? Others have asked the same question, but I haven't...
Yes, you are not focusing the telescope properly. When in focus you cannot see the spider.
Put the eyepiece with the largest number written on it into the telescope. Go outside during the day and practice focusing on a distant object.
Oct 18, 2009 | Bushnell NorthStar® 78-8846 (675 x 114mm)...
Ditto
You bought what we call a toy "department store telescope". Put the eyepiece with the largest number written on it into the scope. DO NOT use any 2x barlow which might have been included.
Go outside during the daytime and practice focusing on a distant object. AND---- no you will not get 450 magnification from that telescope, even though it was written in bold letters on the box.
Sep 21, 2009 | Bushnell NorthStar 78-8831 (525 x 76mm)...
You are seeing the "spider" holding the secondary mirror-- the scope is not in focus--
Practice focusing during the daytime on a distant object at least 100 yards away-- use the lowest power eyepiece-- which is the one with the LARGEST number on it.
Dec 26, 2008 | Edu-Science (10166) Telescope
Fuzzy bright stars with my Celestron CPC 1100 XLT
The image shows that the optics are not centered properly. The secondary may be tilted slightly to the 2 o'clock position. When not centered, a focused star will have an astigmatic shape, and not come to a full focus. Also check the mirror and corrector plate for dewing, that will also affect the views.
Nov 02, 2008 | Optics
Viewing planets and stars
The problem is you are way out of focus. Turn the focus knob alot, until the star image gets much much smaller. Keep going until it looks like a pin point or a star!. The spider vane and center black dot will disappear. This black dot is actually the secondary diagonal mirror reflection in the primary mirror. The peace signs are the secondary supports. Use the lowest power eye pieces. I would not use the Barlow lens that comes with this scope as it very poor quality. Also, using this high power with this small an aperature (tube diamter) & unstable mount will be very difficult indeed. Invest in some wide angle, long eye relief low power lens. Use these for a while before going to higher powers.
Nov 19, 2007 | Bushnell NorthStar 78-8831 (525 x 76mm)...
Celestron AstroMaster 130EQ  Telescope Logo
291 people viewed this question
Top Celestron Optics Experts
Marvin
Marvin
Vernon Taylor
Lawrence Oravetz
Are you a Celestron Optic Expert? Answer questions, earn points and help others
