Question about Maytag SAV4655A Top Load Washer
New belt how do I install a new belt I need help changing a broken belt on an top load washing machine, I already opended the part of the machine where the belt was broken, and purchased a new belt, now I just need to install it.
For the Maytag about which I was asking, one must
roll the belt off the agitator/drum pulley
remove the motor/water pump assembly (1 electrical connector, two hoses with clamps, four 1/2" bolts).
remove the water pump (three torx screws).
Posted on Oct 28, 2007
    President:
  • 1,294 Answers
First put the belt around the small pulley, shd be the motor pulley i think. Then ease the belt around the big pulley & gently move clockwise if the pulley is on the left side; anti clockwise if you are inserting on the right side. The belt will fall into place. Actually it is very simple.
Posted on Apr 20, 2007
Spin. Working short time do not put cloth water out
Sounds like the belt that spins the washing drum is slipping. It my need to be adjusted or replaced, or try washing a smaller load of laundry.
Mar 10, 2016 | GE Washing Machines
Why does my kenmore washer 110 fill with water but won't wash or spin?
Do you happen to hear a humming noise coming from the machine after the tub fills? This might indicate that the motor is spinning, but the belt that connects the motor to the rest of the machine works is broken. It is located underneath the washer. Tip the washer a bit and have a look. If it's broken, you'll probably find the belt laying on the floor. Take that to an appliance parts store where they can match it up with a new one. Installation is not too difficult. The belt will go around the motor pulley, the transmission pulley, the water pump, and in some cases, a spring-loaded tensioner. I hope this helps! :) -Jason
May 06, 2014 | Kenmore 22422 Top Load Washer
Washer makes a buzzing noise when it tries to spin
Hello. Loud noises coming from a Washing Machines are most often caused by looseobjects inside the unit or by a broken dryer belt. The Washing Machines beltallows the dryer's motor to run smoothly. Continuous wear and dry conditionsmay cause the belt to dry out, eventually Washing Machines cracking and thensnapping. This will cause a loud noise within the unit. Repair and fix thedryer belt of a Washing Machines to get rid of loud noises. Instructions And Things You'll Needed to solve the problem.
Screwdriver ,Replacement Washing Machines belt 1 Stop the Washing Machines and look inside the dryer's drum for any looseobjects such as coins, pens or anything else that may have been in a pocket ofclothing. Remove the object and restart the dyer to determine if the noise hasstopped.
2 Unplug the Washing Machines from the wall outlet to disconnect all power tothe unit. 3 Remove the lint trap from the lint compartment on the top of the dryer. 4 Remove the screws that hold the top panel in place. Pull the panel off toaccess the
dryer belt.
5 Tilt the dryer forward and lift the dryer drum to remove the belt. Check theWashing Machines belt. A belt that is worn, cracked, split or broken will causeloud noises. 6 Slide the old belt off of the drum and pull it out to remove it. Take noteon how it is positioned over the drum.
7 Install the new belt. Lean the front panel away from the Washing Machines andslip the new belt over the drum. Locate the position of the old belt and slipthe new belt following the old belt's position ensuring the grooved side of thebelt faces down. Push the idler pulley towards the motor to allow you to slipand loop the belt around the motor pulley.
8 Place the top panel on the Washing Machines and screw it in place.
9 Open the Washing Machines door and use your hand to rotate the drumcounterclockwise a few turns to ensure the belt is secured.
10 Plug the Washing Machines into the wall unit and begin use . Thanks.
Sep 13, 2011 | GE Energy Star WCVH6260F Front Load Washer
Kenmore Series 80 washer doesn't always spin, only 1/3 of time.
First of all check to see if the motor is running, then proceed as follows:
If the motor is running, your washer probably has a frozen pump pulley or a broken pump belt. To check the pulley, remove the pump from the washer and try to rotate the pulley manually. If it doesn't turn freely,if it's frozen or stiff,replace it. If the pump belt is broken or looks quite worn, replace it but be sure to check the pump pulley before you change the belt.
If the motor isn't running, the lid switch may be defective. If so, the washing machine can't spin and may not function at all. The switch is inside the washing machine main housing near the door frame. Often you have to raise or open the top or front of the washing machine to get to the switch. If it's defective, you need to replace it.
Sep 05, 2009 | Kenmore 24902 Top Load Washer
Maytag Top Load washer will spin but won't agitate
sounds like the coupler between the transmission and tub is broken or slipping
Aug 28, 2009 | Maytag LAT2600A Top Load Washer
How to replace a belt on a Maytag MAV6000 washing machine
hey good for you thats an eazy one .pull the washer out abit and then tip so the top resting on wall behind.be careful dose not slip out from under but ihave done it a hundred times as a repairman.before replacing the belt inspect the motor pulley,its plastic and they do melt.also inspect the pump pulley making sure it turns freely and the spot welds are not broken joinning the pulley to the pump shaft...........other wise just spin the old belt off and spin the new belt on.the belt goes on a total of three pulleys .thats it if you need any other help you can email . God bless ,tom
Jan 08, 2009 | Maytag MAV6200 Top Load Washer
Need the belt routing for my washing machine
unless you washer was bought prior to 1988 there is no belt ..washer is direct drive with coupling between motor and gearcase
Jul 30, 2008 | Kenmore 24032\24036 Top Load Washer
Maytag SAV4655A Top Load Washer Logo
176 people viewed this question
Top Maytag Washing Machines Experts
jimorris77
Sheldon Dedek
Bill Long
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
